Serial communcation with USB to serial(DB9) cable
(01-08-2019, 11:40 AM)mknawabi Wrote: Hi rahulsharma,
I think you are trying to get serial console access to the rockpro64 by plugging in a USB serial adapter in one of the USB ports. Unfortunately, to get serial access to the RP64, you need a 3V3 TTL serial adapter (FT232 or others) that plug into the GPIO pins.
The guide to get this working is here:
https://forum.pine64.org/showthread.php?...&pid=43567
So that means i can't use usb port for serial communication?
As i have done serial communication with gpio pins (6,8,10) and used a usb to TTL converter. That is done.
What i asked to use USB port to send serial data for serial communication. Can i do that?
@martinayotte
Yes, The device at the receiving end is a serial +-12v. So please suggest how to achieve that.
And anyhow i have to use a TTL to serial converter in between but i want to distinguish two possibilities-
1) one is i use gpio pins(6,8,10) and then use converter
2) If i want to use one of the USB port instead of GPIOs so how can i do that?
Thanks.
RE: Serial communcation with USB to serial(DB9) cable - by rahulsharma - 01-10-2019, 05:29 AM
  Serial Output Garbage after initial messages jamforlunch 3 2,172 07-07-2022, 06:36 PM
Last Post: t4_4t
  Change Baudrate for Built-On Serial R0b0t1 1 2,994 10-04-2020, 04:50 AM
Last Post: Gienek
  USB Type-C Display cable support (for 2 in 1: Video + Power) Paprika88 0 2,407 02-12-2020, 06:47 AM
Last Post: Paprika88
  Is there a guide to using the PADI-Server serial console adapter? Tim Jones 1 2,703 11-04-2019, 01:25 PM
Last Post: xalius
  u-boot serial port speed? zener 2 4,014 10-06-2018, 12:47 PM
Last Post: zener
