Android Images (ROCK64)
#51
(06-27-2018, 08:25 AM)Luke Wrote: If you are refering to the SD version then you need to give it some time on first boot; at first its quite laggy. Haven't tried the eMMC version.
And yes, the Playstore doesn't work. I can recommend aptoide as an altenative app store (just make sure to only install apps with the green shield symbol).
I have tried the EMMC version. For me, I had to use Etcher to flash it to EMMC as the PINE64 Software Installer would not flash a valid, working image that would successfully boot.
On the EMMC version of Android 8.1, the Google Play Store appears to be partially broken. App URLS will open but stall when trying to install. They just say "Install pending..." and never install.  Apps / APKs in Aptoide also do not install -- they will download but not install and are not in the Aptoide or Download directory.  Also, the EMMC image is only 8GB and there does not appear to be a way to expand it to the full size of your EMMC; like, I have a 32GB EMMC and can only use ~3BG after installing Android with the rest of the EMMC as unformatted, not usable space.
Android Images (ROCK64) - by pineadmin - 08-08-2017, 01:21 AM
RE: Android Images (ROCK64) - by pineadmin - 09-12-2017, 11:50 PM
RE: Android Images (ROCK64) - by pineadmin - 10-02-2017, 03:23 AM
RE: Android Images (ROCK64) - by pineadmin - 10-23-2017, 03:26 AM
RE: Android Images (ROCK64) - by andfun - 10-26-2017, 01:47 AM
RE: Android Images (ROCK64) - by pineadmin - 10-27-2017, 02:50 AM
RE: Android Images (ROCK64) - by Luke - 10-27-2017, 07:08 AM
RE: Android Images (ROCK64) - by dkryder - 10-29-2017, 01:53 PM
RE: Android Images (ROCK64) - by Luke - 10-29-2017, 03:25 PM
RE: Android Images (ROCK64) - by dudemo - 10-29-2017, 03:52 PM
RE: Android Images (ROCK64) - by Luke - 10-29-2017, 04:59 PM
RE: Android Images (ROCK64) - by medc69 - 10-30-2017, 02:40 PM
RE: Android Images (ROCK64) - by dkryder - 10-30-2017, 08:57 PM
RE: Android Images (ROCK64) - by pineadmin - 01-04-2018, 09:52 AM
RE: Android Images (ROCK64) - by wanb1i - 04-08-2018, 09:01 AM
RE: Android Images (ROCK64) - by Luke - 01-04-2018, 10:33 AM
RE: Android Images (ROCK64) - by pineadmin - 01-07-2018, 10:16 PM
RE: Android Images (ROCK64) - by dudemo - 01-08-2018, 06:06 AM
RE: Android Images (ROCK64) - by dudemo - 01-04-2018, 07:41 PM
RE: Android Images (ROCK64) - by quantik - 01-05-2018, 12:45 PM
RE: Android Images (ROCK64) - by toby - 01-05-2018, 02:51 PM
RE: Android Images (ROCK64) - by quantik - 01-05-2018, 07:23 PM
RE: Android Images (ROCK64) - by richzhai - 01-10-2018, 02:45 PM
RE: Android Images (ROCK64) - by pgmy64 - 01-10-2018, 10:55 PM
RE: Android Images (ROCK64) - by richzhai - 01-11-2018, 10:51 AM
RE: Android Images (ROCK64) - by pgmy64 - 01-12-2018, 12:31 AM
RE: Android Images (ROCK64) - by Digigil - 02-12-2018, 09:05 AM
RE: Android Images (ROCK64) - by isndw - 02-09-2018, 09:14 AM
RE: Android Images (ROCK64) - by elik745i - 02-24-2018, 01:05 AM
RE: Android Images (ROCK64) - by elik745i - 02-24-2018, 01:50 AM
RE: Android Images (ROCK64) - by elik745i - 02-25-2018, 03:04 AM
RE: Android Images (ROCK64) - by el_gringo - 02-25-2018, 09:53 AM
RE: Android Images (ROCK64) - by elik745i - 02-26-2018, 01:11 PM
RE: Android Images (ROCK64) - by rarekumiko - 02-26-2018, 11:41 PM
RE: Android Images (ROCK64) - by piraeus - 03-05-2018, 02:58 AM
