HW Acceleration Working
Ok folks first compile DMESG (integration with longsleep kernel work)
looking good somewhat
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.102-mali (administrator@laptop) (gcc version 4.9.2 ( 4.9.2-10) ) #4 SMP PREEMPT Tue Jul 19 15:34:05 EDT 2016
[ 0.000000] CPU: AArch64 Processor [410fd034] revision 4
[ 0.000000] Machine: sun50iw1p1
[ 0.000000] cma: CMA: reserved 64 MiB at 7c000000
[ 0.000000] On node 0 totalpages: 258048
[ 0.000000] DMA zone: 3528 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 258048 pages, LIFO batch:31
[ 0.000000] script_init enter!
[ 0.000000] script buffer is NULL!
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc03af98000 s19136 r8192 d21824 u49152
[ 0.000000] pcpu-alloc: s19136 r8192 d21824 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 254520
[ 0.000000] Kernel command line: console=tty0 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr=36:c9:e3:f1:b8:05 root=/dev/mmcblk0p2 ro rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Memory: 1008MB = 1008MB total
[ 0.000000] Memory: 936544k/936544k available, 95648k reserved
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 MB)
vmemmap : 0xffffffbc00e38000 - 0xffffffbc01c00000 ( 13 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc03f000000 ( 1008 MB)
.init : 0xffffffc0009fc000 - 0xffffffc000a80ac0 ( 531 kB)
.text : 0xffffffc000080000 - 0xffffffc0009fba64 ( 9711 kB)
.data : 0xffffffc000a81000 - 0xffffffc000bdc500 ( 1390 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 7.011377] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 7.011408] pid_max: default: 32768 minimum: 301
[ 7.011512] Security Framework initialized
[ 7.011566] AppArmor: AppArmor initialized
[ 7.011611] Mount-cache hash table entries: 256
[ 7.022328] Initializing cgroup subsys memory
[ 7.022389] Initializing cgroup subsys devices
[ 7.022406] Initializing cgroup subsys freezer
[ 7.022422] Initializing cgroup subsys blkio
[ 7.022437] Initializing cgroup subsys perf_event
[ 7.022459] Initializing cgroup subsys hugetlb
[ 7.022528] ftrace: allocating 27430 entries in 108 pages
[ 7.055547] CPU0: update cpu_power 1968128
[ 7.055579] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 7.056519] virtual base = 0xffffff800000a000.
[ 7.056538] gicd_base = 0xffffff800000c000.
[ 7.056551] gicc_base = 0xffffff800000e000.
[ 7.057120] CPU1: Booted secondary processor
[ 7.057145] CPU1: update cpu_power 1968128
[ 7.059744] CPU2: Booted secondary processor
[ 7.059757] CPU2: update cpu_power 1968128
[ 7.063862] CPU3: Booted secondary processor
[ 7.063874] CPU3: update cpu_power 1968128
[ 7.063957] Brought up 4 CPUs
[ 7.064031] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 7.064634] devtmpfs: initialized
[ 7.069454] atomic64 test passed
[ 7.069471] pinctrl core: initialized pinctrl subsystem
[ 7.071998] NET: Registered protocol family 16
[ 7.072249] script_sysfs_init success
[ 7.072466] dump_class_init,806, success
[ 7.072735] vdso: 2 pages (1 code, 1 data) at base ffffffc000a89000
[ 7.072766] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 7.074025] software IO TLB [mem 0x79c00000-0x7a000000] (4MB) mapped at [ffffffc038c00000-ffffffc038ffffff]
[ 7.075078] DMA: preallocated 256 KiB pool for atomic allocations
[ 7.075226] Serial: AMBA PL011 UART driver
[ 7.075336] axp81x_board_init: axp regl_devs num = 23
[ 7.075478] pll_audio-set_default_rate=24576000 success!
[ 7.075508] pll_video0-set_default_rate=297000000 success!
[ 7.075591] pll_video1-set_default_rate=297000000 success!
[ 7.075660] pll_de-set_default_rate=297000000 success!
[ 7.076423] de-set_default_source=pll_de success!
[ 7.076439] de-set_default_rate=297000000 success!
[ 7.076496] tcon0-set_default_source=pll_mipi success!
[ 7.076543] tcon1-set_default_source=pll_video0 success!
[ 7.076785] hdmi-set_default_source=pll_video0 success!
[ 7.079013] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[ 7.079193] [sun50iw1p1_pinctrl_probe][838]
[ 7.080855] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 7.081516] sunxi hwspinlock vbase:0xffffff800005c000
[ 7.087250] sunxi_chipid_probe,150: soc bin:0
[ 7.092166] bio: create slab <bio-0> at 0
[ 7.092522] pwm module init!
[ 7.093743] SCSI subsystem initialized
[ 7.093879] usbcore: registered new interface driver usbfs
[ 7.093925] usbcore: registered new interface driver hub
[ 7.093999] usbcore: registered new device driver usb
[ 7.094780] Linux video capture interface: v2.00
[ 7.095241] [ARISC] Confusedunxi-arisc driver v1.10
[ 7.102001] [ARISC] Confusedunxi-arisc driver v1.10 startup succeeded
[ 7.102245] Advanced Linux Sound Architecture Driver Initialized.
[ 7.102607] NetLabel: Initializing
[ 7.102620] NetLabel: domain hash size = 128
[ 7.102632] NetLabel: protocols = UNLABELED CIPSOv4
[ 7.102679] NetLabel: unlabeled traffic allowed by default
[ 7.102846] [pm]aw_pm_init!
[ 7.102909] rtc physical base = 0x0000000001f00000 .
[ 7.102950] np name = /soc@01c00000/rtc@01f00000.
[ 7.102966] base = ffffff8000070100, len = 4.
[ 7.102979] pmu name: pmu0 .
[ 7.103016] pmu0_enable = 0x1.
[ 7.103028] pmux_id = 0x6.
[ 7.103040] pmux_twi_id = 0x1.
[ 7.103052] pmux_twi_addr = 0x34.
[ 7.103063] pmu name: pmu1 .
[ 7.103112] Warning: can not find np for pmu1.
[ 7.103336] add_sys_pwr_dm: get ldo name for id: vcc-lpddr failed
[ 7.103501] after inited: sys_mask config = 0x4a55.
[ 7.103533] Warning: can not find np for dynamic_standby_para.
[ 7.103653] [pm]valid
[ 7.103663] [pm]valid
[ 7.103672] Notice: sun9i&sun8iw5&sun50i not need support normal standby, change to super standby.
[ 7.103883] Switching to clocksource arch_sys_counter
[ 7.114452] AppArmor: AppArmor Filesystem Enabled
[ 7.121304] NET: Registered protocol family 2
[ 7.122037] TCP established hash table entries: 8192 (order: 5, 131072 bytes)
[ 7.122199] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 7.122361] TCP: Hash tables configured (established 8192 bind 8192)
[ 7.122442] TCP: reno registered
[ 7.122459] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 7.122498] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 7.122711] NET: Registered protocol family 1
[ 7.122989] RPC: Registered named UNIX socket transport module.
[ 7.123006] RPC: Registered udp transport module.
[ 7.123019] RPC: Registered tcp transport module.
[ 7.123033] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 7.123201] Trying to unpack rootfs image as initramfs...
[ 7.169159] Freeing initrd memory: 1072K (ffffffc035dab000 - ffffffc035eb7000)
[ 7.169698] kvm [1]: Using HYP init bounce page @79b85000
[ 7.170157] kvm [1]: interrupt-controller@1c84000 IRQ25
[ 7.170569] kvm [1]: timer IRQ27
[ 7.170592] kvm [1]: Hyp mode initialized successfully
[ 7.172401] lock super standby defaultly!
[ 7.172423] lookup_scene_lock_name: new scene lock super_standby
[ 7.172439] scene_lock_init name=super_standby
[ 7.172454] scene_lock: super_standby, type 5, count 1
[ 7.172883] audit: initializing netlink socket (disabled)
[ 7.172944] type=2000 audit(0.150:1): initialized
[ 7.173550] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 7.174034] VFS: Disk quotas dquot_6.5.2
[ 7.174152] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 7.174567] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 7.175096] NFS: Registering the id_resolver key type
[ 7.175151] Key type id_resolver registered
[ 7.175164] Key type id_legacy registered
[ 7.175184] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[ 7.175338] NTFS driver 2.1.30 [Flags: R/W].
