Rock64 performance: eMMC / SD Card / USB3 (SSD/HDD)
http://opensource.rock-chips.com/images/...170309.pdf
eMMC Interface
 Compatible with standard iNAND interface
 Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1
 Support block size from 1 to 65535Bytes
 Support three data bus width: 1-bit, 4-bit or 8-bit
 Support up to HS200; but not support CMD Queue and HS400
With a 200Mhz clock & 8 bit data bus the interface should be capable of a theoretical throughput of 200 MB/s
But what HS200 is and how its employed on the ROCK64 ??! I am not worthy Smile
If we are getting the same speed as SD purely because of the cost of the sourced eMMC in the store then it doesn't make a lot of sense if for a few bucks more you can more than double SD throughput?
http://www.samsung.com/global/business/s...l_HR-0.pdf
RE: Rock64 performance: eMMC / SD Card / USB3 (SSD/HDD) - by stuartiannaylor - 08-16-2017, 07:42 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 290 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,367 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,704 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,167 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 337 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,897 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,539 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,117 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 763 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 961 10-07-2022, 07:50 PM
Last Post: rookie_267
