Linux Images (ROCK64)
I tried it three times with "RAM 4GB" Version
I do not have cards that you presented,
Therefore I used a card (Silicon Power: 8 GB) as an alternative.
However, the problem did not occur, the result is as attached.
Certainly u-boot has failed to install, and u-boot has not been updated.
(Since it was not updated even when I tried it before,
This is a problem unique to the "u-boot-xxx.deb" package)
However, there seems to be no impact on boot due to that (in my environment)
~# mkdir /myDEBDownloadFolder
~# cd /myDEBDownloadFolder
/myDEBDownloadFolder# wget https://github.com/ayufan-rock64/linux-build/releases/download/0.6.44/linux-firmware-image-4.4.126-rockchip-ayufan-239_0.6.44_arm64.deb
/myDEBDownloadFolder# wget https://github.com/ayufan-rock64/linux-build/releases/download/0.6.44/linux-headers-4.4.126-rockchip-ayufan-239_0.6.44_arm64.deb
/myDEBDownloadFolder# wget https://github.com/ayufan-rock64/linux-build/releases/download/0.6.44/linux-image-4.4.126-rockchip-ayufan-239_0.6.44_arm64.deb
/myDEBDownloadFolder# wget https://github.com/ayufan-rock64/linux-build/releases/download/0.6.44/u-boot-rock64-0.6.44_all.deb
/myDEBDownloadFolder# cd ../
/# dpkg -R --install ./myDEBDownloadFolder
Selecting previously unselected package linux-firmware-image-4.4.126-rockchip-ayufan-239.
(Reading database ... 85740 files and directories currently installed.)
Preparing to unpack .../linux-firmware-image-4.4.126-rockchip-ayufan-239_0.6.44_arm64.deb ...
Unpacking linux-firmware-image-4.4.126-rockchip-ayufan-239 (0.6.44) ...
Selecting previously unselected package linux-headers-4.4.126-rockchip-ayufan-239.
Preparing to unpack .../linux-headers-4.4.126-rockchip-ayufan-239_0.6.44_arm64.deb ...
Unpacking linux-headers-4.4.126-rockchip-ayufan-239 (0.6.44) ...
Selecting previously unselected package linux-image-4.4.126-rockchip-ayufan-239.
Preparing to unpack .../linux-image-4.4.126-rockchip-ayufan-239_0.6.44_arm64.deb ...
Unpacking linux-image-4.4.126-rockchip-ayufan-239 (0.6.44) ...
Selecting previously unselected package u-boot-rock64.
Preparing to unpack .../u-boot-rock64-0.6.44_all.deb ...
Unpacking u-boot-rock64 (0.6.44) ...
Setting up linux-firmware-image-4.4.126-rockchip-ayufan-239 (0.6.44) ...
Setting up linux-headers-4.4.126-rockchip-ayufan-239 (0.6.44) ...
Setting up linux-image-4.4.126-rockchip-ayufan-239 (0.6.44) ...
update-initramfs: Generating /boot/initrd.img-4.4.126-rockchip-ayufan-239
Warning: root device  does not exist
Using DTB: rk3328-rock64.dtb
Installing /usr/lib/linux-image-4.4.126-rockchip-ayufan-239/rockchip/rk3328-rock64.dtb into /boot/dtbs/4.4.126-rockchip-ayufan-239/rk3328-rock64.dtb
Installing new rk3328-rock64.dtb.
Taking backup of rk3328-rock64.dtb.
flash-kernel: deferring update (trigger activated)
dpkg: dependency problems prevent configuration of u-boot-rock64:
u-boot-rock64 depends on debsums; however:
 Package debsums is not installed.
dpkg: error processing package u-boot-rock64 (--install):
dependency problems - leaving unconfigured
Processing triggers for flash-kernel (3.79) ...
flash-kernel: installing version 4.4.126-rockchip-ayufan-239
Taking backup of Image.
Installing new Image.
Taking backup of initrd.img.
Installing new initrd.img.
Taking backup of dtb.
Installing new dtb.
