A good desktop experience on Rock64
I tried alpine linux on my raspberry pi 2 and it performs really fast. I think it is the fastest distro for soc boards out there. It would be really great if it would run also on the rock64.
Here from the raspberry pi forum:
https://www.raspberrypi.org/forums/viewt...56&t=60569
An extract:
Here are some distro's I compared and the minimal memory they need for still giving you a desktop (without nearly anything running!):
Puppy: 80Mb
Debian 6.03 standard: 64Mb
AntiX: 64Mb
Connochaet: 64Mb
Tiny Core Linux: 48Mb
Slitaz LowRam-CD: 48Mb
Alpine Linux: 28Mb (still able to open and run mc and more !)
Delicate: 16Mb (unable to open xterm)
And here from the alpine linux website:
https://alpinelinux.org/about/
ABOUT
Alpine Linux is an independent, non-commercial, general purpose Linux distribution designed for power users who appreciate security, simplicity and resource efficiency.
SMALL
Alpine Linux is built around musl libc and busybox. This makes it smaller and more resource efficient than traditional GNU/Linux distributions. A container requires no more than 8 MB and a minimal installation to disk requires around 130 MB of storage. Not only do you get a fully-fledged Linux environment but a large selection of packages from the repository.
Binary packages are thinned out and split, giving you even more control over what you install, which in turn keeps your environment as small and efficient as possible.
SIMPLE
Alpine Linux is a very simple distribution that will try to stay out of your way. It uses its own package manager called apk, the OpenRC init system, script driven set-ups and that’s it! This provides you with a simple, crystal-clear Linux environment without all the noise. You can then add on top of that just the packages you need for your project, so whether it’s building a home PVR, or an iSCSI storage controller, a wafer-thin mail server container, or a rock-solid embedded switch, nothing else will get in the way.
SECURE
Alpine Linux was designed with security in mind. The kernel is patched with an unofficial port of grsecurity/PaX, and all userland binaries are compiled as Position Independent Executables (PIE) with stack smashing protection. These proactive security features prevent exploitation of entire classes of zero-day and other vulnerabilities.
So, from what i know, alpine linux would be ideal for soc boards to run a fast desktop.
A good desktop experience on Rock64 - by Luke - 03-05-2018, 02:47 AM
RE: A good desktop experience on Rock64 - by Luke - 03-07-2018, 07:54 AM
RE: A good desktop experience on Rock64 - by Luke - 03-07-2018, 08:24 AM
RE: A good desktop experience on Rock64 - by Luke - 03-08-2018, 03:51 AM
RE: A good desktop experience on Rock64 - by Luke - 03-08-2018, 06:24 AM
RE: A good desktop experience on Rock64 - by Luke - 03-09-2018, 04:41 AM
RE: A good desktop experience on Rock64 - by isndw - 03-14-2018, 01:16 PM
RE: A good desktop experience on Rock64 - by Luke - 03-17-2018, 03:48 AM
RE: A good desktop experience on Rock64 - by noob - 03-17-2018, 12:46 PM
RE: A good desktop experience on Rock64 - by Luke - 03-17-2018, 01:25 PM
RE: A good desktop experience on Rock64 - by noob - 03-17-2018, 02:24 PM
RE: A good desktop experience on Rock64 - by noob - 03-17-2018, 09:10 PM
RE: A good desktop experience on Rock64 - by noob - 03-18-2018, 05:59 AM
RE: A good desktop experience on Rock64 - by Luke - 03-18-2018, 08:36 AM
RE: A good desktop experience on Rock64 - by Luke - 04-29-2018, 03:31 PM
RE: A good desktop experience on Rock64 - by noob - 05-01-2018, 08:32 AM
RE: A good desktop experience on Rock64 - by Luke - 05-01-2018, 08:38 AM
RE: A good desktop experience on Rock64 - by noob - 05-08-2018, 09:08 AM
RE: A good desktop experience on Rock64 - by noob - 05-12-2018, 10:48 AM
RE: A good desktop experience on Rock64 - by Luke - 05-13-2018, 08:12 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 160 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,377 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 345 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 631 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 622 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,494 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 191,131 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 605 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 659 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,703 12-07-2022, 08:22 PM
Last Post: luminosity7
