Default OS update log
#55
(11-03-2019, 09:16 PM)Der Geist der Maschine Wrote:
(11-03-2019, 07:48 PM)rick1959 Wrote:
(11-03-2019, 07:42 PM)evilbunny Wrote:
(11-03-2019, 07:41 PM)rick1959 Wrote:
(11-03-2019, 07:32 PM)evidddlbunny Wrote: use sudo in front of the commands above...
Thanks EV, but here's what I get when I put sudo in front:
Hit:1 http://security.debian.org stretch/updates InRelease
Ign:2 http://cdn-fastly.deb.debian.org/debian stretch InRelease
Hit:3 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease
Hit:4 http://cdn-fastly.deb.debian.org/debian stretch Release
Reading package lists... Done
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
Any other ideas? Thanks! :-)
&& starts a new command, so you need to add sudo between && and apt-get
Perfect, Thank You!!!
The modified command : sudo apt-get update && sudo apt-get dist-upgrade
Works like a charm! :-)
In tutorials, you see quite often commands prefixed with either # or $. They are the typical login prompts, # for root and $ for non-root and they indicate what privileges are required to execute them.
How to become root is a matter of preference.
Hope that helps to avoid confusion in the future.
Thank You!! :-)
I appreciate not being left to my own ignorance! :-)
Just be patient with me....I'll eventually get it :-)
Good Night!!
P.S. How did I get to be a "Senior" member? By age, I guess. Can't be competency!! :-)
Default OS update log - by Luke - 08-10-2019, 06:04 PM
RE: Default OS update log - by aleksei - 08-10-2019, 10:49 PM
RE: Default OS update log - by Luke - 08-12-2019, 10:25 AM
RE: Default OS update log - by zaius - 08-12-2019, 01:42 PM
RE: Default OS update log - by Luke - 08-12-2019, 04:43 PM
RE: Default OS update log - by zaius - 08-12-2019, 06:25 PM
RE: Default OS update log - by Luke - 08-24-2019, 01:21 AM
RE: Default OS update log - by sjk - 08-27-2019, 01:52 PM
RE: Default OS update log - by Luke - 08-27-2019, 02:25 PM
RE: Default OS update log - by binarian - 08-27-2019, 02:31 PM
RE: Default OS update log - by Luke - 08-27-2019, 02:39 PM
RE: Default OS update log - by Luke - 08-27-2019, 03:21 PM
RE: Default OS update log - by Luke - 08-30-2019, 02:21 AM
RE: Default OS update log - by Luke - 08-30-2019, 01:38 PM
RE: Default OS update log - by jvglynnjr - 01-16-2020, 04:03 PM
RE: Default OS update log - by Luke - 08-30-2019, 03:14 PM
RE: Default OS update log - by tllim - 08-31-2019, 08:56 AM
RE: Default OS update log - by zaius - 08-31-2019, 09:08 AM
RE: Default OS update log - by Thra11 - 09-05-2019, 06:05 AM
RE: Default OS update log - by User 6582 - 09-09-2019, 07:17 AM
RE: Default OS update log - by Thra11 - 09-11-2019, 05:46 PM
RE: Default OS update log - by User 6582 - 10-04-2019, 05:21 PM
RE: Default OS update log - by binarian - 09-10-2019, 09:04 AM
RE: Default OS update log - by binarian - 09-10-2019, 10:33 AM
RE: Default OS update log - by ayufan - 08-31-2019, 02:52 PM
RE: Default OS update log - by ac8dg - 09-08-2019, 02:41 PM
RE: Default OS update log - by tllim - 09-09-2019, 04:06 AM
RE: Default OS update log - by Luke - 10-04-2019, 03:20 PM
RE: Default OS update log - by neilman - 10-04-2019, 03:54 PM
RE: Default OS update log - by Luke - 10-04-2019, 04:22 PM
RE: Default OS update log - by bcnaz - 10-15-2019, 12:41 AM
RE: Default OS update log - by Luke - 10-15-2019, 03:47 PM
RE: Default OS update log - by bcnaz - 10-16-2019, 10:18 PM
RE: Default OS update log - by evilbunny - 10-16-2019, 10:45 PM
RE: Default OS update log - by richfm - 11-01-2019, 03:34 PM
RE: Default OS update log - by Watercourse - 11-01-2019, 03:43 PM
RE: Default OS update log - by embhorn - 11-03-2019, 09:42 AM
RE: Default OS update log - by User 6582 - 11-03-2019, 07:30 PM
RE: Default OS update log - by evilbunny - 11-03-2019, 07:32 PM
RE: Default OS update log - by User 6582 - 11-03-2019, 07:41 PM
RE: Default OS update log - by evilbunny - 11-03-2019, 07:42 PM
RE: Default OS update log - by User 6582 - 11-03-2019, 07:48 PM
RE: Default OS update log - by User 6582 - 11-03-2019, 09:20 PM
RE: Default OS update log - by evilbunny - 11-03-2019, 09:29 PM
