Debian Stretch and Kodi Krypton on Rock64
(10-08-2017, 04:58 PM)Kwiboo Wrote:
(10-08-2017, 04:24 PM)stuartiannaylor Wrote: Kodi is running efficiently on linux as it isn't.
Xserver or linux desktop is of no interest to me, but running Kodi efficiently on linux very much is, and the most optimized and efficient way of doing just that is using pure DRM/KMS and bypassing any windowing system such as xserver/wayland exactly like we do with Kodi on LibreELEC linux.
You should be able to build Kodi/mpv/ffmpeg/mpp with the same patches and build flags we use with LibreELEC on any of the other images and run it very efficient when xserver/wayland is stopped.
All libmali libs provided by Rockchip for ROCK64 implements the EGL_KHR_platform_gbm extension and should work with our DRM/KMS Kodi/mpv patches. You will also need the patched libmali include files for proper EGL/GLES build support, see https://github.com/rockchip-linux/libmali/pull/15.
If you are looking for running Kodi on xserver and being caped by the GPU it should be possible using the armsoc driver and some patches from https://github.com/omegamoon/LibreELEC.t...its/master
Cheers Kwiboo will have a look
RE: Debian Stretch and Kodi Krypton on Rock64 - by stuartiannaylor - 10-08-2017, 05:09 PM
  How to update/compile Debian 12.5? Wizardknight 3 466 03-29-2024, 05:01 AM
Last Post: gedas07
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 163 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,388 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 347 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 636 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 628 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,547 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 191,220 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 608 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 662 05-27-2023, 06:11 AM
Last Post: Transportsicherung
