[RFC] Default resolution of 720p for all OSes
(04-11-2016, 07:10 PM)lenny.raposo Wrote: We didn't get the necessary binaries for the Mali (look at the BSP). We have everything else to make it work but the most important factor The Linux Binary for the Mali 400 was not included Sad.
Right now everything is running through the frame buffer and the only work around is using fbset through terminal.
Believe me when I say myself and others are trying to get things rolling. I think this is more of an Allwinner holding back scenario at this point and not that of the Pine Team.
Hopefully we will get more resources in the upcoming weeks.
Is it possible to use fbset through (ssh) command line to get a display to show on a monitor at least using HDMI to DVI cable?  I know that @ak_hepcat was able to get display with HDMI to DVI working by stopping the auto-boot and adding 'disp.screen0_output_mode=EDID' to the boot command.  However I'm definitely not knowledgeable enough with serial console to do this.
RE: [RFC] Default resolution of 720p for all OSes - by markolonius - 04-11-2016, 07:48 PM
  Default GPIO PIN state after boot Artyom 13 22,298 11-12-2016, 06:38 AM
Last Post: Traveler
