Serial console
(11-06-2019, 09:44 AM)Thra11 Wrote:
(11-06-2019, 03:40 AM)danielt Wrote: I've have no problems with USB enumeration and the adapter works fine with u-boot but shortly after the kernel starts the display and serial port stop working if the adapter is left plugged in. This does not happen with my handmade adapter.
I've also been experiencing the issue you describe. I believe it's also the same issue as mentioned here (in relation to RockPRO64) Interestingly, it narrows the problem down to the RX pin (although of course the suggested workaround isn't possible with the jack version, as you can't disconnect only one of the contacts: Plugging the jack in a little later in the boot sequence does work, if you only need to see later boot output). Likewise, I've also observed that other USB-serial adaptors don't cause the problem. I'd be interested to find out what exactly is going on, and whether it might be fixable.
If having the RX pin connected is the problem, then the manufacturer of the cable should not make a difference.
One could make a cable with an inline switch that disconnects the RX pin.
Could someone please replicate this problem?  Then I can add it to the Wiki.
Serial console - by Thra11 - 07-25-2019, 08:19 AM
RE: Serial console - by Luke - 07-25-2019, 01:23 PM
RE: Serial console - by vincele - 08-22-2019, 03:32 AM
RE: Serial console - by hmuller - 11-01-2019, 09:53 PM
RE: Serial console - by belfastraven - 11-03-2019, 04:02 PM
RE: Serial console - by hmuller - 11-03-2019, 10:21 PM
RE: Serial console - by danielt - 11-05-2019, 09:36 AM
RE: Serial console - by danielt - 11-05-2019, 03:01 PM
RE: Serial console - by hmuller - 11-05-2019, 05:40 PM
RE: Serial console - by danielt - 11-06-2019, 03:40 AM
RE: Serial console - by Thra11 - 11-06-2019, 09:44 AM
RE: Serial console - by zaius - 11-06-2019, 02:35 PM
RE: Serial console - by Thra11 - 11-07-2019, 03:42 AM
RE: Serial console - by zaius - 11-07-2019, 06:39 AM
  Serial cable voltage rossk 1 2,724 12-13-2019, 02:36 PM
Last Post: zaius
  "Pinebook Serial Console" unreliable, inhibits boot, kills WiFi and SD Solra Bizna 9 12,294 12-06-2019, 09:53 PM
Last Post: Solra Bizna
  Pinebook serial console usage nemunaire 1 3,368 11-08-2019, 01:34 PM
Last Post: zaius