RE: Default OS update log - by User 6582 - 11-04-2019, 06:37 AM
RE: Default OS update log - by zaius - 11-04-2019, 07:28 AM
RE: Default OS update log - by amp - 11-05-2019, 01:39 AM
RE: Default OS update log - by zaius - 11-05-2019, 12:05 PM
RE: Default OS update log - by amp - 11-06-2019, 02:36 PM
RE: Default OS update log - by amp - 11-04-2019, 01:42 AM
RE: Default OS update log - by Watercourse - 11-03-2019, 11:03 AM
RE: Default OS update log - by fpex73 - 11-03-2019, 11:54 AM
RE: Default OS update log - by Luke - 11-04-2019, 02:31 PM
RE: Default OS update log - by ak_hepcat - 11-04-2019, 05:15 PM
RE: Default OS update log - by Blackr0se - 11-05-2019, 06:32 AM
RE: Default OS update log - by Watercourse - 11-05-2019, 09:06 AM
RE: Default OS update log - by User 11436 - 11-09-2019, 08:54 AM
RE: Default OS update log - by bcnaz - 11-09-2019, 11:25 AM
RE: Default OS update log - by bcnaz - 11-18-2019, 11:38 PM
RE: Default OS update log - by Luke - 11-21-2019, 10:33 AM
RE: Default OS update log - by bcnaz - 11-21-2019, 12:31 PM
RE: Default OS update log - by Luke - 11-21-2019, 01:23 PM
RE: Default OS update log - by tophneal - 11-21-2019, 10:43 AM
RE: Default OS update log - by Luke - 11-21-2019, 01:25 PM
RE: Default OS update log - by Luke - 11-22-2019, 03:46 AM
RE: Default OS update log - by Luke - 11-23-2019, 03:10 PM
RE: Default OS update log - by neilman - 11-23-2019, 04:02 PM
RE: Default OS update log - by GLSRacer - 11-24-2019, 10:57 AM
RE: Default OS update log - by jiyong - 11-24-2019, 01:26 PM
RE: Default OS update log - by ryannshit - 11-24-2019, 05:55 PM
RE: Default OS update log - by Watercourse - 11-24-2019, 07:12 PM
RE: Default OS update log - by pfeerick - 11-25-2019, 03:37 AM
RE: Default OS update log - by GLSRacer - 11-24-2019, 07:16 PM
RE: Default OS update log - by Luke - 11-25-2019, 07:20 AM
RE: Default OS update log - by ryannshit - 11-25-2019, 11:55 AM
RE: Default OS update log - by PabloR - 12-01-2019, 04:48 AM
RE: Default OS update log - by Jeffersoniantoo - 12-01-2019, 07:27 AM
RE: Default OS update log - by PabloR - 12-01-2019, 03:14 PM
RE: Default OS update log - by Jeffersoniantoo - 12-01-2019, 03:28 PM
RE: Default OS update log - by sjk - 12-04-2019, 08:17 AM
RE: Default OS update log - by Mrfixit2001 - 12-05-2019, 11:39 AM
RE: Default OS update log - by sjk - 12-05-2019, 03:29 PM
RE: Default OS update log - by tuxor - 12-08-2019, 05:24 AM
RE: Default OS update log - by Luke - 12-09-2019, 06:48 PM
RE: Default OS update log - by MiiCode2 - 12-09-2019, 09:58 PM
RE: Default OS update log - by sjk - 12-10-2019, 08:54 AM
RE: Default OS update log - by bbraun - 12-09-2019, 11:14 PM
RE: Default OS update log - by Luke - 12-10-2019, 03:06 PM
RE: Default OS update log - by sjk - 12-10-2019, 04:00 PM
RE: Default OS update log - by bigCamel - 12-10-2019, 11:49 PM
RE: Default OS update log - by sjk - 01-10-2020, 06:43 PM
RE: Default OS update log - by sjk - 01-16-2020, 07:54 PM
RE: Default OS update log - by Luke - 12-23-2019, 06:08 AM
RE: Default OS update log - by brent.thierens - 12-23-2019, 09:11 AM
RE: Default OS update log - by Luke - 12-23-2019, 09:32 AM
RE: Default OS update log - by e-minguez - 12-23-2019, 09:43 AM
RE: Default OS update log - by Luke - 12-24-2019, 11:46 AM
RE: Default OS update log - by tuxor - 12-24-2019, 11:09 AM
RE: Default OS update log - by sjk - 12-24-2019, 11:20 AM
RE: Default OS update log - by e-minguez - 12-25-2019, 12:57 AM
RE: Default OS update log - by brent.thierens - 12-28-2019, 04:30 AM
RE: Default OS update log - by e-minguez - 12-31-2019, 04:54 AM
Kernel sources - by kalpazanius - 01-05-2020, 07:25 AM
RE: Default OS update log - by bcnaz - 01-17-2020, 07:33 AM
RE: Default OS update log - by Luke - 01-17-2020, 07:39 AM
RE: Default OS update log - by Luke - 01-17-2020, 08:06 AM
RE: Default OS update log - by Luke - 01-17-2020, 09:25 AM
RE: Default OS update log - by as400 - 01-17-2020, 08:36 AM
RE: Default OS update log - by tophneal - 01-17-2020, 08:49 AM
RE: Default OS update log - by as400 - 01-17-2020, 08:51 AM
RE: Default OS update log - by as400 - 01-17-2020, 08:58 AM
RE: Default OS update log - by neilman - 01-17-2020, 10:22 AM