[ 7.175507] fuse init (API version 7.22)
[ 7.175707] msgmni has been set to 1959
[ 7.176661] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 7.176766] io scheduler noop registered
[ 7.176781] io scheduler deadline registered
[ 7.176815] io scheduler cfq registered (default)
[ 7.177343] [DISP]disp_module_init
[ 7.177646] disp 1000000.disp: unable to map dsi registers
[ 7.177683] disp: probe of 1000000.disp failed with error -22
[ 7.177841] [DISP]disp_module_init finish
[ 7.178146] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[ 7.178178] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[ 8.104251] console [ttyS0] enabled
[ 8.108520] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[ 8.115330] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[ 8.122232] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[ 8.129118] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[ 8.136017] misc dump reg init
[ 8.139501] [drm] Initialized drm 1.1.0 20060810
[ 8.149004] brd: module loaded
[ 8.154697] loop: module loaded
[ 8.158395] sunxi-bt bt.27: Missing bt_power.
[ 8.163164] sunxi-bt bt.27: bt_power_name ((null))
[ 8.168417] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[ 8.174541] sunxi-bt bt.27: bt_rst gpio=356 mul-sel=1 pull=-1 drv_level=-1 data=0
[ 8.183154] sunxi-bt bt.27: clk not config
[ 8.187716] sunxi-bt bt.27: block state already is 1
[ 8.193331] sunxi-wlan wlan.26: wlan_busnum (1)
[ 8.198299] sunxi-wlan wlan.26: Missing wlan_power.
[ 8.203636] sunxi-wlan wlan.26: wlan_power_name ((null))
[ 8.209457] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[ 8.215956] sunxi-wlan wlan.26: wlan_regon gpio=354 mul-sel=1 pull=-1 drv_level=-1 data=0
[ 8.225302] sunxi-wlan wlan.26: wlan_hostwake gpio=355 mul-sel=6 pull=-1 drv_level=-1 data=0
[ 8.234939] sunxi-wlan wlan.26: clk not config
[ 8.240383] tun: Universal TUN/TAP device driver, 1.6
[ 8.245920] tun: © 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 8.253274] WARNING: Get ephy clock is failed
[ 8.258366] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 8.265635] get ehci0-controller drv_vbus_gpio is fail
[ 8.271256] get ehci0-controller, regulator_io is no nocare
[ 8.277409] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000c87e50, 0x:ffffff80000aa000, irq_no:68
[ 8.290692] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 8.300618] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[ 8.310443] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc000504ef0
[ 8.333950] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[ 8.341962] hub 1-0:1.0: USB hub found
[ 8.346085] hub 1-0:1.0: 1 port detected
[ 8.350504] scene_lock_init name=ehci_standby
[ 8.355357] get ehci1-controller drv_vbus_gpio is fail
[ 8.360978] get ehci1-controller, regulator_io is no nocare
[ 8.367121] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000c880a0, 0x:ffffff80000b2000, irq_no:6a
[ 8.380400] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 8.390326] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[ 8.400011] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc000504ef0
[ 8.422508] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[ 8.430426] hub 2-0:1.0: USB hub found
[ 8.434550] hub 2-0:1.0: 1 port detected
[ 8.438956] scene_lock_init name=ehci_standby
[ 8.443981] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 8.450874] get ohci0-controller drv_vbus_gpio is fail
[ 8.456508] get ohci0-controller, regulator_io is no nocare
[ 8.462645] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000c879b0
[ 8.472881] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 8.482422] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[ 8.491879] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc000508690
[ 8.554686] hub 3-0:1.0: USB hub found
[ 8.558794] hub 3-0:1.0: 1 port detected
[ 8.563217] scene_lock_init name=ohci_standby
[ 8.568032] get ohci1-controller drv_vbus_gpio is fail
[ 8.573668] get ohci1-controller, regulator_io is no nocare
[ 8.579792] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000c87c00
[ 8.590025] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 8.599556] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[ 8.609011] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0xffffffc000508690
[ 8.672722] hub 4-0:1.0: USB hub found
[ 8.676831] hub 4-0:1.0: 1 port detected
[ 8.681245] scene_lock_init name=ohci_standby
[ 8.686278] usbcore: registered new interface driver usb-storage
[ 8.692892] usbcore: registered new interface driver ums-alauda
[ 8.699406] usbcore: registered new interface driver ums-cypress
[ 8.705999] usbcore: registered new interface driver ums-datafab
[ 8.712601] usbcore: registered new interface driver ums_eneub6250
[ 8.719394] usbcore: registered new interface driver ums-freecom
[ 8.725985] usbcore: registered new interface driver ums-isd200
[ 8.732494] usbcore: registered new interface driver ums-jumpshot
[ 8.739190] usbcore: registered new interface driver ums-karma
[ 8.745591] usbcore: registered new interface driver ums-onetouch
[ 8.752294] usbcore: registered new interface driver ums-realtek
[ 8.758897] usbcore: registered new interface driver ums-sddr09
[ 8.765394] usbcore: registered new interface driver ums-sddr55
[ 8.771900] usbcore: registered new interface driver ums-usbat
[ 8.778425] usbcore: registered new interface driver usbserial
[ 8.784828] usbcore: registered new interface driver usbserial_generic
[ 8.791997] usbserial: USB Serial support registered for generic
[ 8.798781] mousedev: PS/2 mouse device common for all mice
[ 8.805276] input: sunxi-keyboard as /devices/virtual/input/input0
[ 8.812539] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[ 8.820003] sunxi-rtc 1f00000.rtc: RTC enabled
[ 8.825048] i2c /dev entries driver
[ 8.865856] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[ 8.879356] sunxi budget cooling probe start !
[ 8.884243] CPU freq cooling register Success
[ 8.889048] CPU hotplug cooling register Success
[ 8.894173] CPU budget cooling register Success
[ 8.899354] sunxi gpu cooling probe start !
[ 8.903932] CPU gpu cooling register Success
[ 8.911373] cpuidle: using governor ladder
[ 8.915865] cpuidle: using governor menu
[ 8.920837] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jul 19 2016 at 15:30:22
[ 8.933710] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[ 8.940383] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[ 8.947150] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[ 8.954245] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[ 8.960432] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[ 8.967108] sunxi-mmc 1c0f000.sdmmc: Got CD GPIO #166.
[ 8.972825] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 8.983789] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[ 9.003081] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.032599] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000d8000 irq:92
[ 9.039821] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jul 19 2016 at 15:30:22
[ 9.052686] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[ 9.059634] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[ 9.066686] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[ 9.073736] get() with no identifier
[ 9.077640] get() with no identifier
[ 9.081543] get() with no identifier
[ 9.085456] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[ 9.091650] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[ 9.097931] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[ 9.104555] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.115516] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[ 9.131793] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[ 9.139267] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[ 9.140824] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.157355] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.160522] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000e0000 irq:93
[ 9.161065] usbcore: registered new interface driver usbhid
[ 9.161066] usbhid: USB HID core driver
[ 9.186411] usbcore: registered new interface driver snd-usb-audio
[ 9.188333] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.190460] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 9.191271] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 9.192080] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 9.192890] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 9.193517] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 9.193557] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 9.195927] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 9.216736] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 9.218588] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 9.218628] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 9.218726] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[ 9.218746] mmc0: new high speed SDHC card at address 59b4
[ 9.314271] mmcblk0: mmc0:59b4 NCard 7.48 GiB
[ 9.319925] sndhdmi sound.7: sndhdmi <-> 1c22800.daudio mapping ok
[ 9.320145] mmcblk0: p1 p2
[ 9.330720] TCP: cubic registered
[ 9.331016] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 9.331829] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 9.331847] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.334246] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.336061] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[ 9.336867] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 9.337672] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 9.338478] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 9.339280] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 9.340085] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 9.340889] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 9.341693] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 9.342498] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 9.342511] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.343341] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[ 9.343354] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 9.458901] NET: Registered protocol family 10
[ 9.464410] sit: IPv6 over IPv4 tunneling driver
[ 9.469816] NET: Registered protocol family 17
[ 9.474721] 8021q: 802.1Q VLAN Support v1.8
[ 9.479340] Key type dns_resolver registered
[ 9.484184] Registering SWP/SWPB emulation handler
[ 9.489684] registered taskstats version 1
[ 9.495041] Key type encrypted registered
[ 9.499440] AppArmor: AppArmor sha1 policy hashing enabled
[ 9.505759] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[ 9.514327] [DISP] boot_disp:0x0
[ 9.518525] [HDMI] power vcc-hdmi-33
[ 9.522890] [HDMI] cec support = 0
[ 9.633809] sunxi-rtc 1f00000.rtc: setting system clock to 2016-07-19 20:49:53 UTC (1468961393)
[ 9.643895] input: sunxi-ths as /devices/virtual/input/input2
[ 9.650310] thermal thermal_zone0: failed to read out thermal zone 0
[ 9.657648] ALSA device list:
[ 9.660889] #0: sndhdmi
[ 9.664159] Freeing unused kernel memory: 528K (ffffffc0009fc000 - ffffffc000a80000)
[ 9.731332] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 9.740736] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 9.880788] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 10.143556] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 10.158365] systemd[1]: Detected architecture 'arm64'.
