Rock64 ethernet problems
Hi
I have a Rock64 board 4GB version and just cannot get a reliable ethernet connection.
I have flashed the SPI and I am booting from a USB 3.0 HDD (1TB) connected to a powered USB 3 hub.
The same problem occurs with ayufan linux, Armbian, Nextcloudpi and DietPi; with DietPi being the most stable to date.
While I can get to the login screen and login when connected directly to a keyboard and HDMI, when I connect an ethernet cable or SSH into the machine the whole system slows and becomes unresponsive.
The ethernet lights flash intermittently and often go blank for 20-30 seconds at a time.
I have tried limiting the ethernet connection to 100MB, cutting the blue and brown cables, two different routers and the problem is always the same.
As I intend to use this as a Nextcloud server obviously reliable ethernet is key.  Is this a common problem and how can I fix it before returning the board.
Rock64 ethernet problems - by ushills - 05-29-2018, 03:50 AM
RE: Rock64 ethernet problems - by Rocklobster - 05-29-2018, 05:37 AM
RE: Rock64 ethernet problems - by ushills - 05-29-2018, 05:40 AM
RE: Rock64 ethernet problems - by Rocklobster - 05-29-2018, 06:10 AM
RE: Rock64 ethernet problems - by pfeerick - 05-29-2018, 05:16 PM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 288 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,339 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,697 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,158 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 337 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,895 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,534 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,111 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 762 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 957 10-07-2022, 07:50 PM
Last Post: rookie_267
