Android Images (ROCK64)
#53
Is a eMMC flash memory really required to get a stable Android installation??
I have tried to install different version of the SD boot able android distro's but only the android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img seems to be "stable". But the Google play store does not contain all the apps I would like to install. (e.g. DR TV)
The non TV version freeze and is not useable for me.
Version 8.1 has no Google Play support - How to install your apps?
Another question, why is the layout of the TV and non TV android installations almost identical (i can't see the differens) I had expected something similar to the PINE64 Android versions or a Android tablet.
I'm using the same SAMSUNG 64 GB EVO micro SD XC 1 as i used to use for my PINE64 media center installation (which worked much better than my new ROCK64)
i had no problems installing Armbian Debian Stretch on another board i'm using as a file server.
i can see in this forum i'm not the only one with SD card issues, so what would you suggest me to do, shall I invest in a eMMC card or just skip the Android installation and go back to my Pine64?
Android Images (ROCK64) - by pineadmin - 08-08-2017, 01:21 AM
RE: Android Images (ROCK64) - by pineadmin - 09-12-2017, 11:50 PM
RE: Android Images (ROCK64) - by pineadmin - 10-02-2017, 03:23 AM
RE: Android Images (ROCK64) - by pineadmin - 10-23-2017, 03:26 AM
RE: Android Images (ROCK64) - by andfun - 10-26-2017, 01:47 AM
RE: Android Images (ROCK64) - by pineadmin - 10-27-2017, 02:50 AM
RE: Android Images (ROCK64) - by Luke - 10-27-2017, 07:08 AM
RE: Android Images (ROCK64) - by dkryder - 10-29-2017, 01:53 PM
RE: Android Images (ROCK64) - by Luke - 10-29-2017, 03:25 PM
RE: Android Images (ROCK64) - by dudemo - 10-29-2017, 03:52 PM
RE: Android Images (ROCK64) - by Luke - 10-29-2017, 04:59 PM
RE: Android Images (ROCK64) - by medc69 - 10-30-2017, 02:40 PM
RE: Android Images (ROCK64) - by dkryder - 10-30-2017, 08:57 PM
RE: Android Images (ROCK64) - by pineadmin - 01-04-2018, 09:52 AM
RE: Android Images (ROCK64) - by wanb1i - 04-08-2018, 09:01 AM
RE: Android Images (ROCK64) - by Luke - 01-04-2018, 10:33 AM
RE: Android Images (ROCK64) - by pineadmin - 01-07-2018, 10:16 PM
RE: Android Images (ROCK64) - by dudemo - 01-08-2018, 06:06 AM
RE: Android Images (ROCK64) - by dudemo - 01-04-2018, 07:41 PM
RE: Android Images (ROCK64) - by quantik - 01-05-2018, 12:45 PM
RE: Android Images (ROCK64) - by toby - 01-05-2018, 02:51 PM
RE: Android Images (ROCK64) - by quantik - 01-05-2018, 07:23 PM
RE: Android Images (ROCK64) - by richzhai - 01-10-2018, 02:45 PM
RE: Android Images (ROCK64) - by pgmy64 - 01-10-2018, 10:55 PM
RE: Android Images (ROCK64) - by richzhai - 01-11-2018, 10:51 AM
RE: Android Images (ROCK64) - by pgmy64 - 01-12-2018, 12:31 AM
RE: Android Images (ROCK64) - by Digigil - 02-12-2018, 09:05 AM
RE: Android Images (ROCK64) - by isndw - 02-09-2018, 09:14 AM
RE: Android Images (ROCK64) - by elik745i - 02-24-2018, 01:05 AM
RE: Android Images (ROCK64) - by elik745i - 02-24-2018, 01:50 AM
RE: Android Images (ROCK64) - by elik745i - 02-25-2018, 03:04 AM
RE: Android Images (ROCK64) - by el_gringo - 02-25-2018, 09:53 AM
RE: Android Images (ROCK64) - by elik745i - 02-26-2018, 01:11 PM
