manjaro and qemmu+kvm
(02-25-2019, 04:53 AM)erchache2000 Wrote: Hi, im trying to install qemmu on pinebook using manjaro.
I see kernel has enabled KVM via dmesg, but when try to create qemmu image ovmf files arent installed.
Strit said Anarsoul is kernel maintainer of manjaro-arm for pinebook.
But some packages aren't on majaro, like this, https://aur.archlinux.org/packages/ovmf-aarch64/
Any tips to install correctly qemu+kvm on pinebook?
Hi erchade2000
The package `ovmf-aarch64` that you mention is an AUR (Archlinux User Repository) package. AUR is not supported by `pacman`. The Archlinux devs prefer to have a natural barrier if you use AUR packages. That has advantages (you understand better what you are doing) but is also sometimes a bit cumbersome.
You can download and install the package manually (see wiki) or and generally more comfortably you use a so called AUR helper. The AUR helper makes access to the AUR repository very similar to the way pacman works and also can be used as a pacman replacement.
You might want to give `yay` a look (no dependencies) or maybe `trizen`
You can then install the package like this: `yay -S ovmf-aarch64`
If you use the AUR it is expected that you have installed the base-devel package group. Or you occasionally have to install a build dependency.
All packages available in the AUR for Archlinux are as far as I know also available for Manjaro.
(There are sometimes packages that are not supported for you architecture, but that's the same for Archlinux then)
manjaro and qemmu+kvm - by erchache2000 - 02-25-2019, 04:53 AM
RE: manjaro and qemmu+kvm - by Surehand53 - 02-27-2019, 12:48 PM
RE: manjaro and qemmu+kvm - by Skywheel - 06-11-2019, 03:11 AM
Information Manjaro ARM for Pinebook erchache2000 88 113,107 11-29-2020, 04:36 PM
Last Post: Mr.Fermer
  Plasma-wayland on Manjaro tophneal 2 6,100 09-01-2020, 06:48 AM
  Manjaro sway profile for pinebook e-minguez 3 5,347 07-21-2020, 03:25 PM
Last Post: jezek
  Manjaro instability DAMO238 6 9,402 10-17-2019, 12:55 PM
  Manjaro hangs on boot DAMO238 1 3,253 07-08-2019, 08:14 AM
Last Post: DAMO238
