Armbian - need help, locked out myself by setting backlight to zero
(03-30-2019, 10:55 PM)pfeerick Wrote: The fix is to either login via serial/network and tweak the right sysfs path
for network - when armbian is normally iinstalled - it uses the network-manager.
so when you then insert a USB-Ethernet-Dongle this would use DHCP and you can connect via ssh.
Then you have to find/edit the screen setting.
Network access on the Pinebook would be much more easy than a serial-port-login , because a usb-serial-donge would automatically become a serial-terminal Wink
RE: Armbian - need help, locked out myself by setting backlight to zero - by guidol - 03-31-2019, 12:36 PM
  Armbian broken sometime in the last few months acruhl 4 2,269 05-29-2024, 10:44 PM
Last Post: acruhl
  Change console resolution (Armbian/bookworm) jcgraybill 1 3,114 06-22-2023, 01:31 PM
Last Post: jcgraybill
  Armbian 22.02 Release Announcement TRS-80 0 2,132 02-28-2022, 05:02 PM
Last Post: TRS-80
  Big thanks to Armbian! soupbowl 2 4,240 12-30-2021, 01:36 PM
Last Post: rookieone
  Armbian - Xenial Desktop (Pinebook) pineadmin 83 140,008 07-17-2019, 01:22 PM
Last Post: catsmile
  Wi-fi stops working - Armbian cel 1 4,060 06-26-2019, 01:57 PM
Last Post: cel
  Improve the life of your Pinebook battery by setting charger's voltage limits wlad 0 3,400 06-11-2019, 02:27 PM
Last Post: wlad
  Failure in setting the display backlight with Armbian 5.86 [SOLVED] wlad 0 2,685 06-11-2019, 03:36 AM
Last Post: wlad
  Armbian 18.04 (Bionic) for Pinebook Luke 0 3,807 08-17-2018, 02:28 PM
Last Post: Luke
  How to test the emmc(usdhc2) diver and pwm backlight driver? vinothkumar 0 2,499 12-29-2017, 11:40 PM
Last Post: vinothkumar