[ 10.204768] systemd[1]: Set hostname to <pine64>.
[ 10.507950] systemd[1]: Expecting device dev-ttyS0.device...
[ 10.528341] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 10.536860] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.545213] systemd[1]: Starting Remote File Systems (Pre).
[ 10.567668] systemd[1]: Reached target Remote File Systems (Pre).
[ 10.574393] systemd[1]: Starting Encrypted Volumes.
[ 10.597186] systemd[1]: Reached target Encrypted Volumes.
[ 10.603143] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 10.612023] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 10.620733] systemd[1]: Starting Paths.
[ 10.636540] systemd[1]: Reached target Paths.
[ 10.641377] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.651710] systemd[1]: Starting Swap.
[ 10.675905] systemd[1]: Reached target Swap.
[ 10.680604] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 10.705432] systemd[1]: Starting Root Slice.
[ 10.725106] systemd[1]: Created slice Root Slice.
[ 10.730277] systemd[1]: Starting User and Session Slice.
[ 10.754627] systemd[1]: Created slice User and Session Slice.
[ 10.760941] systemd[1]: Starting Delayed Shutdown Socket.
[ 10.784150] systemd[1]: Listening on Delayed Shutdown Socket.
[ 10.790465] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 10.813669] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 10.821315] systemd[1]: Starting Journal Socket (/dev/log).
[ 10.843190] systemd[1]: Listening on Journal Socket (/dev/log).
[ 10.849712] systemd[1]: Starting udev Control Socket.
[ 10.872723] systemd[1]: Listening on udev Control Socket.
[ 10.878670] systemd[1]: Starting udev Kernel Socket.
[ 10.902229] systemd[1]: Listening on udev Kernel Socket.
[ 10.908097] systemd[1]: Starting Journal Socket.
[ 10.931750] systemd[1]: Listening on Journal Socket.
[ 10.937292] systemd[1]: Starting System Slice.
[ 10.961269] systemd[1]: Created slice System Slice.
[ 10.966669] systemd[1]: Started File System Check on Root Device.
[ 10.973370] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 11.000670] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 11.007568] systemd[1]: Starting system-getty.slice.
[ 11.030153] systemd[1]: Created slice system-getty.slice.
[ 11.036087] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 11.059661] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 11.066604] systemd[1]: Starting Increase datagram queue length...
[ 11.069477] [ehci0-controller]: sunxi_usb_disable_ehci
[ 11.069483] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000c87e50
[ 11.069497] scene_lock_destroy name=ehci_standby
[ 11.069506] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[ 11.069521] usb usb1: USB disconnect, device number 1
[ 11.069967] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[ 11.069995] [ohci0-controller]: sunxi_usb_disable_ohci
[ 11.069999] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000c879b0
[ 11.070001] scene_lock_destroy name=ohci_standby
[ 11.070007] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[ 11.070019] usb usb3: USB disconnect, device number 1
[ 11.070318] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[ 11.070341] [ehci0-controller]: sunxi_usb_enable_ehci
[ 11.070346] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000c87e50, 0x:ffffff80000aa000, irq_no:68
[ 11.070382] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 11.070397] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[ 11.192282] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc039987dc0
[ 11.217067] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[ 11.218714] systemd[1]: Starting Restore / save the current clock...
[ 11.232172] hub 1-0:1.0: USB hub found
[ 11.236784] hub 1-0:1.0: 1 port detected
[ 11.243906] scene_lock_init name=ehci_standby
[ 11.249735] [ohci0-controller]: sunxi_usb_enable_ohci
[ 11.255259] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000c879b0
[ 11.265488] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 11.269257] systemd[1]: Mounting Huge Pages File System...
[ 11.281101] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[ 11.281141] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc00045eb40
[ 11.318978] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 11.339587] hub 3-0:1.0: USB hub found
[ 11.343714] hub 3-0:1.0: 1 port detected
[ 11.348321] scene_lock_init name=ohci_standby
[ 11.367203] systemd[1]: Started Set Up Additional Binary Formats.
[ 11.386802] systemd[1]: Starting Load Kernel Modules...
[ 11.415441] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.444954] systemd[1]: Starting udev Coldplug all Devices...
[ 11.474749] systemd[1]: Mounting Debug File System...
[ 11.504195] systemd[1]: Starting Slices.
[ 11.522241] systemd[1]: Reached target Slices.
[ 11.541954] systemd[1]: Mounted Debug File System.
[ 11.571494] systemd[1]: Mounted POSIX Message Queue File System.
[ 11.600972] systemd[1]: Mounted Huge Pages File System.
[ 11.630472] systemd[1]: Started Increase datagram queue length.
[ 11.660015] systemd[1]: Started Restore / save the current clock.
[ 11.689534] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 11.703574] systemd[1]: Time has been changed
[ 11.742055] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 11.770786] systemd[1]: Starting Syslog Socket.
[ 11.788138] systemd[1]: Listening on Syslog Socket.
[ 11.793709] systemd[1]: Starting Journal Service...
[ 11.837162] systemd[1]: Started Journal Service.
[ 11.934208] cfg80211: Calling CRDA to update world regulatory domain
[ 12.106509] RTL871X: module init start
[ 12.110302] systemd-udevd[171]: starting version 215
[ 12.116194] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[ 12.123639] RTL871X: build time: Jul 19 2016 15:52:07
[ 12.129160] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[ 12.137486] sunxi-wlan wlan.26: bus_index: 1
[ 12.142368] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[ 12.260843] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 12.260914] RTL871X: module init ret=0
[ 12.277430] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[ 12.299516] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 12.329818] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 12.337304] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 12.343986] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 12.359926] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 12.373644] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[ 12.380635] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 12.401640] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 12.416364] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 12.428848] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[ 12.443554] mmc1: new high speed SDIO card at address 0001
[ 12.496087] RTL871X: rtw_ndev_init(wlan0)
[ 12.501681] RTL871X: rtw_ndev_init(wlan1)
[ 12.692580] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 12.915906] sunxi cedar version 0.1
[ 12.920566] [cedar]: install start!!!
[ 12.924729] ycy the get irq is 90
[ 12.931649] ycy clk_bass_vir 0x18 is ffffff80017ee018, the value:3006207
[ 12.940068] ycy clk_bass_vir 0x13c is ffffff80017ee13c, the value:0
[ 12.947780] ycy clk_bass_vir 0x64 is ffffff80017ee064, the value:601810
[ 12.955531] ycy clk_bass_vir 0x2c4 is ffffff80017ee2c4, the value:601c10
[ 12.963901] ycy clk_bass_vir 0x100 is ffffff80017ee100, the value:0
[ 12.971905] [cedar]: install end!!!
[ 13.130119] Registered IR keymap rc_map_sunxi
[ 13.135387] input: sunxi_ir_recv as /devices/soc.0/1f02000.s_cir/rc/rc0/input3
[ 13.143549] rc0: sunxi_ir_recv as /devices/soc.0/1f02000.s_cir/rc/rc0
[ 13.306149] IR RC6 protocol handler initialized
[ 13.306152] IR RC5(x) protocol handler initialized
[ 13.327113] IR SANYO protocol handler initialized
[ 13.327115] IR JVC protocol handler initialized
[ 13.337537] IR Sony protocol handler initialized
[ 13.361686] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input4
[ 13.361919] lirc_dev: IR Remote Control driver registered, major 249
[ 13.378255] IR MCE Keyboard/mouse protocol handler initialized
[ 13.378415] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[ 13.378417] IR LIRC bridge handler initialized
[ 13.445016] IR NEC protocol handler initialized
[ 13.484084] sunxi-bt bt.27: set block: 0
[ 13.488524] sunxi-bt bt.27: check bluetooth io_regulator voltage: 1800000
[ 13.518982] [VFE]cci probe end cci_sel = 0!
[ 13.523913] [VFE]cci_init end
[ 13.819988] cfg80211: World regulatory domain updated:
[ 13.825653] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 13.834643] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 13.842737] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 13.850850] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 13.858956] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 13.867055] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 13.875703] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 13.886204] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 13.897155] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 14.048796] [VFE]Welcome to Video Front End driver
[ 14.054663] [VFE]csi probe end csi_sel = 0!
[ 14.059656] [VFE]csi_init end
[ 14.063667] [VFE]isp probe start isp_sel = 0!
[ 14.069807] [ISP] isp platform_id = 3!
[ 14.074188] [VFE]isp probe end isp_sel = 0!
[ 14.079389] [VFE]sunxi_isp_platform_register end
[ 14.085381] [VFE]mipi probe start mipi_sel = 0!
[ 14.090791] [VFE]mipi probe end mipi_sel = 0!
