Rock64 v3 and SD-Cards
(05-12-2019, 03:22 PM)tllim Wrote:
(05-10-2019, 06:03 AM)Luke Wrote: Issue has been identified and solved. New images from mrfixit2001 and ayufan will have the fix.
I have upload the mrfixit200 debian image that works with Rock64 v3 to file server and here is the download link: http://files.pine64.org/os/ROCK64/v3/roc...9_2.img.xz
My bootlog with this image, after the loading kernel message it sits flashing the power LED twice per second and no more output or network activity.
Have tried a few different SD cards from 16GB to 64GB, all Class 10/UHS1.
DDR version 1.13 20180428
In
LPDDR3
786MHz
Bus Width=32 Col=11 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=4096MB
ddrconfig:7
OUT
Boot1 Release Time: Feb  2 2018 15:41:39, version: 2.46
ChipType = 0x11, 143
SdmmcInit=2 0
BootCapSize=0
UserCapSize=0MB
FwPartOffset=2000 , 0
SdmmcInit=0 0
BootCapSize=0
UserCapSize=60952MB
StorageInit ok = 24000
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
LoadTrustBL
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa3d00
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):9d3f591
NOTICE:  BL31: Built : 14:39:02, Jan 17 2018
NOTICE:  BL31:Rockchip release version: v1.3
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status 0xe
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 (May 09 2019 - 11:48:17 -0400)
Model: Rockchip RK3328 EVB
DRAM:  4 GiB
Sysmem: init
Relocation Offset is: fed15000
I2c speed: 400000Hz
PMIC:  RK8050 (on=0x02, off=0x01)
vdd_logic 1100000 uV
vdd_arm 1100000 uV
MMC:   rksdmmc@ff500000: 1, rksdmmc@ff520000: 0
*** Warning - bad CRC, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
switch to partitions #0, OK
mmc1 is current device
Unknown command 'rkimgtest' - try 'help'
Card did not respond to voltage select!
mmc_init: -95, time 9
Unknown command 'rknand' - try 'help'
Unknown command 'rksfc' - try 'help'
Bootdev: mmc 0
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 0N/A)
  apll 400000 KHz
  dpll 1572000 KHz
  cpll 1200000 KHz
  gpll 491009 KHz
  npll 600000 KHz
  armclk 600000 KHz
  aclk_bus 150000 KHz
  hclk_bus 75000 KHz
  pclk_bus 75000 KHz
  aclk_peri 150000 KHz
  hclk_peri 75000 KHz
  pclk_peri 75000 KHz
Net:
Warning: ethernet@ff540000 (eth0) using random MAC address - e2:b5:61:c5:27:cc
eth0: ethernet@ff540000
Hit key to stop autoboot('CTRL+C'):  0
Unknown command 'boot_android' - try 'help'
Unknown command 'bootrkp' - try 'help'
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
351 bytes read in 4 ms (85 KiB/s)
1: ROCK64
Retrieving file: /Image
reading /Image
22226952 bytes read in 1006 ms (21.1 MiB/s)
append: console=tty1 rw root=PARTUUID=deedbeef-02 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr= eth1addr= serial=c3d9b8674f4b94f6 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 loglevel=3
Retrieving file: /rk3328-rock64.dtb
reading /rk3328-rock64.dtb
72924 bytes read in 8 ms (8.7 MiB/s)
## Flattened Device Tree blob at 08300000
   Booting using the fdt blob at 0x8300000
   Loading Device Tree to 00000000f6eed000, end 00000000f6f01cdb ... OK
Adding bank: 0x00200000 - 0xff000000 (size: 0xfee00000)
Total: 4576.971 ms
Starting kernel ...
In
LPDDR3
786MHz
ddrconfig:7
OUT
ChipType = 0x11, 144
SdmmcInit=2 0
BootCapSize=0
UserCapSize=0MB
SdmmcInit=0 0
BootCapSize=0
UserCapSize=60952MB
StorageInit ok = 23989
Raw SecureMode = 0
LoadTrustBL
No find bl30.bin
No find bl32.bin
RunBL31 0x10000
INFO:    SPSR = 0x3c9
DRAM:  4 GiB
Sysmem: init
I2c speed: 400000Hz
vdd_arm 1100000 uV
In:    serial@ff130000
Bootdev: mmc 0
  apll 400000 KHz
  dpll 1572000 KHz
  cpll 1200000 KHz
  gpll 491009 KHz
  npll 600000 KHz
  armclk 600000 KHz
  aclk_bus 150000 KHz
  hclk_bus 75000 KHz
  pclk_bus 75000 KHz
  hclk_peri 75000 KHz
  pclk_peri 75000 KHz
Net:
Scanning mmc 1:1...
345 bytes read in 4 ms (84 KiB/s)
1: ROCK64
reading /Image
22226952 bytes read in 1007 ms (21 MiB/s)
append: console=tty1 rw root=/dev/mmcblk1p2 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr= eth1addr= serial=c3d9b8674f4b94f6 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 loglevel=3
Total: 4577.812 ms
Starting kernel ...
Rock64 v3 and SD-Cards - by Humberg - 05-06-2019, 10:04 AM
RE: Rock64 v3 and SD-Cards - by Luke - 05-08-2019, 02:54 AM
RE: Rock64 v3 and SD-Cards - by Leapo - 05-08-2019, 09:49 AM
RE: Rock64 v3 and SD-Cards - by ketominer - 05-16-2019, 02:50 PM
RE: Rock64 v3 and SD-Cards - by Luke - 05-10-2019, 06:03 AM
RE: Rock64 v3 and SD-Cards - by tllim - 05-12-2019, 03:22 PM
RE: Rock64 v3 and SD-Cards - by dene - 05-13-2019, 01:04 AM
RE: Rock64 v3 and SD-Cards - by PDXpi - 06-05-2019, 06:25 AM
RE: Rock64 v3 and SD-Cards - by Leapo - 05-27-2019, 12:33 PM
RE: Rock64 v3 and SD-Cards - by Luke - 06-02-2019, 08:12 AM
RE: Rock64 v3 and SD-Cards - by Leapo - 02-01-2020, 09:16 PM
RE: Rock64 v3 and SD-Cards - by elibenyaacov - 06-02-2019, 02:04 AM
RE: Rock64 v3 and SD-Cards - by igorp - 06-06-2019, 12:48 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 290 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,364 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,703 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,165 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 337 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,897 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,539 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,117 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 763 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 960 10-07-2022, 07:50 PM
Last Post: rookie_267