Errors were encountered while processing:
u-boot-rock64
~# uname -a
Linux rock64 4.4.77-rockchip-ayufan-136 #1 SMP Thu Oct 12 09:14:48 UTC 2017 aarch64 GNU/Linux
# reboot
Debian GNU/Linux 9 rock64 ttyS2
rock64 login: root
Password:
Last login: Mon Jun  4 05:18:31 UTC 2018 on ttyFIQ0
               _     __   _  _
_ __ ___   ___| | __/ /_ | || |
| '__/ _ \ / __| |/ / '_ \| || |_
| | | (_) | (__|   <| (_) |__   _|
|_|  \___/ \___|_|\_\\___/   |_|
Linux rock64 4.4.126-rockchip-ayufan-239 #1 SMP Sun May 27 18:38:24 UTC 2018 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
~# uname -a
Linux rock64 4.4.126-rockchip-ayufan-239 #1 SMP Sun May 27 18:38:24 UTC 2018 aarch64 GNU/Linux
Linux Images (ROCK64) - by pineadmin - 08-04-2017, 04:06 AM
RE: Linux Images (ROCK64) 0.4.16-83 - by pfeerick - 08-08-2017, 05:59 PM
RE: Linux Images (ROCK64) 0.4.16-83 - by senderg - 08-10-2017, 03:10 AM
RE: Linux Images (ROCK64) 0.4.16-83 - by Luke - 08-10-2017, 03:15 AM
RE: Linux Images (ROCK64) 0.4.16-83 - by senderg - 08-10-2017, 03:16 AM
RE: Linux Images (ROCK64) - by pineadmin - 08-16-2017, 03:59 AM
RE: Linux Images (ROCK64) - by stuartiannaylor - 08-21-2017, 09:10 PM
RE: Linux Images (ROCK64) - by MarkHaysHarris777 - 08-21-2017, 09:20 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 08-21-2017, 10:35 PM
RE: Linux Images (ROCK64) - by MarkHaysHarris777 - 08-21-2017, 11:29 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 08-21-2017, 11:44 PM
RE: Linux Images (ROCK64) - by radek - 08-21-2017, 11:59 AM
RE: Linux Images (ROCK64) - by Luke - 08-21-2017, 02:54 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 08-21-2017, 02:59 PM
RE: Linux Images (ROCK64) - by radek - 08-22-2017, 07:21 AM
RE: Linux Images (ROCK64) - by Luke - 08-22-2017, 07:32 AM
RE: Linux Images (ROCK64) - by Farley56 - 09-06-2017, 03:57 PM
RE: Linux Images (ROCK64) - by tllim - 09-06-2017, 06:31 PM
RE: Linux Images (ROCK64) - by Farley56 - 09-06-2017, 06:51 PM
RE: Linux Images (ROCK64) - by elatllat - 09-12-2017, 12:55 PM
RE: Linux Images (ROCK64) - by ayufan - 09-12-2017, 01:18 PM
RE: Linux Images (ROCK64) - by pineadmin - 09-12-2017, 11:56 PM
RE: Linux Images (ROCK64) - by Farley56 - 09-19-2017, 07:13 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 09-27-2017, 02:23 PM
RE: Linux Images (ROCK64) - by Farley56 - 09-27-2017, 06:16 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 09-27-2017, 07:45 PM
RE: Linux Images (ROCK64) - by pineadmin - 10-02-2017, 03:32 AM
RE: Linux Images (ROCK64) - by stuartiannaylor - 10-02-2017, 07:00 AM
RE: Linux Images (ROCK64) - by chitenavi - 10-24-2017, 12:26 AM
RE: Linux Images (ROCK64) - by Luke - 10-24-2017, 02:39 AM
RE: Linux Images (ROCK64) - by pineadmin - 10-24-2017, 02:30 AM
RE: Linux Images (ROCK64) - by chitenavi - 10-24-2017, 03:28 AM
RE: Linux Images (ROCK64) - by Luke - 10-24-2017, 03:57 AM
RE: Linux Images (ROCK64) - by chitenavi - 10-24-2017, 04:17 AM
RE: Linux Images (ROCK64) - by gene83 - 11-22-2017, 11:00 AM
RE: Linux Images (ROCK64) - by Rar9 - 12-04-2017, 10:14 AM