[ 14.095613] [VFE]mipi_init end
[ 14.100227] [VFE]flash_init end
[ 14.104516] [VFE]pdev->id = 0
[ 14.107763] [VFE]dev->vip_sel = 0
[ 14.111821] [VFE]vfe_init end
[ 14.119896] [VFE]probe_work_handle start!
[ 14.124846] [VFE]vfe_runtime_resume
[ 14.143127] [VFE]..........................vfe clk open!.......................
[ 14.151149] [VFE_WARN]vfe dphy clock is null
[ 14.155866] [VFE]V4L2 device registered as (null)
[ 14.161072] [VFE]vfe_runtime_suspend
[ 14.164987] [VFE]..........................vfe clk close!.......................
[ 14.181872] [VFE]probe_work_handle end!
[ 14.368233] sunxidrm: exports duplicate symbol dsi_dcs_rd (owned by kernel)
[ 14.589990] systemd-journald[168]: Received request to flush runtime journal from PID 1
[ 20.985007] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 26.165822] libphy: 1c30000.eth: probed
[ 26.170189] sunxi-gmac 1c30000.eth eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (1c30000.eth-0:00)
[ 30.099986] libphy: 1c30000.eth-0:00 - Link is Up - 100/Full
[ 32.399428] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 33.397930] libphy: 1c30000.eth: probed
[ 33.402296] sunxi-gmac 1c30000.eth eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (1c30000.eth-0:00)
[ 33.457593] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 34.360480] libphy: 1c30000.eth: probed
[ 34.364814] sunxi-gmac 1c30000.eth eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (1c30000.eth-0:00)
[ 34.421379] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 38.296537] libphy: 1c30000.eth-0:00 - Link is Up - 100/Full
[ 38.302831] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
A little bit more rework and it falls apart time to undo changes
[ 0.000000] Linux version 3.10.102-mali-2 (administrator@laptop) (gcc version 4.9.2 ( 4.9.2-10) ) #5 SMP PREEMPT Tue Jul 19 18:48:24 EDT 2016
[ 0.000000] Memory: 937596k/937596k available, 94596k reserved
.init : 0xffffffc0009b7000 - 0xffffffc000a39ac0 ( 523 kB)
.text : 0xffffffc000080000 - 0xffffffc0009b69e4 ( 9435 kB)
.data : 0xffffffc000a3a000 - 0xffffffc000adb900 ( 647 kB)
[ 6.956940] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 6.956971] pid_max: default: 32768 minimum: 301
[ 6.957074] Security Framework initialized
[ 6.957127] AppArmor: AppArmor initialized
[ 6.957172] Mount-cache hash table entries: 256
[ 6.967725] Initializing cgroup subsys memory
[ 6.967784] Initializing cgroup subsys devices
[ 6.967802] Initializing cgroup subsys freezer
[ 6.967818] Initializing cgroup subsys blkio
[ 6.967833] Initializing cgroup subsys perf_event
[ 6.967854] Initializing cgroup subsys hugetlb
[ 6.967924] ftrace: allocating 26490 entries in 104 pages
[ 6.999789] CPU0: update cpu_power 1968128
[ 6.999822] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 7.000765] virtual base = 0xffffff800000a000.
[ 7.000784] gicd_base = 0xffffff800000c000.
[ 7.000797] gicc_base = 0xffffff800000e000.
[ 7.001353] CPU1: Booted secondary processor
[ 7.001377] CPU1: update cpu_power 1968128
[ 7.003978] CPU2: Booted secondary processor
[ 7.003990] CPU2: update cpu_power 1968128
[ 7.008097] CPU3: Booted secondary processor
[ 7.008108] CPU3: update cpu_power 1968128
[ 7.008187] Brought up 4 CPUs
[ 7.008261] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 7.008857] devtmpfs: initialized
[ 7.013608] atomic64 test passed
[ 7.013627] pinctrl core: initialized pinctrl subsystem
[ 7.016143] NET: Registered protocol family 16
[ 7.016399] script_sysfs_init success
[ 7.016615] dump_class_init,806, success
[ 7.016881] vdso: 2 pages (1 code, 1 data) at base ffffffc000a41000
[ 7.016913] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 7.018172] software IO TLB [mem 0x79c00000-0x7a000000] (4MB) mapped at [ffffffc038c00000-ffffffc038ffffff]
[ 7.019224] DMA: preallocated 256 KiB pool for atomic allocations
[ 7.019374] Serial: AMBA PL011 UART driver
[ 7.019483] axp81x_board_init: axp regl_devs num = 23
[ 7.019624] pll_audio-set_default_rate=24576000 success!
[ 7.019653] pll_video0-set_default_rate=297000000 success!
[ 7.019735] pll_video1-set_default_rate=297000000 success!
[ 7.019801] pll_de-set_default_rate=297000000 success!
[ 7.020549] de-set_default_source=pll_de success!
[ 7.020565] de-set_default_rate=297000000 success!
[ 7.020619] tcon0-set_default_source=pll_mipi success!
[ 7.020665] tcon1-set_default_source=pll_video0 success!
[ 7.020904] hdmi-set_default_source=pll_video0 success!
[ 7.023143] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[ 7.023322] [sun50iw1p1_pinctrl_probe][838]
[ 7.024984] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 7.025636] sunxi hwspinlock vbase:0xffffff800005c000
[ 7.031306] sunxi_chipid_probe,150: soc bin:0
[ 7.036163] bio: create slab <bio-0> at 0
[ 7.036519] pwm module init!
[ 7.037726] SCSI subsystem initialized
[ 7.037860] usbcore: registered new interface driver usbfs
[ 7.037905] usbcore: registered new interface driver hub
[ 7.037979] usbcore: registered new device driver usb
[ 7.038746] Linux video capture interface: v2.00
[ 7.039199] [ARISC] Confusedunxi-arisc driver v1.10
[ 7.045925] [ARISC] Confusedunxi-arisc driver v1.10 startup succeeded
[ 7.046167] Advanced Linux Sound Architecture Driver Initialized.
[ 7.046522] NetLabel: Initializing
[ 7.046536] NetLabel: domain hash size = 128
[ 7.046548] NetLabel: protocols = UNLABELED CIPSOv4
[ 7.046596] NetLabel: unlabeled traffic allowed by default
[ 7.046762] [pm]aw_pm_init!
[ 7.046825] rtc physical base = 0x0000000001f00000 .
[ 7.046867] np name = /soc@01c00000/rtc@01f00000.
[ 7.046883] base = ffffff8000070100, len = 4.
[ 7.046896] pmu name: pmu0 .
[ 7.046933] pmu0_enable = 0x1.
[ 7.046945] pmux_id = 0x6.
[ 7.046957] pmux_twi_id = 0x1.
[ 7.046969] pmux_twi_addr = 0x34.
[ 7.046980] pmu name: pmu1 .
[ 7.047031] Warning: can not find np for pmu1.
[ 7.047254] add_sys_pwr_dm: get ldo name for id: vcc-lpddr failed
[ 7.047418] after inited: sys_mask config = 0x4a55.
[ 7.047448] Warning: can not find np for dynamic_standby_para.
[ 7.047581] [pm]valid
[ 7.047591] [pm]valid
[ 7.047600] Notice: sun9i&sun8iw5&sun50i not need support normal standby, change to super standby.
[ 7.047812] Switching to clocksource arch_sys_counter
[ 7.058377] AppArmor: AppArmor Filesystem Enabled
[ 7.065177] NET: Registered protocol family 2
[ 7.065910] TCP established hash table entries: 8192 (order: 5, 131072 bytes)
[ 7.066068] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 7.066243] TCP: Hash tables configured (established 8192 bind 8192)
[ 7.066326] TCP: reno registered
[ 7.066342] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 7.066381] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 7.066593] NET: Registered protocol family 1
[ 7.066880] RPC: Registered named UNIX socket transport module.
[ 7.066898] RPC: Registered udp transport module.
[ 7.066911] RPC: Registered tcp transport module.
[ 7.066924] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 7.067092] Trying to unpack rootfs image as initramfs...
[ 7.113057] Freeing initrd memory: 1072K (ffffffc035dab000 - ffffffc035eb7000)
[ 7.113594] kvm [1]: Using HYP init bounce page @79b81000
[ 7.114066] kvm [1]: interrupt-controller@1c84000 IRQ25
[ 7.114480] kvm [1]: timer IRQ27
[ 7.114504] kvm [1]: Hyp mode initialized successfully
[ 7.116311] lock super standby defaultly!
