Power supply for Pine A64 LTS
(10-10-2017, 07:30 PM)panah87 Wrote: What power supply I need to purchase for Pine A64 LTS board ?
This is very well documented on this forum in multiple threads;  please see this link particularly:
I prefer the Raspberry PI power adapter due to its very good two wire cable;  cut the cable to no more than one meter, and adapt to the euler bus pin(6  -ground)   pin(4  +5v).   (or mount barrel connector, see below)
The Rock64 power supply is also quite good  5v @3A 3000ma.  It has a barrel connector !  I'm not sure if the LTS board has the barrel connector yet...  if not you can add it and wire to the euler bus,  otherwise if the LTS board has the barrel connector the Rock64 power supply will just plug it !
Power supply for Pine A64 LTS - by panah87 - 10-10-2017, 07:30 PM
RE: Power supply for Pine A64 LTS - by MarkHaysHarris777 - 10-10-2017, 08:24 PM
RE: Power supply for Pine A64 LTS - by tllim - 10-11-2017, 12:27 AM
  PINE A64-LTS v2 - Can't get WiFi to work Voidwatcher 2 1,690 04-01-2023, 10:29 PM
Last Post: Voidwatcher
  Power lead / RS232c - DIN Project JohnnySSH 3 8,677 08-15-2019, 07:02 PM
