Rock64 - Stuck when do the soft reboot
(06-15-2018, 08:26 AM)ramprasad Wrote: Hi pfeerick,
     We have contacted the Longsys (FORSEE eMMC support company) regarding this issue and provided the FORSEE eMMC model (NCEMAD6B-16G - from Pine64 website). The LONGSYS responded that this model was End of Life and it may be signal compatibility issue and was asked to change the MODE to SDR50. Can you please somebody provide some pointers how to change the mode. I observed the mmc command in uboot to set several parameters, but not the MODE. Also checked the documentation (/Documentation/devicetree/bindings/mmc/mmc.txt) provided a parameter (sd-uhs-sdr50) in .dtsi file. But I am not sure about correct procedure. Can somebody provide some info about how to change and achieve this.
       And one more information is that LONGSYS recommended another model of eMMC recommended (NCEMAD9D-16G) and I am not sure about that we need to change the MODE for this model too. I requested the same info with LONGSYS, I will share more details once I received the response.
Thanks,
Ramprasad
Any pointers to change eMMC bus speed mode?
RE: Rock64 - Stuck when do the soft reboot - by ramprasad - 06-20-2018, 04:47 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 169 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,399 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 353 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 649 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 638 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,605 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 191,929 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 612 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 668 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,011 12-07-2022, 08:22 PM
Last Post: luminosity7