[ 7.116332] lookup_scene_lock_name: new scene lock super_standby
[ 7.116348] scene_lock_init name=super_standby
[ 7.116363] scene_lock: super_standby, type 5, count 1
[ 7.116786] audit: initializing netlink socket (disabled)
[ 7.116848] type=2000 audit(0.150:1): initialized
[ 7.117459] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 7.117940] VFS: Disk quotas dquot_6.5.2
[ 7.118057] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 7.118472] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 7.119002] NFS: Registering the id_resolver key type
[ 7.119057] Key type id_resolver registered
[ 7.119071] Key type id_legacy registered
[ 7.119091] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[ 7.119243] NTFS driver 2.1.30 [Flags: R/W].
[ 7.119414] fuse init (API version 7.22)
[ 7.119612] msgmni has been set to 1961
[ 7.120569] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 7.120674] io scheduler noop registered
[ 7.120689] io scheduler deadline registered
[ 7.120723] io scheduler cfq registered (default)
[ 7.121575] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[ 7.121606] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[ 8.027497] console [ttyS0] enabled
[ 8.031753] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[ 8.038567] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[ 8.045459] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[ 8.052347] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[ 8.059252] misc dump reg init
[ 8.062744] [drm] Initialized drm 1.1.0 20060810
[ 8.072194] brd: module loaded
[ 8.077851] loop: module loaded
[ 8.081547] sunxi-bt bt.27: Missing bt_power.
[ 8.086314] sunxi-bt bt.27: bt_power_name ((null))
[ 8.091567] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[ 8.097692] sunxi-bt bt.27: bt_rst gpio=356 mul-sel=1 pull=-1 drv_level=-1 data=0
[ 8.106305] sunxi-bt bt.27: clk not config
[ 8.110858] sunxi-bt bt.27: block state already is 1
[ 8.116470] sunxi-wlan wlan.26: wlan_busnum (1)
[ 8.121438] sunxi-wlan wlan.26: Missing wlan_power.
[ 8.126774] sunxi-wlan wlan.26: wlan_power_name ((null))
[ 8.132595] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[ 8.139084] sunxi-wlan wlan.26: wlan_regon gpio=354 mul-sel=1 pull=-1 drv_level=-1 data=0
[ 8.148440] sunxi-wlan wlan.26: wlan_hostwake gpio=355 mul-sel=6 pull=-1 drv_level=-1 data=0
[ 8.158077] sunxi-wlan wlan.26: clk not config
[ 8.163527] tun: Universal TUN/TAP device driver, 1.6
[ 8.169052] tun: © 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 8.176412] WARNING: Get ephy clock is failed
[ 8.181498] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 8.188741] get ehci0-controller drv_vbus_gpio is fail
[ 8.194381] get ehci0-controller, regulator_io is no nocare
[ 8.200533] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000b80c90, 0x:ffffff800007a000, irq_no:68
[ 8.213815] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 8.223742] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[ 8.233572] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0004cdff8
[ 8.258202] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[ 8.266236] hub 1-0:1.0: USB hub found
[ 8.270361] hub 1-0:1.0: 1 port detected
[ 8.274780] scene_lock_init name=ehci_standby
[ 8.279639] get ehci1-controller drv_vbus_gpio is fail
[ 8.285259] get ehci1-controller, regulator_io is no nocare
[ 8.291406] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000b80ee0, 0x:ffffff80000aa000, irq_no:6a
[ 8.304685] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 8.314611] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[ 8.324293] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc0004cdff8
[ 8.346756] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[ 8.354687] hub 2-0:1.0: USB hub found
[ 8.358809] hub 2-0:1.0: 1 port detected
[ 8.363216] scene_lock_init name=ehci_standby
[ 8.369083] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 8.375978] get ohci0-controller drv_vbus_gpio is fail
[ 8.381612] get ohci0-controller, regulator_io is no nocare
[ 8.387750] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000b807f0
[ 8.397988] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 8.407529] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[ 8.416985] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0004d1798
[ 8.478926] hub 3-0:1.0: USB hub found
[ 8.483035] hub 3-0:1.0: 1 port detected
[ 8.487451] scene_lock_init name=ohci_standby
[ 8.492268] get ohci1-controller drv_vbus_gpio is fail
[ 8.497904] get ohci1-controller, regulator_io is no nocare
[ 8.504029] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000b80a40
[ 8.514265] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 8.523796] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[ 8.533254] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0xffffffc0004d1798
[ 8.596983] hub 4-0:1.0: USB hub found
[ 8.601090] hub 4-0:1.0: 1 port detected
[ 8.605498] scene_lock_init name=ohci_standby
[ 8.610531] usbcore: registered new interface driver usb-storage
[ 8.617145] usbcore: registered new interface driver ums-alauda
[ 8.623656] usbcore: registered new interface driver ums-cypress
[ 8.630252] usbcore: registered new interface driver ums-datafab
[ 8.636858] usbcore: registered new interface driver ums_eneub6250
[ 8.643650] usbcore: registered new interface driver ums-freecom
[ 8.650242] usbcore: registered new interface driver ums-isd200
[ 8.656747] usbcore: registered new interface driver ums-jumpshot
[ 8.663444] usbcore: registered new interface driver ums-karma
[ 8.669845] usbcore: registered new interface driver ums-onetouch
[ 8.676548] usbcore: registered new interface driver ums-realtek
[ 8.683154] usbcore: registered new interface driver ums-sddr09
[ 8.689652] usbcore: registered new interface driver ums-sddr55
[ 8.696158] usbcore: registered new interface driver ums-usbat
[ 8.702667] usbcore: registered new interface driver usbserial
[ 8.709070] usbcore: registered new interface driver usbserial_generic
[ 8.716239] usbserial: USB Serial support registered for generic
[ 8.723011] mousedev: PS/2 mouse device common for all mice
[ 8.729509] input: sunxi-keyboard as /devices/virtual/input/input0
[ 8.736752] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[ 8.744209] sunxi-rtc 1f00000.rtc: RTC enabled
[ 8.749253] i2c /dev entries driver
[ 8.790103] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[ 8.803584] sunxi budget cooling probe start !
[ 8.808468] CPU freq cooling register Success
[ 8.813272] CPU hotplug cooling register Success
[ 8.818397] CPU budget cooling register Success
[ 8.823569] sunxi gpu cooling probe start !
[ 8.828148] CPU gpu cooling register Success
[ 8.835587] cpuidle: using governor ladder
[ 8.840077] cpuidle: using governor menu
[ 8.845049] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jul 19 2016 at 18:44:41
[ 8.857922] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[ 8.864596] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[ 8.871363] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[ 8.878457] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[ 8.884644] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[ 8.891338] sunxi-mmc 1c0f000.sdmmc: Got CD GPIO #166.
[ 8.897036] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 8.908003] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[ 8.927316] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 8.956860] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000be000 irq:92
[ 8.964083] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jul 19 2016 at 18:44:41
[ 8.976949] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[ 8.983897] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[ 8.990948] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[ 8.997996] get() with no identifier
[ 9.001900] get() with no identifier
[ 9.005803] get() with no identifier
[ 9.009716] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[ 9.015909] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[ 9.022191] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[ 9.028810] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.039774] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[ 9.056042] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[ 9.063516] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[ 9.065073] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.081604] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.084771] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000d6000 irq:93
[ 9.085316] usbcore: registered new interface driver usbhid
[ 9.085317] usbhid: USB HID core driver
[ 9.110659] usbcore: registered new interface driver snd-usb-audio
[ 9.112580] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.114705] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 9.115516] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 9.116325] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 9.117134] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 9.117761] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 9.117802] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 9.120172] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 9.140986] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 9.142838] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 9.142878] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 9.142974] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[ 9.142993] mmc0: new high speed SDHC card at address 59b4
[ 9.238510] mmcblk0: mmc0:59b4 NCard 7.48 GiB
[ 9.244135] sndhdmi sound.7: sndhdmi <-> 1c22800.daudio mapping ok
[ 9.244373] mmcblk0: p1 p2
[ 9.254942] TCP: cubic registered
[ 9.255279] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 9.256089] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 9.256107] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.258506] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.260321] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[ 9.261128] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 9.261932] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 9.262739] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 9.263543] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 9.264350] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 9.265154] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 9.265959] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 9.266763] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 9.266777] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.267606] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[ 9.267620] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 9.383128] NET: Registered protocol family 10
[ 9.388637] sit: IPv6 over IPv4 tunneling driver
[ 9.394040] NET: Registered protocol family 17
[ 9.398947] 8021q: 802.1Q VLAN Support v1.8
[ 9.403570] Key type dns_resolver registered
[ 9.408413] Registering SWP/SWPB emulation handler
[ 9.413927] registered taskstats version 1
[ 9.419269] Key type encrypted registered
[ 9.423668] AppArmor: AppArmor sha1 policy hashing enabled
[ 9.430501] sunxi-rtc 1f00000.rtc: setting system clock to 2016-07-19 23:53:07 UTC (1468972387)
[ 9.440699] input: sunxi-ths as /devices/virtual/input/input2
[ 9.447119] thermal thermal_zone0: failed to read out thermal zone 0
[ 9.454439] ALSA device list:
[ 9.457680] #0: sndhdmi
[ 9.460966] Freeing unused kernel memory: 520K (ffffffc0009b7000 - ffffffc000a39000)
[ 9.528203] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 9.537606] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 9.661734] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 9.933213] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 9.947979] systemd[1]: Detected architecture 'arm64'.
