Which OS is better to run on ROCK64?
(03-15-2018, 04:56 PM)Luke Wrote:
(03-15-2018, 03:03 PM)elik745i Wrote:
(03-15-2018, 01:23 PM)Luke Wrote:
(03-15-2018, 01:11 PM)elik745i Wrote: I have issues with perfomance, can't play even fullhd video files, browsers can't display smooth youtube videos.... I have raspberry pi 3 and despite the fact that raspbian's specs are way less than this crappy rock64, it performs way better...
I need desktop solution, or at least android system. Currently non of which can work properly on this board.
Sorry I'm bit upset...
If you want a good (as far as the SOC and state of development permits) Linux desktop experience then follow follow the linked tutorial.
What is your issue with Android? I have a ATV build running since what seems to be forever and it blows everything/anything that RPI has to offer in terms of media consumption...
issue with android is: I have WIFI and Bluetooth USB dongles and non of them operational in Android, however worked on Linux straight away.
wifi is rtl8192cu and I've tried also rtl8192eu, non of the work in android, most probably lack of drivers... same with bluetooth, I do not know the chipset, but it's 4.1bluetooth and it works in linux too, but not in android.
thanks for tutorial with desktop solution, currently I'm about to install the same and test it!
Also, if you want media playback, why not use LibreELEC ? All my BT and WiFi dongles work, there is docker so you can do a bunch of other things (even run a full debian) and a lot of native add-ons .... Not to mention that the latest alpha build is running really  well for me.
Sorry to hijack the thread, ive seen you also have a rtl8812au and i see you mentioning here that it works on the libreelec build but i was unable to make it work on my rock64, what libreelec version did you try? can it be a device id problem? mine is an tp-link t4uhp (2357:010f)...if its a device id problem you know any solution? (my linux knowledge is somehow limited)
RE: Which OS is better to run on ROCK64? - by Trash_Can_Man - 03-15-2018, 05:08 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 196 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,436 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 377 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 688 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 669 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,797 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 194,408 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 633 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 684 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,733 12-07-2022, 08:22 PM
Last Post: luminosity7
