ANNOUNCING *BETA* RELEASE OF RECALBOX FOR THE ROCK64
(08-05-2018, 02:17 PM)Brainy142 Wrote: I noticed that games are still trying to run in 4k 30fps rather than 1080p. I'll try to SSH and confirm if the settings are correct. the recalbox OS runs normally, however, when retroarch runs it switches to 4k output. I can confirm the setting is set to the default value of 1080p.
On the plus side, Kodi seems to work well for videos up to 1080p as well, hdr10 works perfectly. I notice that 4k playback does not work well (likely will improve with drivers) as well, audio pass-through is intermittent in Kodi.
Other than that. it definitely feels faster than my RPI3 on loading and general interface browsing.
Thanks for the feedback! What exactly do you mean by saying that games 'try' to run at 4K? - do they end up running at 4k or not ? Would be strange if they did since both RA and non RA emulators/ cores are at 1080p on my 4k monitor ...
Well, you're absolutely correct. RA emulators all run at 4K ... while stand-alone emulators such as Mupen64 run at 1080p (as they should). Thanks for pointing it out !
RE: ANNOUNCING *BETA* RELEASE OF RECALBOX FOR THE ROCK64 - by Luke - 08-05-2018, 02:50 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,373 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 619 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 613 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,420 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,731 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 593 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,458 12-07-2022, 08:22 PM
Last Post: luminosity7