RE: Default OS update log - by Thanos - 01-17-2020, 12:04 PM
RE: Default OS update log - by tso4ev - 01-18-2020, 06:56 AM
RE: Default OS update log - by Luke - 01-18-2020, 07:11 PM
RE: Default OS update log - by bcnaz - 01-18-2020, 03:10 PM
RE: Default OS update log - by zaius - 01-18-2020, 03:29 PM
RE: Default OS update log - by Luke - 01-19-2020, 06:03 AM
RE: Default OS update log - by bcnaz - 01-18-2020, 03:37 PM
RE: Default OS update log - by tso4ev - 01-19-2020, 03:48 AM
RE: Default OS update log - by Envision - 01-20-2020, 12:14 PM
RE: Default OS update log - by Arwen - 01-20-2020, 01:20 PM
RE: Default OS update log - by Envision - 01-20-2020, 02:21 PM
RE: Default OS update log - by rnorfor - 01-24-2020, 06:19 AM
RE: Default OS update log - by wrzomar - 01-27-2020, 01:51 PM
RE: Default OS update log - by sjk - 01-30-2020, 02:07 PM
RE: Default OS update log - by agurenko - 01-31-2020, 03:32 AM
RE: Default OS update log - by SageFox - 02-05-2020, 05:44 AM
RE: Default OS update log - by LutzFechner - 02-05-2020, 09:07 AM
RE: Default OS update log - by vfr400racer - 02-07-2020, 02:27 PM
RE: Default OS update log - by Luke - 02-07-2020, 03:24 PM
RE: Default OS update log - by ac8dg - 02-07-2020, 04:26 PM
RE: Default OS update log - by amp - 02-08-2020, 02:12 AM
RE: Default OS update log - by xmixahlx - 02-07-2020, 05:39 PM
RE: Default OS update log - by rleasle - 02-08-2020, 12:10 PM
RE: Default OS update log - by amp - 02-09-2020, 01:47 AM
RE: Default OS update log - by wdt - 02-08-2020, 01:45 PM
RE: Default OS update log - by vfr400racer - 02-10-2020, 10:50 AM
RE: Default OS update log - by Arwen - 02-10-2020, 11:14 AM
RE: Default OS update log - by vfr400racer - 02-10-2020, 12:38 PM
RE: Default OS update log - by amp - 02-10-2020, 01:00 PM
RE: Default OS update log - by vfr400racer - 02-10-2020, 01:24 PM
RE: Default OS update log - by sirspate - 02-13-2020, 06:12 PM
RE: Default OS update log - by GLSRacer - 02-13-2020, 08:37 PM
RE: Default OS update log - by tuxor - 03-10-2020, 03:07 PM
RE: Default OS update log - by wdt - 03-11-2020, 10:44 PM
RE: Default OS update log - by Firedevil79 - 03-16-2020, 10:46 PM
RE: Default OS update log - by xmixahlx - 03-17-2020, 01:26 PM
RE: Default OS update log - by Luke - 03-17-2020, 04:29 PM
MATE for upcoming Distros? - by fritzf - 03-21-2020, 10:27 AM
RE: Default OS update log - by bcnaz - 03-21-2020, 06:47 PM
RE: Default OS update log - by xmixahlx - 03-22-2020, 10:33 AM
RE: Default OS update log - by fritzf - 03-22-2020, 10:48 AM
RE: Default OS update log - by hikaricore - 05-06-2020, 03:03 PM
RE: Default OS update log - by Dendrocalamus64 - 05-06-2020, 08:23 PM
RE: Default OS update log - by hikaricore - 05-06-2020, 09:48 PM
RE: Default OS update log - by tso4ev - 05-26-2020, 04:48 AM
RE: Default OS update log - by Luke - 05-26-2020, 06:25 AM
RE: Default OS update log - by tso4ev - 05-26-2020, 07:29 AM
RE: Default OS update log - by bchenlee609 - 06-06-2020, 02:16 PM
RE: Default OS update log - by User 6582 - 05-26-2020, 06:52 AM
RE: Default OS update log - by amp - 05-26-2020, 10:02 AM
RE: Default OS update log - by sinistermrcream - 06-01-2020, 01:44 PM
RE: Default OS update log - by xmixahlx - 06-06-2020, 03:17 PM
RE: Default OS update log - by bcnaz - 06-09-2020, 12:34 PM
RE: Default OS update log - by User 6582 - 06-09-2020, 02:54 PM
RE: Default OS update log - by sirspate - 06-11-2020, 08:03 PM
RE: Default OS update log - by xmixahlx - 06-11-2020, 11:25 PM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,245 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 1,054 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 1,063 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,328 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,429 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 2,105 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 5,983 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 1,382 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 2,591 10-19-2021, 01:57 AM
Last Post: j4n3z
  Trackpad firmware update Luke 263 361,601 07-28-2021, 12:52 PM
Last Post: Luke