[ 9.991297] systemd[1]: Set hostname to <pine64>.
[ 10.297748] systemd[1]: Expecting device dev-ttyS0.device...
[ 10.324665] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 10.333184] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.341558] systemd[1]: Starting Remote File Systems (Pre).
[ 10.363993] systemd[1]: Reached target Remote File Systems (Pre).
[ 10.370718] systemd[1]: Starting Encrypted Volumes.
[ 10.393509] systemd[1]: Reached target Encrypted Volumes.
[ 10.399464] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 10.408354] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 10.417051] systemd[1]: Starting Paths.
[ 10.432880] systemd[1]: Reached target Paths.
[ 10.437719] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.448040] systemd[1]: Starting Swap.
[ 10.472230] systemd[1]: Reached target Swap.
[ 10.476931] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 10.501760] systemd[1]: Starting Root Slice.
[ 10.521436] systemd[1]: Created slice Root Slice.
[ 10.526607] systemd[1]: Starting User and Session Slice.
[ 10.550956] systemd[1]: Created slice User and Session Slice.
[ 10.557269] systemd[1]: Starting Delayed Shutdown Socket.
[ 10.580479] systemd[1]: Listening on Delayed Shutdown Socket.
[ 10.586792] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 10.609997] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 10.617643] systemd[1]: Starting Journal Socket (/dev/log).
[ 10.639519] systemd[1]: Listening on Journal Socket (/dev/log).
[ 10.646041] systemd[1]: Starting udev Control Socket.
[ 10.669038] systemd[1]: Listening on udev Control Socket.
[ 10.674982] systemd[1]: Starting udev Kernel Socket.
[ 10.698560] systemd[1]: Listening on udev Kernel Socket.
[ 10.704428] systemd[1]: Starting Journal Socket.
[ 10.728078] systemd[1]: Listening on Journal Socket.
[ 10.733620] systemd[1]: Starting System Slice.
[ 10.757599] systemd[1]: Created slice System Slice.
[ 10.763001] systemd[1]: Started File System Check on Root Device.
[ 10.769702] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 10.796969] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 10.803861] systemd[1]: Starting system-getty.slice.
[ 10.826477] systemd[1]: Created slice system-getty.slice.
[ 10.832408] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 10.855996] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 10.862933] systemd[1]: Starting Increase datagram queue length...
[ 10.887011] systemd[1]: Starting Restore / save the current clock...
[ 10.921596] systemd[1]: Mounting Huge Pages File System...
[ 10.985740] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 11.013435] [ehci0-controller]: sunxi_usb_disable_ehci
[ 11.019074] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000b80c90
[ 11.029431] scene_lock_destroy name=ehci_standby
[ 11.032107] systemd[1]: Started Set Up Additional Binary Formats.
[ 11.041239] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[ 11.047887] usb usb1: USB disconnect, device number 1
[ 11.050469] systemd[1]: Starting Load Kernel Modules...
[ 11.059602] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[ 11.067337] [ohci0-controller]: sunxi_usb_disable_ohci
[ 11.075629] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000b807f0
[ 11.077222] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.092905] scene_lock_destroy name=ohci_standby
[ 11.097960] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[ 11.104555] usb usb3: USB disconnect, device number 1
[ 11.110499] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[ 11.118154] [ehci0-controller]: sunxi_usb_enable_ehci
[ 11.126351] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000b80c90, 0x:ffffff800007a000, irq_no:68
[ 11.140754] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 11.150704] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[ 11.162058] systemd[1]: Starting udev Coldplug all Devices...
[ 11.175678] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc000427c48
[ 11.192434] systemd[1]: Mounting Debug File System...
[ 11.200393] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[ 11.209828] hub 1-0:1.0: USB hub found
[ 11.213958] hub 1-0:1.0: 1 port detected
[ 11.218398] scene_lock_init name=ehci_standby
[ 11.223202] [ohci0-controller]: sunxi_usb_enable_ohci
[ 11.225089] systemd[1]: Starting Slices.
[ 11.233125] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000b807f0
[ 11.243369] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 11.252955] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[ 11.262426] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc039983d50
[ 11.289077] systemd[1]: Reached target Slices.
[ 11.308727] systemd[1]: Mounted Debug File System.
[ 11.328413] systemd[1]: Mounted POSIX Message Queue File System.
[ 11.332697] hub 3-0:1.0: USB hub found
[ 11.332710] hub 3-0:1.0: 1 port detected
[ 11.332841] scene_lock_init name=ohci_standby
[ 11.367837] systemd[1]: Mounted Huge Pages File System.
[ 11.397319] systemd[1]: Started Increase datagram queue length.
[ 11.426808] systemd[1]: Started Restore / save the current clock.
[ 11.456325] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 11.503316] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 11.527700] systemd[1]: Starting Syslog Socket.
[ 11.544896] systemd[1]: Listening on Syslog Socket.
[ 11.550455] systemd[1]: Starting Journal Service...
[ 11.594133] systemd[1]: Started Journal Service.
[ 11.609764] cfg80211: Calling CRDA to update world regulatory domain
[ 11.776312] RTL871X: module init start
[ 11.780426] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[ 11.787935] RTL871X: build time
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
HW Acceleration Working - by Luke - 04-06-2016, 07:29 PM
RE: Help with HW Acceleration - by tllim - 04-07-2016, 11:12 AM
RE: Help with HW Acceleration - by rdPine64 - 04-13-2016, 11:22 AM
RE: Help with HW Acceleration - by longsleep - 04-14-2016, 11:00 AM
RE: Help with HW Acceleration - by rdPine64 - 04-23-2016, 01:16 PM
RE: Help with HW Acceleration - by moondark - 04-19-2016, 11:58 PM
RE: Help with HW Acceleration - by moondark - 04-20-2016, 03:23 AM
RE: Help with HW Acceleration - by moondark - 04-20-2016, 04:49 AM
RE: Help with HW Acceleration - by longsleep - 04-20-2016, 05:06 AM
RE: Help with HW Acceleration - by moondark - 04-20-2016, 05:49 AM
RE: Help with HW Acceleration - by longsleep - 04-20-2016, 01:59 PM
RE: Help with HW Acceleration - by moondark - 04-20-2016, 04:08 PM
RE: Help with HW Acceleration - by longsleep - 04-21-2016, 01:37 PM
RE: Help with HW Acceleration - by moondark - 04-22-2016, 02:10 PM
RE: Help with HW Acceleration - by Luke - 04-22-2016, 10:08 AM
RE: Help with HW Acceleration - by rahlquist - 04-22-2016, 12:26 PM
RE: Help with HW Acceleration - by sirhcjw - 04-26-2016, 07:50 AM
RE: Help with HW Acceleration - by baryluk - 04-26-2016, 02:43 PM
RE: Help with HW Acceleration - by Luke - 04-27-2016, 07:55 AM