RE: Android Images (ROCK64) - by rarekumiko - 02-26-2018, 11:41 PM
RE: Android Images (ROCK64) - by piraeus - 03-05-2018, 02:58 AM
RE: Android Images (ROCK64) - by Nelly - 03-18-2018, 04:02 AM
RE: Android Images (ROCK64) - by Poincare - 04-05-2018, 08:25 PM
RE: Android Images (ROCK64) - by jzhang18 - 05-01-2018, 09:56 AM
RE: Android Images (ROCK64) - by jzhang18 - 05-01-2018, 10:42 AM
RE: Android Images (ROCK64) - by dougunder - 05-05-2018, 04:43 PM
RE: Android Images (ROCK64) - by Poincare - 05-06-2018, 06:31 AM
RE: Android Images (ROCK64) - by Luke - 05-06-2018, 06:52 AM
RE: Android Images (ROCK64) - by dougunder - 05-06-2018, 08:58 AM
RE: Android Images (ROCK64) - by mlade77 - 05-08-2018, 04:03 AM
RE: Android Images (ROCK64) - by jzhang18 - 05-22-2018, 02:31 PM
RE: Android Images (ROCK64) - by jzhang18 - 06-01-2018, 11:37 AM
RE: Android Images (ROCK64) - by pineadmin - 06-25-2018, 01:34 AM
RE: Android Images (ROCK64) - by geno - 06-27-2018, 05:52 AM
RE: Android Images (ROCK64) - by Luke - 06-27-2018, 08:25 AM
RE: Android Images (ROCK64) - by Poincare - 07-11-2018, 07:35 PM
RE: Android Images (ROCK64) - by ameridroid - 08-13-2018, 09:15 PM
RE: Android Images (ROCK64) - by gbjensen - 09-07-2018, 09:37 AM
RE: Android Images (ROCK64) - by fender90 - 09-07-2018, 01:07 PM
RE: Android Images (ROCK64) - by mranderson - 01-18-2019, 03:23 AM
RE: Android Images (ROCK64) - by pineadmin - 06-20-2019, 12:13 AM
RE: Android Images (ROCK64) - by AlexS - 06-27-2019, 09:25 AM
RE: Android Images (ROCK64) - by lumix14 - 08-25-2019, 06:59 AM
RE: Android Images (ROCK64) - by AlexS - 09-16-2019, 09:01 AM
RE: Android Images (ROCK64) - by fender90 - 06-20-2019, 10:45 PM
RE: Android Images (ROCK64) - by tllim - 06-23-2019, 12:48 AM
RE: Android Images (ROCK64) - by totalgaara - 06-24-2019, 11:01 PM
RE: Android Images (ROCK64) - by R_V - 09-12-2019, 04:58 PM
RE: Android Images (ROCK64) - by elik745i - 09-20-2019, 09:54 AM
RE: Android Images (ROCK64) - by Pepe - 04-11-2020, 04:30 PM
RE: Android Images (ROCK64) - by tllim - 04-14-2020, 11:02 PM
RE: Android Images (ROCK64) - by Pepe - 04-19-2020, 06:30 AM
RE: Android Images (ROCK64) - by tllim - 04-20-2020, 12:34 AM
RE: Android Images (ROCK64) - by ricklar - 05-22-2020, 03:44 AM
RE: Android Images (ROCK64) - by Chaitanyalohith - 08-03-2020, 12:41 AM
RE: Android Images (ROCK64) - by seaurchin - 08-03-2020, 02:20 PM
RE: Android Images (ROCK64) - by tophneal - 08-04-2020, 08:08 AM
RE: Android Images (ROCK64) - by BowerR64 - 09-02-2020, 09:52 PM
RE: Android Images (ROCK64) - by zet_lab - 05-04-2021, 01:58 AM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,361 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,087 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,602 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,049 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,534 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,083 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,598 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,768 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,889 09-09-2020, 08:44 AM
Last Post: BowerR64
  Boot Android from USB? Max_H 3 6,609 09-09-2020, 08:26 AM
Last Post: BowerR64
