Default OS update log
#30
(09-07-2019, 06:27 PM)Der Geist der Maschine Wrote:
(09-05-2019, 06:05 AM)Thra11 Wrote: As far as suspend to disk (hibernate) is concerned, there are two important points about the hibernation image:
  1. 1. It only needs to contain the contents of memory which is in use (A lot of the time, you won't be using all available memory)
  2. 2. The image is compressed.
This means that you actually have a fairly good chance of hibernating with a swap device which is much smaller than the available RAM.
With Swap Partitions vs Swap Files, in most circumstances the performance differences are minimal, while the advantage of a swapfile is it's trivial to adjust the size while the system is running.
Of course, it's your system, so it shouldn't be too difficult for you to repartition the disk to accomodate a large swap partition if that's what you prefer Smile
Over the last days I educated myself on swap-files. A lot of engineering went into making them efficient.
I'm not yet sure what I will do ... shipping the first batch got delayed and so I have now more time to think about what I will do.
Could the emphasis on a small swap file be to keep the program full in RAM for faster operation?
Default OS update log - by Luke - 08-10-2019, 06:04 PM
RE: Default OS update log - by aleksei - 08-10-2019, 10:49 PM
RE: Default OS update log - by Luke - 08-12-2019, 10:25 AM
RE: Default OS update log - by zaius - 08-12-2019, 01:42 PM
RE: Default OS update log - by Luke - 08-12-2019, 04:43 PM
RE: Default OS update log - by zaius - 08-12-2019, 06:25 PM
RE: Default OS update log - by Luke - 08-24-2019, 01:21 AM
RE: Default OS update log - by sjk - 08-27-2019, 01:52 PM
RE: Default OS update log - by Luke - 08-27-2019, 02:25 PM
RE: Default OS update log - by binarian - 08-27-2019, 02:31 PM
RE: Default OS update log - by Luke - 08-27-2019, 02:39 PM
RE: Default OS update log - by Luke - 08-27-2019, 03:21 PM
RE: Default OS update log - by Luke - 08-30-2019, 02:21 AM
RE: Default OS update log - by Luke - 08-30-2019, 01:38 PM
RE: Default OS update log - by jvglynnjr - 01-16-2020, 04:03 PM
RE: Default OS update log - by Luke - 08-30-2019, 03:14 PM
RE: Default OS update log - by tllim - 08-31-2019, 08:56 AM
RE: Default OS update log - by zaius - 08-31-2019, 09:08 AM
RE: Default OS update log - by Thra11 - 09-05-2019, 06:05 AM
RE: Default OS update log - by User 6582 - 09-09-2019, 07:17 AM
RE: Default OS update log - by Thra11 - 09-11-2019, 05:46 PM
RE: Default OS update log - by User 6582 - 10-04-2019, 05:21 PM
RE: Default OS update log - by binarian - 09-10-2019, 09:04 AM
RE: Default OS update log - by binarian - 09-10-2019, 10:33 AM
RE: Default OS update log - by ayufan - 08-31-2019, 02:52 PM
RE: Default OS update log - by ac8dg - 09-08-2019, 02:41 PM
RE: Default OS update log - by tllim - 09-09-2019, 04:06 AM
RE: Default OS update log - by Luke - 10-04-2019, 03:20 PM
RE: Default OS update log - by neilman - 10-04-2019, 03:54 PM
RE: Default OS update log - by Luke - 10-04-2019, 04:22 PM
RE: Default OS update log - by bcnaz - 10-15-2019, 12:41 AM
RE: Default OS update log - by Luke - 10-15-2019, 03:47 PM
RE: Default OS update log - by bcnaz - 10-16-2019, 10:18 PM
RE: Default OS update log - by evilbunny - 10-16-2019, 10:45 PM
RE: Default OS update log - by richfm - 11-01-2019, 03:34 PM
RE: Default OS update log - by Watercourse - 11-01-2019, 03:43 PM
RE: Default OS update log - by embhorn - 11-03-2019, 09:42 AM
RE: Default OS update log - by User 6582 - 11-03-2019, 07:30 PM
RE: Default OS update log - by evilbunny - 11-03-2019, 07:32 PM
RE: Default OS update log - by User 6582 - 11-03-2019, 07:41 PM
RE: Default OS update log - by evilbunny - 11-03-2019, 07:42 PM
RE: Default OS update log - by User 6582 - 11-03-2019, 07:48 PM
RE: Default OS update log - by User 6582 - 11-03-2019, 09:20 PM
RE: Default OS update log - by evilbunny - 11-03-2019, 09:29 PM
RE: Default OS update log - by User 6582 - 11-04-2019, 06:37 AM
RE: Default OS update log - by zaius - 11-04-2019, 07:28 AM
RE: Default OS update log - by amp - 11-05-2019, 01:39 AM