RE: Linux Images (ROCK64) - by Luke - 12-04-2017, 10:19 AM
RE: Linux Images (ROCK64) - by Rar9 - 12-04-2017, 11:19 AM
RE: Linux Images (ROCK64) - by Luke - 12-04-2017, 11:30 AM
RE: Linux Images (ROCK64) - by pineadmin - 12-08-2017, 04:42 AM
RE: Linux Images (ROCK64) - by thewonderer - 12-19-2017, 01:11 AM
RE: Linux Images (ROCK64) - by dkryder - 12-19-2017, 07:42 PM
RE: Linux Images (ROCK64) - by pineadmin - 12-21-2017, 12:27 AM
RE: Linux Images (ROCK64) - by Rar9 - 12-21-2017, 05:37 AM
RE: Linux Images (ROCK64) - by pineadmin - 12-22-2017, 04:24 AM
RE: Linux Images (ROCK64) - by Rar9 - 12-22-2017, 05:40 AM
RE: Linux Images (ROCK64) - by dkryder - 12-22-2017, 11:00 AM
Linux Images (ROCK64) - by Rar9 - 12-22-2017, 11:07 AM
RE: Linux Images (ROCK64) - by dkryder - 12-22-2017, 03:36 PM
RE: Linux Images (ROCK64) - by pineadmin - 01-04-2018, 04:58 AM
RE: Linux Images (ROCK64) - by gene83 - 01-13-2018, 05:38 PM
RE: Linux Images (ROCK64) - by xalius - 01-13-2018, 06:29 PM
RE: Linux Images (ROCK64) - by gene83 - 01-13-2018, 08:02 PM
RE: Linux Images (ROCK64) - by gene83 - 01-14-2018, 04:33 AM
RE: Linux Images (ROCK64) - by Luke - 01-14-2018, 08:58 AM
RE: Linux Images (ROCK64) - by thewonderer - 01-17-2018, 04:57 PM
RE: Linux Images (ROCK64) - by gene83 - 01-17-2018, 06:30 PM
RE: Linux Images (ROCK64) - by thewonderer - 01-17-2018, 06:45 PM
RE: Linux Images (ROCK64) - by gene83 - 01-17-2018, 11:06 PM
RE: Linux Images (ROCK64) - by a1w.ca - 01-17-2018, 11:52 PM
RE: Linux Images (ROCK64) - by Luke - 01-18-2018, 01:01 AM
RE: Linux Images (ROCK64) - by gene83 - 01-18-2018, 05:56 AM
RE: Linux Images (ROCK64) - by soichiro - 01-18-2018, 10:33 AM
RE: Linux Images (ROCK64) - by Luke - 01-18-2018, 10:38 AM
RE: Linux Images (ROCK64) - by soichiro - 01-18-2018, 11:07 AM
RE: Linux Images (ROCK64) - by thewonderer - 01-23-2018, 11:15 PM
RE: Linux Images (ROCK64) - by gene83 - 01-23-2018, 11:37 PM
RE: Linux Images (ROCK64) - by thewonderer - 01-24-2018, 12:16 AM
RE: Linux Images (ROCK64) - by matteobp - 01-24-2018, 03:35 AM
RE: Linux Images (ROCK64) - by ayufan - 01-24-2018, 10:07 AM
RE: Linux Images (ROCK64) - by matteobp - 01-25-2018, 04:54 AM
RE: Linux Images (ROCK64) - by matteobp - 02-06-2018, 11:02 AM
RE: Linux Images (ROCK64) - by thewonderer - 02-06-2018, 10:16 PM
RE: Linux Images (ROCK64) - by thewonderer - 01-24-2018, 05:27 PM
RE: Linux Images (ROCK64) - by Luke - 01-25-2018, 05:26 AM
RE: Linux Images (ROCK64) - by matteobp - 01-26-2018, 05:28 AM
RE: Linux Images (ROCK64) - by Luke - 01-26-2018, 06:04 AM
RE: Linux Images (ROCK64) - by gene83 - 01-25-2018, 05:39 AM
RE: Linux Images (ROCK64) - by Luke - 01-25-2018, 06:47 AM
RE: Linux Images (ROCK64) - by gene83 - 01-25-2018, 09:43 AM
RE: Linux Images (ROCK64) - by thewonderer - 01-25-2018, 04:34 PM
RE: Linux Images (ROCK64) - by Crady - 01-30-2018, 07:47 PM
RE: Linux Images (ROCK64) - by Luke - 01-31-2018, 01:33 AM
RE: Linux Images (ROCK64) - by gene83 - 02-06-2018, 12:59 PM
RE: Linux Images (ROCK64) - by gene83 - 02-07-2018, 08:43 AM
