At what point do you give up and ask for a refund or another board
(05-02-2016, 08:32 AM)mr pink Wrote: thanks for all your help guys!  I have left rating where appropriate. It turns out the SD cards I was using was the issue.  Finally made it and not on to the next chapter of shaping things up!
Great to hear you got it going!
If I've helped you with something, please leave a rating for my responses.
RE: At what point do you give up and ask for a refund or another board - by pine.tree - 05-02-2016, 08:50 AM
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 1,590 10-06-2022, 08:46 PM
Last Post: ihab
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 15,539 05-15-2019, 02:55 PM
Last Post: Thatoo
  My first Single Board! jjh221 4 6,808 04-09-2018, 06:52 PM
Last Post: jjh221
  sopine cluster board install Smurfbot 1 4,419 03-31-2018, 04:09 AM
Last Post: pfeerick
  What is the format that one should use for imaging SD cards on APINE64+2GB Board? Doryan 1 3,542 03-05-2018, 08:11 PM
  Which board to use? Dayve 0 2,296 02-18-2018, 06:31 AM
Last Post: Dayve
  Kodi on Rock64 board cenguix 2 8,877 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
  What are these pins on PIN board? dims 1 3,256 01-15-2018, 11:21 AM
Last Post: Luke
  What is on the Micro SC card that came with the board? clawinus 1 3,700 11-03-2016, 02:33 PM
Last Post: MarkHaysHarris777
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,550 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