RE: Android Images (ROCK64) - by Nelly - 03-18-2018, 04:02 AM
RE: Android Images (ROCK64) - by Poincare - 04-05-2018, 08:25 PM
RE: Android Images (ROCK64) - by jzhang18 - 05-01-2018, 09:56 AM
RE: Android Images (ROCK64) - by jzhang18 - 05-01-2018, 10:42 AM
RE: Android Images (ROCK64) - by dougunder - 05-05-2018, 04:43 PM
RE: Android Images (ROCK64) - by Poincare - 05-06-2018, 06:31 AM
RE: Android Images (ROCK64) - by Luke - 05-06-2018, 06:52 AM
RE: Android Images (ROCK64) - by dougunder - 05-06-2018, 08:58 AM
RE: Android Images (ROCK64) - by mlade77 - 05-08-2018, 04:03 AM
RE: Android Images (ROCK64) - by jzhang18 - 05-22-2018, 02:31 PM
RE: Android Images (ROCK64) - by jzhang18 - 06-01-2018, 11:37 AM
RE: Android Images (ROCK64) - by pineadmin - 06-25-2018, 01:34 AM
RE: Android Images (ROCK64) - by geno - 06-27-2018, 05:52 AM
RE: Android Images (ROCK64) - by Luke - 06-27-2018, 08:25 AM
RE: Android Images (ROCK64) - by Poincare - 07-11-2018, 07:35 PM
RE: Android Images (ROCK64) - by ameridroid - 08-13-2018, 09:15 PM
RE: Android Images (ROCK64) - by gbjensen - 09-07-2018, 09:37 AM
RE: Android Images (ROCK64) - by fender90 - 09-07-2018, 01:07 PM
RE: Android Images (ROCK64) - by mranderson - 01-18-2019, 03:23 AM
RE: Android Images (ROCK64) - by pineadmin - 06-20-2019, 12:13 AM
RE: Android Images (ROCK64) - by AlexS - 06-27-2019, 09:25 AM
RE: Android Images (ROCK64) - by lumix14 - 08-25-2019, 06:59 AM
RE: Android Images (ROCK64) - by AlexS - 09-16-2019, 09:01 AM
RE: Android Images (ROCK64) - by fender90 - 06-20-2019, 10:45 PM
RE: Android Images (ROCK64) - by tllim - 06-23-2019, 12:48 AM
RE: Android Images (ROCK64) - by totalgaara - 06-24-2019, 11:01 PM
RE: Android Images (ROCK64) - by R_V - 09-12-2019, 04:58 PM
RE: Android Images (ROCK64) - by elik745i - 09-20-2019, 09:54 AM
RE: Android Images (ROCK64) - by Pepe - 04-11-2020, 04:30 PM
RE: Android Images (ROCK64) - by tllim - 04-14-2020, 11:02 PM
RE: Android Images (ROCK64) - by Pepe - 04-19-2020, 06:30 AM
RE: Android Images (ROCK64) - by tllim - 04-20-2020, 12:34 AM
RE: Android Images (ROCK64) - by ricklar - 05-22-2020, 03:44 AM
RE: Android Images (ROCK64) - by Chaitanyalohith - 08-03-2020, 12:41 AM
RE: Android Images (ROCK64) - by seaurchin - 08-03-2020, 02:20 PM
RE: Android Images (ROCK64) - by tophneal - 08-04-2020, 08:08 AM
RE: Android Images (ROCK64) - by BowerR64 - 09-02-2020, 09:52 PM
RE: Android Images (ROCK64) - by zet_lab - 05-04-2021, 01:58 AM
RE: Android Images (ROCK64) - by Blackheat45 - 05-09-2024, 02:40 PM
RE: Android Images (ROCK64) - by manf001 - 05-11-2024, 03:57 PM
RE: Android Images (ROCK64) - by tllim - 05-13-2024, 04:13 PM
RE: Android Images (ROCK64) - by reukiodo - 11-18-2024, 08:21 AM
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 8,781 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 7,858 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 7,786 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 5,962 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 5,042 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 4,494 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 7,810 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 3,357 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 6,035 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 11,932 09-09-2020, 08:44 AM
Last Post: BowerR64