RE: Default OS update log - by zaius - 11-05-2019, 12:05 PM
RE: Default OS update log - by amp - 11-06-2019, 02:36 PM
RE: Default OS update log - by amp - 11-04-2019, 01:42 AM
RE: Default OS update log - by Watercourse - 11-03-2019, 11:03 AM
RE: Default OS update log - by fpex73 - 11-03-2019, 11:54 AM
RE: Default OS update log - by Luke - 11-04-2019, 02:31 PM
RE: Default OS update log - by ak_hepcat - 11-04-2019, 05:15 PM
RE: Default OS update log - by Blackr0se - 11-05-2019, 06:32 AM
RE: Default OS update log - by Watercourse - 11-05-2019, 09:06 AM
RE: Default OS update log - by User 11436 - 11-09-2019, 08:54 AM
RE: Default OS update log - by bcnaz - 11-09-2019, 11:25 AM
RE: Default OS update log - by bcnaz - 11-18-2019, 11:38 PM
RE: Default OS update log - by Luke - 11-21-2019, 10:33 AM
RE: Default OS update log - by bcnaz - 11-21-2019, 12:31 PM
RE: Default OS update log - by Luke - 11-21-2019, 01:23 PM
RE: Default OS update log - by tophneal - 11-21-2019, 10:43 AM
RE: Default OS update log - by Luke - 11-21-2019, 01:25 PM
RE: Default OS update log - by Luke - 11-22-2019, 03:46 AM
RE: Default OS update log - by Luke - 11-23-2019, 03:10 PM
RE: Default OS update log - by neilman - 11-23-2019, 04:02 PM
RE: Default OS update log - by GLSRacer - 11-24-2019, 10:57 AM
RE: Default OS update log - by jiyong - 11-24-2019, 01:26 PM
RE: Default OS update log - by ryannshit - 11-24-2019, 05:55 PM
RE: Default OS update log - by Watercourse - 11-24-2019, 07:12 PM
RE: Default OS update log - by pfeerick - 11-25-2019, 03:37 AM
RE: Default OS update log - by GLSRacer - 11-24-2019, 07:16 PM
RE: Default OS update log - by Luke - 11-25-2019, 07:20 AM
RE: Default OS update log - by ryannshit - 11-25-2019, 11:55 AM
RE: Default OS update log - by PabloR - 12-01-2019, 04:48 AM
RE: Default OS update log - by Jeffersoniantoo - 12-01-2019, 07:27 AM
RE: Default OS update log - by PabloR - 12-01-2019, 03:14 PM
RE: Default OS update log - by Jeffersoniantoo - 12-01-2019, 03:28 PM
RE: Default OS update log - by sjk - 12-04-2019, 08:17 AM
RE: Default OS update log - by Mrfixit2001 - 12-05-2019, 11:39 AM
RE: Default OS update log - by sjk - 12-05-2019, 03:29 PM
RE: Default OS update log - by tuxor - 12-08-2019, 05:24 AM
RE: Default OS update log - by Luke - 12-09-2019, 06:48 PM
RE: Default OS update log - by MiiCode2 - 12-09-2019, 09:58 PM
RE: Default OS update log - by sjk - 12-10-2019, 08:54 AM
RE: Default OS update log - by bbraun - 12-09-2019, 11:14 PM
RE: Default OS update log - by Luke - 12-10-2019, 03:06 PM
RE: Default OS update log - by sjk - 12-10-2019, 04:00 PM
RE: Default OS update log - by bigCamel - 12-10-2019, 11:49 PM
RE: Default OS update log - by sjk - 01-10-2020, 06:43 PM
RE: Default OS update log - by sjk - 01-16-2020, 07:54 PM
RE: Default OS update log - by Luke - 12-23-2019, 06:08 AM
RE: Default OS update log - by brent.thierens - 12-23-2019, 09:11 AM
RE: Default OS update log - by Luke - 12-23-2019, 09:32 AM
RE: Default OS update log - by e-minguez - 12-23-2019, 09:43 AM
RE: Default OS update log - by Luke - 12-24-2019, 11:46 AM
RE: Default OS update log - by tuxor - 12-24-2019, 11:09 AM
RE: Default OS update log - by sjk - 12-24-2019, 11:20 AM
RE: Default OS update log - by e-minguez - 12-25-2019, 12:57 AM
RE: Default OS update log - by brent.thierens - 12-28-2019, 04:30 AM
RE: Default OS update log - by e-minguez - 12-31-2019, 04:54 AM
Kernel sources - by kalpazanius - 01-05-2020, 07:25 AM
RE: Default OS update log - by bcnaz - 01-17-2020, 07:33 AM
RE: Default OS update log - by Luke - 01-17-2020, 07:39 AM
RE: Default OS update log - by Luke - 01-17-2020, 08:06 AM
RE: Default OS update log - by Luke - 01-17-2020, 09:25 AM
RE: Default OS update log - by as400 - 01-17-2020, 08:36 AM
RE: Default OS update log - by tophneal - 01-17-2020, 08:49 AM
RE: Default OS update log - by as400 - 01-17-2020, 08:51 AM
RE: Default OS update log - by as400 - 01-17-2020, 08:58 AM
RE: Default OS update log - by neilman - 01-17-2020, 10:22 AM
RE: Default OS update log - by Thanos - 01-17-2020, 12:04 PM
