Does rock64 have a RTC
(05-30-2018, 09:21 PM)jata Wrote: thanks for this but this appears to be proper RTC hardware not the software that does a similar function. I'm going to keep investigating.
The main processor (RK3328) does not have a RTC as far as I can tell, but the RK805, which is the programmable DC-DC converter unit providing all the voltages the board needs does have one. I don't know if you can use it as an RTC for the board, or if it's primary purpose of existing is just to allow for time triggered poweron. The datasheet does list all the registers and such, so if you can poke the RK805 registers you might be able to find out. Just be careful what you poke as if you poke the wrong think you might fry something by setting a voltage you shouldn't. You have been warned™ ™.
Does rock64 have a RTC - by jata - 05-30-2018, 05:38 PM
RE: Does rock64 have a RTC - by Rocklobster - 05-30-2018, 06:35 PM
RE: Does rock64 have a RTC - by jata - 05-30-2018, 09:21 PM
RE: Does rock64 have a RTC - by pfeerick - 05-31-2018, 03:48 AM
RE: Does rock64 have a RTC - by Z80 - 06-02-2018, 08:56 PM
RE: Does rock64 have a RTC - by pfeerick - 06-02-2018, 09:48 PM
RE: Does rock64 have a RTC - by evilbunny - 06-02-2018, 11:21 PM
RE: Does rock64 have a RTC - by Z80 - 06-02-2018, 11:53 PM
RE: Does rock64 have a RTC - by jata - 06-15-2018, 05:16 AM
RE: Does rock64 have a RTC - by fire219 - 06-15-2018, 08:19 AM
RE: Does rock64 have a RTC - by jata - 06-15-2018, 03:50 PM
RE: Does rock64 have a RTC - by pfeerick - 06-15-2018, 04:04 PM
RE: Does rock64 have a RTC - by jata - 06-15-2018, 05:04 PM
RE: Does rock64 have a RTC - by pfeerick - 06-16-2018, 03:15 AM
RE: Does rock64 have a RTC - by jata - 06-19-2018, 05:05 PM
RE: Does rock64 have a RTC - by pfeerick - 06-19-2018, 08:13 PM
RE: Does rock64 have a RTC - by tllim - 06-20-2018, 01:19 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 290 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,367 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,704 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,167 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 337 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,897 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,539 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,118 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 764 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 962 10-07-2022, 07:50 PM
Last Post: rookie_267