RE: Help with HW Acceleration - by fishmech - 05-06-2016, 02:01 PM
RE: Help with HW Acceleration - by CaptainZalo - 05-31-2016, 12:57 PM
RE: Help with HW Acceleration - by tllim - 05-31-2016, 05:26 PM
RE: Help with HW Acceleration - by Luke - 05-31-2016, 05:57 PM
RE: Help with HW Acceleration - by CybeX - 06-01-2016, 08:47 AM
RE: Help with HW Acceleration - by Metalazzo - 06-06-2016, 10:16 AM
RE: Help with HW Acceleration - by tllim - 06-06-2016, 06:31 PM
RE: Help with HW Acceleration - by CybeX - 06-10-2016, 12:08 PM
RE: Help with HW Acceleration - by CaptainZalo - 06-13-2016, 12:50 PM
RE: Help with HW Acceleration - by tllim - 06-14-2016, 11:45 AM
RE: Help with HW Acceleration - by pietrondo - 06-06-2016, 05:51 PM
RE: Help with HW Acceleration - by Metalazzo - 06-07-2016, 03:22 AM
RE: Help with HW Acceleration - by BringItOn - 06-11-2016, 04:28 AM
RE: Help with HW Acceleration - by fneves - 06-14-2016, 04:55 AM
RE: Help with HW Acceleration - by pietrondo - 06-14-2016, 09:32 AM
RE: Help with HW Acceleration - by Luke - 06-14-2016, 12:22 PM
RE: Help with HW Acceleration - by CaptainZalo - 06-16-2016, 11:41 AM
RE: Help with HW Acceleration - by tllim - 06-16-2016, 12:30 PM
RE: Help with HW Acceleration - by tllim - 06-17-2016, 10:31 AM
RE: Help with HW Acceleration - by ViperVi - 06-17-2016, 11:40 AM
RE: Help with HW Acceleration - by tllim - 06-17-2016, 05:08 PM
RE: Help with HW Acceleration - by ViperVi - 06-17-2016, 06:37 PM
RE: Help with HW Acceleration - by Ghost - 06-20-2016, 04:00 AM
RE: Help with HW Acceleration - by CaptainZalo - 06-20-2016, 11:05 PM
RE: Help with HW Acceleration - by tllim - 06-21-2016, 03:54 PM
RE: Help with HW Acceleration - by tllim - 06-23-2016, 07:50 AM
RE: Help with HW Acceleration - by jl_678 - 06-23-2016, 07:58 AM
RE: Help with HW Acceleration - by Luke - 06-23-2016, 08:57 AM
RE: Help with HW Acceleration - by jl_678 - 06-23-2016, 01:23 PM
RE: Help with HW Acceleration - by Monochrome - 06-23-2016, 01:49 PM
RE: Help with HW Acceleration - by extr - 06-23-2016, 02:13 PM
RE: Help with HW Acceleration - by xalius - 06-23-2016, 02:56 PM
RE: Help with HW Acceleration - by ssvb - 06-23-2016, 03:03 PM
RE: Help with HW Acceleration - by barawn - 07-02-2016, 10:33 AM
RE: Help with HW Acceleration - by xalius - 06-24-2016, 11:45 AM
RE: Help with HW Acceleration - by Sak3r - 06-24-2016, 10:54 AM
RE: Help with HW Acceleration - by ssvb - 06-24-2016, 11:58 AM
RE: Help with HW Acceleration - by Xabaras76 - 06-24-2016, 04:48 PM
RE: Help with HW Acceleration - by ssvb - 06-25-2016, 02:58 PM
RE: Help with HW Acceleration - by longsleep - 06-25-2016, 03:40 PM
RE: Help with HW Acceleration - by tllim - 06-26-2016, 06:57 PM
RE: Help with HW Acceleration - by nagmier - 06-27-2016, 09:25 AM
RE: Help with HW Acceleration - by ssvb - 06-25-2016, 05:30 PM
RE: Help with HW Acceleration - by jrullan - 06-25-2016, 07:09 PM
RE: Help with HW Acceleration - by CaptainZalo - 06-27-2016, 03:13 PM
RE: Help with HW Acceleration - by nagmier - 06-28-2016, 05:50 AM
RE: Help with HW Acceleration - by CaptainZalo - 06-28-2016, 07:21 AM
RE: Help with HW Acceleration - by CaptainZalo - 07-01-2016, 02:24 AM
RE: Help with HW Acceleration - by tllim - 07-02-2016, 09:50 PM
RE: Help with HW Acceleration - by nagmier - 07-14-2016, 06:59 PM
RE: Help with HW Acceleration - by tllim - 07-16-2016, 07:35 PM
RE: Help with HW Acceleration - by nagmier - 07-17-2016, 07:41 AM
RE: Help with HW Acceleration - by longsleep - 07-03-2016, 09:19 AM
RE: Help with HW Acceleration - by longsleep - 07-06-2016, 11:09 PM
RE: Help with HW Acceleration - by janeku - 07-06-2016, 03:42 PM
RE: Help with HW Acceleration - by janeku - 07-07-2016, 09:19 AM
RE: Help with HW Acceleration - by longsleep - 07-07-2016, 10:17 AM
RE: Help with HW Acceleration - by Bart333 - 07-11-2016, 10:41 AM
RE: Help with HW Acceleration - by Luke - 07-11-2016, 10:59 AM
RE: Help with HW Acceleration - by jrullan - 07-11-2016, 08:42 PM
RE: Help with HW Acceleration - by CaptainZalo - 07-16-2016, 06:44 AM
RE: Help with HW Acceleration - by Boring - 07-17-2016, 03:42 AM
RE: Help with HW Acceleration - by lenny.raposo-pine64.pro - 07-19-2016, 06:09 PM
RE: Help with HW Acceleration - by adamw - 07-19-2016, 08:06 PM
RE: Help with HW Acceleration - by CaptainZalo - 07-20-2016, 03:49 AM
RE: Help with HW Acceleration - by vinodmenon80 - 07-20-2016, 04:04 AM
RE: Help with HW Acceleration - by nugu53 - 07-27-2016, 01:54 AM
RE: Help with HW Acceleration - by Monochrome - 07-29-2016, 10:18 AM
RE: Help with HW Acceleration - by adamw - 07-29-2016, 10:29 AM
RE: Help with HW Acceleration - by jl_678 - 07-29-2016, 11:17 AM
RE: Help with HW Acceleration - by jrullan - 07-29-2016, 04:16 PM
RE: Help with HW Acceleration - by jkmooney - 07-29-2016, 02:40 PM
RE: Help with HW Acceleration - by fire219 - 07-29-2016, 09:18 PM
RE: Help with HW Acceleration - by nagmier - 07-30-2016, 10:27 AM
RE: Help with HW Acceleration - by tllim - 07-30-2016, 06:23 PM
HW Acceleration Working - by Monochrome - 07-30-2016, 01:03 AM
RE: HW Acceleration Working - by Er0l - 07-30-2016, 01:27 AM
RE: HW Acceleration Working - by DefinitelyNotLA - 07-30-2016, 02:20 AM
RE: HW Acceleration Working - by ssvb - 07-30-2016, 02:41 AM
RE: HW Acceleration Working - by Luke - 07-30-2016, 07:15 AM
RE: HW Acceleration Working - by longsleep - 07-30-2016, 07:33 AM
RE: HW Acceleration Working - by Xabaras76 - 07-30-2016, 09:20 AM
RE: HW Acceleration Working - by Zoidiano0 - 07-30-2016, 09:55 AM
RE: HW Acceleration Working - by Vidiot - 07-30-2016, 02:50 PM
RE: HW Acceleration Working - by Terra854 - 07-30-2016, 11:28 PM
RE: HW Acceleration Working - by Monochrome - 07-31-2016, 03:54 AM
RE: HW Acceleration Working - by longsleep - 07-31-2016, 01:54 PM
RE: HW Acceleration Working - by Monochrome - 07-31-2016, 02:13 PM
RE: HW Acceleration Working - by longsleep - 07-31-2016, 02:17 PM
RE: HW Acceleration Working - by Monochrome - 07-31-2016, 02:18 PM
RE: HW Acceleration Working - by longsleep - 07-31-2016, 02:19 PM
HW Acceleration Working - by Monochrome - 07-31-2016, 02:41 PM
RE: HW Acceleration Working - by longsleep - 07-31-2016, 03:43 PM
RE: HW Acceleration Working - by xalius - 07-31-2016, 03:57 PM
HW Acceleration Working - by Monochrome - 07-31-2016, 10:35 PM
RE: HW Acceleration Working - by Monochrome - 08-01-2016, 09:53 AM
RE: HW Acceleration Working - by longsleep - 08-01-2016, 10:29 AM
RE: HW Acceleration Working - by xalius - 08-01-2016, 11:40 AM
RE: HW Acceleration Working - by Monochrome - 08-01-2016, 11:54 AM
RE: HW Acceleration Working - by longsleep - 08-01-2016, 12:46 PM
RE: HW Acceleration Working - by Monochrome - 08-01-2016, 01:21 PM
RE: HW Acceleration Working - by longsleep - 08-01-2016, 03:06 PM
RE: HW Acceleration Working - by Monochrome - 08-02-2016, 01:46 PM
RE: HW Acceleration Working - by rallar8 - 08-02-2016, 12:07 PM
RE: HW Acceleration Working - by HorreC - 08-03-2016, 12:30 PM
RE: HW Acceleration Working - by rallar8 - 08-03-2016, 03:26 PM
