10-07-2018, 11:16 PM
Hi all,
these weekend I had time to play a bit with Recalbox, I mean testing it. I added up to 4K roms almost 8bit and 16bit generations and then I setup an overlay scanlines for each system. For each system the graphic had a lot of weird artifacts, while with the shaders the graphic is fine while the sound emulation is laggy, with the Alpha version and almost the same quantity of Roms I didn't have artifacts on screen. Other issues were the frequent crashes, for each system every three roms the system got freeze or simply restarted. I can't say if because the overlays or because the high numbers or roms available, unfortunately the log systems it is not very friendly, it just shows what happened with the last rom you played. Is there a way to improve the quality and quantity of the logs available? Without logs is difficult to understand as well as catching bugs and system issues.
Thanks,
Danielsan
Thanks,
Danielsan