RE: Default OS update log - by tso4ev - 01-18-2020, 06:56 AM
RE: Default OS update log - by Luke - 01-18-2020, 07:11 PM
RE: Default OS update log - by bcnaz - 01-18-2020, 03:10 PM
RE: Default OS update log - by zaius - 01-18-2020, 03:29 PM
RE: Default OS update log - by Luke - 01-19-2020, 06:03 AM
RE: Default OS update log - by bcnaz - 01-18-2020, 03:37 PM
RE: Default OS update log - by tso4ev - 01-19-2020, 03:48 AM
RE: Default OS update log - by Envision - 01-20-2020, 12:14 PM
RE: Default OS update log - by Arwen - 01-20-2020, 01:20 PM
RE: Default OS update log - by Envision - 01-20-2020, 02:21 PM
RE: Default OS update log - by rnorfor - 01-24-2020, 06:19 AM
RE: Default OS update log - by wrzomar - 01-27-2020, 01:51 PM
RE: Default OS update log - by sjk - 01-30-2020, 02:07 PM
RE: Default OS update log - by agurenko - 01-31-2020, 03:32 AM
RE: Default OS update log - by SageFox - 02-05-2020, 05:44 AM
RE: Default OS update log - by LutzFechner - 02-05-2020, 09:07 AM
RE: Default OS update log - by vfr400racer - 02-07-2020, 02:27 PM
RE: Default OS update log - by Luke - 02-07-2020, 03:24 PM
RE: Default OS update log - by ac8dg - 02-07-2020, 04:26 PM
RE: Default OS update log - by amp - 02-08-2020, 02:12 AM
RE: Default OS update log - by xmixahlx - 02-07-2020, 05:39 PM
RE: Default OS update log - by rleasle - 02-08-2020, 12:10 PM
RE: Default OS update log - by amp - 02-09-2020, 01:47 AM
RE: Default OS update log - by wdt - 02-08-2020, 01:45 PM
RE: Default OS update log - by vfr400racer - 02-10-2020, 10:50 AM
RE: Default OS update log - by Arwen - 02-10-2020, 11:14 AM
RE: Default OS update log - by vfr400racer - 02-10-2020, 12:38 PM
RE: Default OS update log - by amp - 02-10-2020, 01:00 PM
RE: Default OS update log - by vfr400racer - 02-10-2020, 01:24 PM
RE: Default OS update log - by sirspate - 02-13-2020, 06:12 PM
RE: Default OS update log - by GLSRacer - 02-13-2020, 08:37 PM
RE: Default OS update log - by tuxor - 03-10-2020, 03:07 PM
RE: Default OS update log - by wdt - 03-11-2020, 10:44 PM
RE: Default OS update log - by Firedevil79 - 03-16-2020, 10:46 PM
RE: Default OS update log - by xmixahlx - 03-17-2020, 01:26 PM
RE: Default OS update log - by Luke - 03-17-2020, 04:29 PM
MATE for upcoming Distros? - by fritzf - 03-21-2020, 10:27 AM
RE: Default OS update log - by bcnaz - 03-21-2020, 06:47 PM
RE: Default OS update log - by xmixahlx - 03-22-2020, 10:33 AM
RE: Default OS update log - by fritzf - 03-22-2020, 10:48 AM
RE: Default OS update log - by hikaricore - 05-06-2020, 03:03 PM
RE: Default OS update log - by Dendrocalamus64 - 05-06-2020, 08:23 PM
RE: Default OS update log - by hikaricore - 05-06-2020, 09:48 PM
RE: Default OS update log - by tso4ev - 05-26-2020, 04:48 AM
RE: Default OS update log - by Luke - 05-26-2020, 06:25 AM
RE: Default OS update log - by tso4ev - 05-26-2020, 07:29 AM
RE: Default OS update log - by bchenlee609 - 06-06-2020, 02:16 PM
RE: Default OS update log - by User 6582 - 05-26-2020, 06:52 AM
RE: Default OS update log - by amp - 05-26-2020, 10:02 AM
RE: Default OS update log - by sinistermrcream - 06-01-2020, 01:44 PM
RE: Default OS update log - by xmixahlx - 06-06-2020, 03:17 PM
RE: Default OS update log - by bcnaz - 06-09-2020, 12:34 PM
RE: Default OS update log - by User 6582 - 06-09-2020, 02:54 PM
RE: Default OS update log - by sirspate - 06-11-2020, 08:03 PM
RE: Default OS update log - by xmixahlx - 06-11-2020, 11:25 PM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,251 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 1,054 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 1,066 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,336 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,432 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 2,110 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 5,986 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 1,382 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 2,591 10-19-2021, 01:57 AM
Last Post: j4n3z
  Trackpad firmware update Luke 263 361,754 07-28-2021, 12:52 PM
Last Post: Luke
