[SOLVED] stuck at emmc
ok that worked fine.
shortened 20 and 21 just to boot ( remove after several seconds)
DDR version 1.08 20170628
In
LPDDR3
333MHz
Bus Width=32 Col=11 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=4096MB
ddrconfig:7
OUT
U-Boot SPL 2017.09-ga0a2b48 (Apr 27 2018 - 18:00:06)
setup_ddr_param 1
booted from SD
Trying to boot from MMC2
NOTICE: BL31: v1.3(debug):9d3f591
NOTICE: BL31: Built : 14:39:02, Jan 17 2018
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-ga0a2b48 (Apr 27 2018 - 18:00:21 +0000), Build: jenkins-linux-build-rock-64-211
Model: Pine64 Rock64
DRAM: 4 GiB
MMC: rksdmmc@ff520000: 0, rksdmmc@ff500000: 1
*** Warning - bad CRC, using default environment
In: serial@ff130000
Out: serial@ff130000
Err: serial@ff130000
misc_init_r
cpuid=55524b50303930303500000000122119
serial=95ac81d6aa1d2bf
Net: eth0: ethernet@ff540000
Hit any key to stop autoboot: 0
Card did not respond to voltage select!
mmc_init: -95, time 10
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:6...
Found U-Boot script /boot.scr
reading /boot.scr
449 bytes read in 4 ms (109.4 KiB/s)
## Executing script at 00500000
SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
MMC read: dev # 1, block # 64, count 8000 ... 8000 blocks read: OK
SF: 4096000 bytes @ 0x8000 Erased: OK
device 0 offset 0x8000, size 0x3e8000
SF: 4096000 bytes @ 0x8000 Written: OK
ANd it boots from usb as well as well as sd Smile
thnx for the direction you pointed me to Smile
Dre
[SOLVED] stuck at emmc - by dr_dre - 04-28-2018, 09:46 AM
RE: stuck at emmc - by vincent37 - 04-28-2018, 02:44 PM
RE: stuck at emmc - by dr_dre - 04-29-2018, 01:17 AM
RE: stuck at emmc - by evilbunny - 04-29-2018, 03:07 AM
RE: stuck at emmc - by pfeerick - 04-29-2018, 03:30 AM
RE: stuck at emmc - by dr_dre - 04-29-2018, 04:03 AM
RE: stuck at emmc - by dr_dre - 04-29-2018, 04:59 AM
RE: stuck at emmc - by dr_dre - 04-29-2018, 05:38 AM
RE: stuck at emmc - by Facecreator - 04-29-2018, 08:12 AM
RE: stuck at emmc - by dr_dre - 04-29-2018, 11:59 AM
RE: stuck at emmc - by pfeerick - 04-29-2018, 05:10 PM
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,076 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 2,988 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 3,740 08-19-2021, 06:46 PM
Last Post: bcnaz
  Rock64 No Audio - Solved wbecks 12 30,250 08-13-2021, 01:23 PM
Last Post: blakeadam
  Segfault with GCC in Armbian [Solved]. ejolson 13 18,637 07-07-2021, 10:16 AM
Last Post: stelabentley
  Receiving errors about eMMC (?) acasta 11 15,911 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 29,220 07-27-2019, 04:27 PM
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 105,967 02-06-2019, 04:02 PM
  flash image to sd/emmc through ethernet LMM 0 2,288 02-04-2019, 07:36 AM
Last Post: LMM
  Card emmc Auggoncalves 2 3,695 06-25-2018, 03:20 AM
Last Post: Auggoncalves