RE: HW Acceleration Working - by HorreC - 08-03-2016, 04:06 PM
RE: HW Acceleration Working - by kflorek46 - 08-03-2016, 11:25 PM
RE: HW Acceleration Working - by HorreC - 08-04-2016, 09:53 AM
RE: HW Acceleration Working - by jodybrown99 - 08-04-2016, 02:19 PM
RE: HW Acceleration Working - by piner64 - 08-08-2016, 02:04 AM
RE: HW Acceleration Working - by Monochrome - 08-08-2016, 04:05 AM
RE: HW Acceleration Working - by shadowheart - 08-11-2016, 04:52 AM
RE: HW Acceleration Working - by Monochrome - 08-11-2016, 06:38 AM
RE: HW Acceleration Working - by xalius - 08-11-2016, 06:50 AM
RE: HW Acceleration Working - by dkryder - 08-12-2016, 02:43 AM
RE: HW Acceleration Working - by xalius - 08-12-2016, 02:48 AM
RE: HW Acceleration Working - by dkryder - 08-12-2016, 03:22 AM
RE: HW Acceleration Working - by jrullan - 08-17-2016, 06:32 PM
RE: HW Acceleration Working - by protonic - 08-19-2016, 05:23 AM
RE: HW Acceleration Working - by rcgalvao - 08-23-2016, 06:59 PM
RE: HW Acceleration Working - by pietrondo - 08-25-2016, 06:12 AM
RE: HW Acceleration Working - by jkmooney - 08-25-2016, 06:05 AM
RE: HW Acceleration Working - by nagmier - 08-25-2016, 12:39 PM
RE: HW Acceleration Working - by pietrondo - 08-25-2016, 02:33 PM
RE: HW Acceleration Working - by jrullan - 08-25-2016, 09:13 PM
RE: HW Acceleration Working - by nagmier - 08-25-2016, 07:06 PM
RE: HW Acceleration Working - by pfeerick - 08-25-2016, 11:29 PM
RE: HW Acceleration Working - by dkryder - 08-26-2016, 04:18 AM
RE: HW Acceleration Working - by jrullan - 08-26-2016, 07:36 AM
RE: HW Acceleration Working - by Monochrome - 08-26-2016, 09:36 AM
RE: HW Acceleration Working - by joe - 08-26-2016, 09:55 AM
RE: HW Acceleration Working - by pfeerick - 08-26-2016, 11:58 PM
RE: HW Acceleration Working - by Terra854 - 08-29-2016, 09:39 AM
RE: HW Acceleration Working - by jrullan - 08-29-2016, 09:17 PM
RE: HW Acceleration Working - by jrullan - 08-29-2016, 02:47 PM
HW Acceleration Working - by Monochrome - 08-29-2016, 03:03 PM
RE: HW Acceleration Working - by jrullan - 08-29-2016, 03:17 PM
RE: HW Acceleration Working - by CaptainZalo - 08-29-2016, 10:45 PM
RE: HW Acceleration Working - by longsleep - 08-29-2016, 11:41 PM
RE: HW Acceleration Working - by CaptainZalo - 08-30-2016, 01:37 AM
RE: HW Acceleration Working - by CaptainZalo - 08-30-2016, 02:03 AM
RE: HW Acceleration Working - by pfeerick - 08-30-2016, 02:13 AM
RE: HW Acceleration Working - by pfeerick - 08-30-2016, 02:50 AM
RE: HW Acceleration Working - by pfeerick - 08-30-2016, 03:10 AM
RE: HW Acceleration Working - by pfeerick - 08-30-2016, 03:50 AM
RE: HW Acceleration Working - by jrullan - 08-30-2016, 04:47 AM
RE: HW Acceleration Working - by jrullan - 08-30-2016, 06:20 AM
RE: HW Acceleration Working - by longsleep - 08-30-2016, 10:43 AM
RE: HW Acceleration Working - by pfeerick - 08-30-2016, 03:44 PM
RE: HW Acceleration Working - by jrullan - 08-30-2016, 12:33 PM
RE: HW Acceleration Working - by adamw - 08-30-2016, 02:53 PM
RE: HW Acceleration Working - by pietrondo - 08-30-2016, 03:14 PM
RE: HW Acceleration Working - by longsleep - 08-30-2016, 05:13 PM
RE: HW Acceleration Working - by jrullan - 08-30-2016, 06:47 PM
RE: HW Acceleration Working - by tkaiser - 08-30-2016, 11:24 PM
RE: HW Acceleration Working - by tkaiser - 08-31-2016, 03:23 AM
RE: HW Acceleration Working - by tkaiser - 08-31-2016, 07:22 AM
RE: HW Acceleration Working - by adamw - 08-31-2016, 08:54 AM
RE: HW Acceleration Working - by tkaiser - 08-31-2016, 09:14 AM
RE: HW Acceleration Working - by jrullan - 08-31-2016, 02:57 PM
RE: HW Acceleration Working - by tkaiser - 08-31-2016, 03:18 PM
RE: HW Acceleration Working - by jkmooney - 08-31-2016, 04:00 PM
RE: HW Acceleration Working - by jrullan - 08-31-2016, 04:37 PM
RE: HW Acceleration Working - by jrullan - 08-31-2016, 05:20 PM
RE: HW Acceleration Working - by ssvb - 08-31-2016, 05:54 PM
RE: HW Acceleration Working - by jrullan - 08-31-2016, 06:36 PM
RE: HW Acceleration Working - by Pander - 09-04-2016, 07:09 AM
RE: HW Acceleration Working - by Ghelorn - 09-04-2016, 03:52 PM
RE: HW Acceleration Working - by psychedup - 09-06-2016, 05:12 PM
RE: HW Acceleration Working - by Pander - 09-07-2016, 07:00 AM
RE: HW Acceleration Working - by pietrondo - 09-10-2016, 05:33 AM
RE: HW Acceleration Working - by pfeerick - 09-10-2016, 11:36 PM
RE: HW Acceleration Working - by Luke - 09-11-2016, 03:13 PM
RE: HW Acceleration Working - by Zoidiano0 - 09-10-2016, 07:08 AM
RE: HW Acceleration Working - by dkryder - 09-10-2016, 08:31 PM
RE: HW Acceleration Working - by HayseedGeek - 09-10-2016, 10:40 PM
RE: HW Acceleration Working - by FlameCRO - 09-11-2016, 08:01 AM
RE: HW Acceleration Working - by tampadave - 10-04-2016, 04:16 PM
RE: HW Acceleration Working - by pfeerick - 10-04-2016, 07:14 PM
RE: HW Acceleration Working - by dkryder - 10-04-2016, 08:30 PM
RE: HW Acceleration Working - by HayseedGeek - 10-05-2016, 07:09 AM
RE: HW Acceleration Working - by ssvb - 10-05-2016, 07:28 AM
RE: HW Acceleration Working - by pfeerick - 10-05-2016, 06:56 PM
RE: HW Acceleration Working - by dkryder - 10-06-2016, 11:01 PM
RE: HW Acceleration Working - by Gnx - 11-26-2016, 02:05 PM
RE: HW Acceleration Working - by bmarquismarkail - 12-01-2016, 08:05 AM
RE: HW Acceleration Working - by Gnx - 12-05-2016, 12:23 PM
RE: HW Acceleration Working - by Terra854 - 12-05-2016, 08:22 PM
RE: HW Acceleration Working - by Luke - 12-06-2016, 06:38 AM
RE: HW Acceleration Working - by tllim - 12-15-2016, 06:27 PM
RE: HW Acceleration Working - by Pander - 12-08-2016, 05:20 AM
RE: HW Acceleration Working - by Gnx - 12-11-2016, 11:58 AM
RE: HW Acceleration Working - by Pander - 12-16-2016, 08:18 AM
RE: HW Acceleration Working - by Flint - 12-29-2016, 02:49 AM
RE: HW Acceleration Working - by Gnx - 01-20-2017, 03:04 AM
RE: HW Acceleration Working - by Flint - 02-06-2017, 09:22 AM
RE: HW Acceleration Working - by makzoom01 - 02-14-2017, 11:40 PM
RE: HW Acceleration Working - by pqueiro - 03-13-2017, 04:46 AM
RE: HW Acceleration Working - by CaptainZalo - 03-13-2017, 07:29 AM
RE: HW Acceleration Working - by pqueiro - 03-15-2017, 05:11 AM
RE: HW Acceleration Working - by Gnx - 05-09-2017, 09:32 PM
RE: HW Acceleration Working - by Luke - 05-10-2017, 03:08 AM
RE: HW Acceleration Working - by Gnx - 05-14-2017, 10:45 PM
RE: HW Acceleration Working - by Luke - 05-15-2017, 05:11 AM
RE: HW Acceleration Working - by Gnx - 05-15-2017, 12:27 PM
RE: HW Acceleration Working - by pqueiro - 12-01-2017, 02:25 PM
RE: HW Acceleration Working - by Pander - 12-02-2017, 06:44 AM
RE: HW Acceleration Working - by Luke - 12-02-2017, 04:37 PM
RE: HW Acceleration Working - by Brian Beuken - 03-04-2018, 02:54 PM
RE: HW Acceleration Working - by Luke - 03-05-2018, 04:27 AM
  Brand New LCD not working adamjedgar 3 6,611 03-11-2017, 12:20 AM
Last Post: simplexdan
  Pine64+: 3 working, 1 shows nothing on tv zumtra 1 3,993 07-30-2016, 05:47 PM
