OS's for the Rock64
I had loaded the bionic minimal rock64 and this just gave me a command prompt.
I used the tasksel to install the mate desktop.
Maybe i installed the wrong thing, I used the pine installer IE etcher.
Kind of a newbe with the rock 64, just got it this week.
I bought it mainly to replace my Raspberrypi as a faster NAS using openmediavault.
And wow it is faster for sure.
Looking forward to some improvements in the OMV supplied by your group.
I got version 0.6.44-239 working but it won't accept the password (openmediavault) when trying to log in via SSL.
When I try locally to go to omv-firstaid to set a static ip address as I type it outputs string of code with every key stroke.
Keep up the great work, this board is a great improvement over the Raspberrypi for NAS use.
Rich Prim
Going to SSH and clicking on "allow root login " fixed the rejection of the openmediavault passwork being rejected.
But when I tried to use omv-firstaid to set a ip address the below was the response from the board.
ERROR: dialog-like terminated due to an error: the dialog-like program exited with status 3 (which was passed to it as the DIALOG_ERROR environment variable). Sometimes, the reason is simply that dialog was given a height or width parameter that is too big for the terminal in use. Its output, with leading and trailing whitespace stripped, was:
Error: Expected at least 5 tokens for --menu, have 4.
Use --help to list options.
root@rock64:~#
OS's for the Rock64 - by richprim - 06-22-2018, 06:55 AM
RE: OS's for the Rock64 - by fire219 - 06-22-2018, 08:43 AM
RE: OS's for the Rock64 - by richprim - 06-22-2018, 09:39 AM
RE: OS's for the Rock64 - by pfeerick - 06-22-2018, 08:58 PM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 339 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,458 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,779 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,289 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 362 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,963 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,582 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,159 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 775 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 973 10-07-2022, 07:50 PM
Last Post: rookie_267
