Battery Powered
(07-17-2018, 02:36 AM)pfeerick Wrote: You can run anything from batteries if you work the problem enough. 240AC-only appliance? Get a big enough 12-48v battery and inverter combo. DC appliances? Get a big enough switching regulator (fixed or adjustable).
In the case of the rockpro64, I'm running mine from a solar charged 12v solar setup, and to give it a stable 12v supply it's running from a step up / setup down regulator that ensures that regardless of if the input voltage is above or below the 12v the rockpro64 needs, it gets the stable 12v it needs. And since it's a 10A supply, it should be able to power the 12v side of a 3.5" hard drive or two.
Would you be so kind to list the specific parts you used and perhaps an image of the setup?
Battery Powered - by Firesped - 07-15-2018, 11:33 AM
RE: Battery Powered - by pfeerick - 07-17-2018, 02:36 AM
RE: Battery Powered - by duckkcud - 09-20-2018, 03:26 PM
RE: Battery Powered - by RockPro64Newbie - 09-23-2018, 08:06 PM
RE: Battery Powered - by Firesped - 09-19-2018, 07:19 PM
RE: Battery Powered - by bobdaroze - 10-23-2018, 11:16 AM
RE: Battery Powered - by tllim - 10-23-2018, 07:24 PM
RE: Battery Powered - by bobdaroze - 10-25-2018, 10:02 AM
RE: Battery Powered - by duckkcud - 10-30-2018, 08:30 AM
RE: Battery Powered - by fysa - 04-11-2019, 08:41 PM
RE: Battery Powered - by Nikolay_Po - 05-26-2019, 07:05 AM
RE: Battery Powered - by bobdaroze - 06-07-2019, 08:06 AM
RE: Battery Powered - by tllim - 06-07-2019, 12:18 PM
RE: Battery Powered - by ender_saved - 06-19-2019, 09:19 AM
RE: Battery Powered - by RockPro64Newbie - 07-15-2019, 05:20 PM
RE: Battery Powered - by ender_saved - 08-02-2019, 07:56 AM
RE: Battery Powered - by pfeerick - 07-15-2019, 07:27 PM
RE: Battery Powered - by stuartiannaylor - 07-21-2019, 05:04 AM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,067 04-01-2024, 10:24 PM
Last Post: nano2
Question RockPro64 Lithium Battery Port TitleOS 0 1,889 12-05-2020, 12:35 AM
Last Post: TitleOS
  Can RockPro64 be powered via usb-c? pawlinski 2 3,721 10-16-2020, 07:27 AM
Last Post: pawlinski
  connector type SPDIF FAN RTC battery? ChriChri 4 5,707 03-21-2020, 06:47 AM
Last Post: ChriChri
  Rockpro64 12v Lipo battery for playbox? ScrumpyJack 0 1,741 09-18-2019, 01:25 AM
Last Post: ScrumpyJack
  USB powered externall hard drive not powering Shilelis 5 6,808 03-15-2019, 11:34 AM
Last Post: len
