RockPro64 pcie Gpu
(05-29-2019, 03:18 PM)Davidos Wrote: Hey Guys,
 I have a qestion to the RockPro64. Is a nvidia 570 geforce compatible withe the RockPro64 ?
 I like to operate over the Pcie. What kind of Pcie I need (sometimes a Pcie x4 to Pcie x16 bridge) ?
 Did I need a special driver or a normal ARM64 driver. My other AMD GPU does not work. The Fans working normal but I get no signal from the HDMI port of the GPU.
I hope someone can help me thanks  [Image: biggrin.png]
Hi ,I read too late that "RK3399 memory mapping PCIe device address space is 32MB"
Anyway I also tried to connect a Nvidia GeForce GT 710 to my Rockpro64, I used a PCI Express 1X to 16X Riser Card . I connect the 12VDC 5A supply , used for the Rockpro64 also to the molex connector of the riser (yellow +12 ) so negative common to rockpro64 and riser.
On Rockpro64 I have Ubuntu 18.04 Bionic LXDE Desktop 32bit (armhf)   Ubuntu 18.04.4 LTS \n \l
and following :
sudo apt update
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get install nvidia-384   (it looks that driver support also GT710)
sudo reboot
After that xrdp stop working, I have no signal on HDMI of GT710 neither on HDMI of Rockpro64 ,
I tried to test if it could mine :
sudo apt-get install automake autoconf pkg-config libcurl4-openssl-dev libjansson-dev libssl-dev libgmp-dev make g++ git libgmp-dev opencl-headers libncurses5-dev libtool
git clone https://github.com/tpruvot/ccminer.git
wget https://developer.download.nvidia.com/co...tu1804.pin
sudo mv cuda-ubuntu1804.pin /etc/apt/preferences.d/cuda-repository-pin-600
sudo dpkg -i cuda-repo-ubuntu1804-10-2-local-10.2.107-435.17.01_1.0-1_arm64.deb
sudo apt-key add /var/cuda-repo-10-2-local-10.2.107-435.17.01/7fa2af80.pub
sudo apt-get update
sudo apt-get -y install cuda
./build.sh
but receive just
(  ccminer.cpp:49:10: fatal error: cuda_runtime.h: No such file or directory
   #include <cuda_runtime.h>    )
RockPro64 pcie Gpu - by Davidos - 05-29-2019, 03:18 PM
RE: RockPro64 pcie Gpu - by laserguru - 06-04-2019, 07:51 PM
RE: RockPro64 pcie Gpu - by Davidos - 06-06-2019, 12:14 PM
RE: RockPro64 pcie Gpu - by pc2005 - 06-19-2019, 03:58 PM
RE: RockPro64 pcie Gpu - by tllim - 06-23-2019, 12:33 AM
RE: RockPro64 pcie Gpu - by bluciano - 03-18-2020, 03:00 AM
RE: RockPro64 pcie Gpu - by bluciano - 03-20-2020, 02:07 PM
RE: RockPro64 pcie Gpu - by ProDigit - 07-14-2020, 05:07 PM
RE: RockPro64 pcie Gpu - by ProDigit - 07-14-2020, 05:11 PM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,078 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 917 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  Compatible PCIe Sata Controller spacebricker 1 1,580 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,944 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 863 12-16-2022, 02:05 PM
Last Post: misterc
  PCIe bifurcation support (on RK3399) Arn 1 1,347 11-28-2022, 05:12 PM
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,651 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 6,727 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,164 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,454 07-18-2022, 10:05 PM
Last Post: zer0sig
