Rock64 Cluster.
Any PSU would work, as long as it meets a few requirements:
  • Stable 4.9-5.2V output. Don't just trust it if it says 5V. It may put out much less under heavy load and much more under minimal load.
  • 3 amps per board. If you are running 3 boards, the power supply needs to be rated for at least 9 amps. More is fine, and is even preferable.
  • Good cables/wire between power supply and boards. Wires that are too thin may make the voltage drop too low, and might even heat up and burn.
You'll also need to decide on if you want to power the boards through the barrel jack connector, or through the pin header. You'll probably have to do your own wiring, since power supplies that fit your need will be like this.
Rock64 Cluster. - by fabricedupre - 08-15-2017, 11:46 AM
RE: Rock64 Cluster. - by fire219 - 08-15-2017, 12:12 PM
RE: Rock64 Cluster. - by fabricedupre - 08-15-2017, 02:32 PM
RE: Rock64 Cluster. - by fabricedupre - 09-10-2017, 03:11 AM
RE: Rock64 Cluster. - by MarkHaysHarris777 - 08-15-2017, 12:16 PM
RE: Rock64 Cluster. - by fabricedupre - 08-15-2017, 02:29 PM
RE: Rock64 Cluster. - by martinayotte - 09-10-2017, 07:35 AM
RE: Rock64 Cluster. - by digitaldaz - 09-10-2017, 08:14 AM
RE: Rock64 Cluster. - by rmbusy - 09-10-2017, 10:44 AM
RE: Rock64 Cluster. - by pitsch - 09-13-2017, 03:50 PM
RE: Rock64 Cluster. - by digitaldaz - 09-13-2017, 03:53 PM
RE: Rock64 Cluster. - by stuartiannaylor - 09-15-2017, 11:39 PM
RE: Rock64 Cluster. - by digitaldaz - 09-16-2017, 04:34 AM
RE: Rock64 Cluster. - by pitsch - 09-23-2017, 11:45 AM
RE: Rock64 Cluster. - by stuartiannaylor - 09-23-2017, 12:11 PM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 304 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,388 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,724 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,194 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 347 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,913 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,546 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,122 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 767 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 964 10-07-2022, 07:50 PM
Last Post: rookie_267
