Slow ethernet in linux
#20
netperf tests with standard pfifo_fast
$ netperf -H wielkiczarny.local -l 60 -t TCP_STREAM
MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to wielkiczarny.local () port 0 AF_INET : demo
Recv   Send    Send
Socket Socket  Message  Elapsed
Size   Size    Size     Time     Throughput
bytes  bytes   bytes    secs.    10^6bits/sec
87380  16384  16384    60.00     695.63
Recv   Send    Send
87380  16384  16384    60.00     702.86
$ netperf -H wielkiczarny.local -l 60 -t TCP_MAERTS
MIGRATED TCP MAERTS TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to wielkiczarny.local () port 0 AF_INET : demo
Recv   Send    Send
87380  16384  16384    60.00     733.93
$ netperf -H wielkiczarny.local -l 60 -t UDP_STREAM
MIGRATED UDP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to wielkiczarny.local () port 0 AF_INET : demo
Socket  Message  Elapsed      Messages
Size    Size     Time         Okay Errors   Throughput
bytes   bytes    secs            #      #   10^6bits/sec
212992   65507   60.00      101426      0     885.87
212992           60.00        4087             35.70
$ netperf -H wielkiczarny.local -l 60 -t UDP_RR
MIGRATED UDP REQUEST/RESPONSE TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to wielkiczarny.local () port 0 AF_INET : demo : first burst 0
Local /Remote
Socket Size   Request  Resp.   Elapsed  Trans.
Send   Recv   Size     Size    Time     Rate
bytes  Bytes  bytes    bytes   secs.    per sec
212992 212992 1        1       60.00    8486.10
212992 212992
$ ip l show dev eth0
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/ether 7a:6e:63:xx:xx:xx brd ff:ff:ff:ff:ff:ff
Still It is unclear to me why wget from Internet is pretty slow at ~4-6MB/s, and maks 10MB/s at the start of download.
Slow ethernet in linux - by dipole - 04-17-2016, 08:32 AM
RE: Slow ethernet in linux - by androsch - 04-17-2016, 08:50 AM
RE: Slow ethernet in linux - by dipole - 04-17-2016, 09:04 AM
RE: Slow ethernet in linux - by may1791 - 04-17-2016, 03:18 PM
RE: Slow ethernet in linux - by coleshores - 04-18-2016, 09:40 AM
RE: Slow ethernet in linux - by Sailing_Nut - 04-22-2016, 01:53 PM
RE: Slow ethernet in linux - by patrickhwood - 04-22-2016, 09:06 PM
RE: Slow ethernet in linux - by androsch - 04-22-2016, 04:25 PM
RE: Slow ethernet in linux - by Sailing_Nut - 04-22-2016, 07:13 PM
RE: Slow ethernet in linux - by androsch - 04-23-2016, 01:15 AM
RE: Slow ethernet in linux - by baryluk - 04-23-2016, 03:11 PM
RE: Slow ethernet in linux - by piahoo - 04-28-2016, 09:03 AM
RE: Slow ethernet in linux - by tkaiser - 04-28-2016, 09:45 AM
RE: Slow ethernet in linux - by piahoo - 04-28-2016, 12:55 PM
RE: Slow ethernet in linux - by tkaiser - 04-28-2016, 01:02 PM
RE: Slow ethernet in linux - by baryluk - 04-28-2016, 04:15 PM
RE: Slow ethernet in linux - by ak_hepcat - 04-29-2016, 12:41 PM
RE: Slow ethernet in linux - by longsleep - 04-29-2016, 01:03 PM
RE: Slow ethernet in linux - by ak_hepcat - 04-29-2016, 02:21 PM
RE: Slow ethernet in linux - by baryluk - 05-01-2016, 01:27 PM
RE: Slow ethernet in linux - by ak_hepcat - 05-04-2016, 01:40 PM
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 9,285 03-28-2020, 06:20 PM
Last Post: ty1911
  Howto run Linux with resolution other than 1080p longsleep 28 66,755 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 5,135 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,257 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 48,720 01-28-2019, 11:05 PM
Last Post: necrose99
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 2,926 12-06-2018, 01:14 AM
Last Post: tenspd137
  Real-time linux kernel Artyom 45 73,019 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 6,166 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 5,838 01-30-2018, 10:26 AM
Last Post: Rustproof
  eta linux image?? firosiro 1 4,076 08-03-2017, 10:05 PM
Last Post: pfeerick
