NextcloudPi on a Rock64
(09-05-2018, 08:51 AM)prog-amateur Wrote: Hello, this message is already in another thread but I have found this one more related to my problem (I would like to delete the same message in the other thread but couldn't as I am new to this forum and I don't have the access for it, so sorry about that) :
I have recently bought a Rock64 (2GB) and I have installed the NextcloudPi image for the Rock64 on the eMMC (via the official eMMC to USB adaptor).
I would like to plug a USB drive, but I have faced some issues (the drive is not well recognized). The main problem is that they are many partitions :
mtdblock0     31:0    0    4M  0 disk
mtdblock1     31:1    0  256K  0 disk
mmcblk0      179:0    0 14.5G  0 disk
mmcblk0p1    179:1    0 14.3G  0 part /
mmcblk0boot0 179:32   0    4M  1 disk
mmcblk0boot1 179:64   0    4M  1 disk
mmcblk0rpmb  179:96   0    4M  0 disk
There is already an issue open in github (see here : https://github.com/nextcloud/nextcloudpi/issues/614) but I just would like to know if somebody have succeed to solve such similar problem ?
It could help both Nachoparker (the NextcloudPi developer), myself, and many other Rock64 users. Thank you very much !
Hey. I recently set up Nextcloud on one of my 4GB Rock64 boards and its performing extremely well. I tried the NextcloudPi image and I was not quite happy with the performance. It could be because the image is based on an older build from ayufan (0.6.4 IIRC) or because of a combination of other things - I do not know, not an expert.
In any case, I flashed uboot to SPI and Armbian (because of a slightly higher default SOC and RAM freq) to my HDD.
Then I basically followed this tutorial and adjusted where necessary. The one thing the tutorial is missing is enabling cache - which I highly recommend you do once the installation is done. The entire setup took me 30 min flat, including port-forwarding, installing the apps I wanted, etc.,
Its now been running for 3 weeks with occasional heavy load and I've not had any issues with it. I also had no issues with installing the app to mount my NAS as a folder, using Nextcloud Talk (is that what its called ?) with family and fetching/ uploading things from my phone as well as sharing them online.
I think the NextcloudPi project is amazing, but I suggest you give this a try until the performance and other issues get sorted.
NextcloudPi on a Rock64 - by jsfrederick - 03-27-2018, 08:23 PM
RE: NextcloudPi on a Rock64 - by xalius - 03-28-2018, 02:51 AM
RE: NextcloudPi on a Rock64 - by Luke - 03-28-2018, 02:55 AM
NextcloudPi on a Rock64 - by jsfrederick - 03-28-2018, 08:31 PM
RE: NextcloudPi on a Rock64 - by tllim - 04-02-2018, 08:40 PM
RE: NextcloudPi on a Rock64 - by nachoparker - 05-10-2018, 08:53 AM
RE: NextcloudPi on a Rock64 - by tllim - 05-10-2018, 04:29 PM
RE: NextcloudPi on a Rock64 - by prog-amateur - 09-05-2018, 08:51 AM
RE: NextcloudPi on a Rock64 - by Luke - 09-05-2018, 02:46 PM
RE: NextcloudPi on a Rock64 - by tllim - 09-06-2018, 12:02 AM
RE: NextcloudPi on a Rock64 - by prog-amateur - 09-06-2018, 04:01 AM
RE: NextcloudPi on a Rock64 - by Trash_Can_Man - 09-06-2018, 02:15 PM
RE: NextcloudPi on a Rock64 - by prog-amateur - 09-07-2018, 08:03 AM
RE: NextcloudPi on a Rock64 - by Trash_Can_Man - 09-07-2018, 11:31 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 346 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,478 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,783 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,293 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 365 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,963 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,582 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,166 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 776 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 975 10-07-2022, 07:50 PM
Last Post: rookie_267