RE: Linux Images (ROCK64) - by Tony32 - 02-07-2018, 10:06 AM
Xenial Mate Cannot Install Add-ons - by Crady - 02-07-2018, 10:52 AM
RE: Linux Images (ROCK64) - by gene83 - 02-07-2018, 11:20 AM
RE: Linux Images (ROCK64) - by Crady - 02-07-2018, 11:47 AM
RE: Linux Images (ROCK64) - by gene83 - 02-07-2018, 02:04 PM
RE: Linux Images (ROCK64) - by Trash_Can_Man - 02-09-2018, 07:10 AM
RE: Linux Images (ROCK64) - by gene83 - 02-09-2018, 09:21 AM
RE: Linux Images (ROCK64) - by thewonderer - 03-01-2018, 08:29 PM
RE: Linux Images (ROCK64) - by prof7bit - 03-03-2018, 06:40 AM
RE: Linux Images (ROCK64) - by Ricky - 03-18-2018, 12:38 PM
RE: Linux Images (ROCK64) - by pfeerick - 03-18-2018, 09:15 PM
RE: Linux Images (ROCK64) - by Ricky - 03-19-2018, 07:04 AM
RE: Linux Images (ROCK64) - by t4_4t - 03-29-2018, 02:08 AM
RE: Linux Images (ROCK64) - by Malmgren - 04-02-2018, 05:30 AM
RE: Linux Images (ROCK64) - by WenYee - 04-08-2018, 02:38 AM
Linux Images (ROCK64) - by daniel.ligti - 05-06-2018, 01:40 AM
RE: Linux Images (ROCK64) - by rompelstompel - 05-14-2018, 04:38 AM
RE: Linux Images (ROCK64) - by jzhang18 - 05-29-2018, 01:20 PM
RE: Linux Images (ROCK64) - by evilbunny - 05-29-2018, 04:42 PM
RE: Linux Images (ROCK64) - by pfeerick - 05-29-2018, 05:27 PM
RE: Linux Images (ROCK64) - by jzhang18 - 05-31-2018, 07:43 PM
RE: Linux Images (ROCK64) - by pfeerick - 05-31-2018, 11:24 PM
RE: Linux Images (ROCK64) - by jzhang18 - 06-01-2018, 08:16 AM
RE: Linux Images (ROCK64) - by OnTheRocks - 05-30-2018, 03:52 AM
RE: Linux Images (ROCK64) - by evilbunny - 05-30-2018, 05:55 AM
RE: Linux Images (ROCK64) - by OnTheRocks - 05-30-2018, 09:13 PM
RE: Linux Images (ROCK64) - by evilbunny - 05-30-2018, 09:45 PM
RE: Linux Images (ROCK64) - by jzhang18 - 06-02-2018, 09:25 AM
RE: Linux Images (ROCK64) - by pfeerick - 06-02-2018, 10:50 PM
RE: Linux Images (ROCK64) - by t4_4t - 06-02-2018, 02:38 PM
RE: Linux Images (ROCK64) - by jzhang18 - 06-03-2018, 09:17 AM
RE: Linux Images (ROCK64) - by t4_4t - 06-04-2018, 01:25 AM
RE: Linux Images (ROCK64) - by jzhang18 - 06-04-2018, 02:38 PM
RE: Linux Images (ROCK64) - by jzhang18 - 06-05-2018, 10:14 AM
RE: Linux Images (ROCK64) - by gregb49 - 06-21-2018, 11:41 AM
RE: Linux Images (ROCK64) - by pfeerick - 06-21-2018, 06:07 PM
RE: Linux Images (ROCK64) - by gregb49 - 06-22-2018, 12:14 AM
RE: Linux Images (ROCK64) - by gregb49 - 06-22-2018, 12:25 AM
RE: Linux Images (ROCK64) - by pfeerick - 06-22-2018, 04:38 PM
RE: Linux Images (ROCK64) - by gregb49 - 07-17-2018, 10:23 AM
RE: Linux Images (ROCK64) - by Trash_Can_Man - 07-17-2018, 11:34 AM
RE: Linux Images (ROCK64) - by gregb49 - 07-17-2018, 01:03 PM
RE: Linux Images (ROCK64) - by Trash_Can_Man - 07-17-2018, 01:35 PM
RE: Linux Images (ROCK64) - by gregb49 - 07-17-2018, 04:16 PM
RE: Linux Images (ROCK64) - by Trash_Can_Man - 07-17-2018, 04:24 PM
RE: Linux Images (ROCK64) - by gregb49 - 07-18-2018, 02:46 AM
RE: Linux Images (ROCK64) - by gregb49 - 07-22-2018, 09:21 AM
RE: Linux Images (ROCK64) - by gene83 - 07-22-2018, 08:56 PM
RE: Linux Images (ROCK64) - by pineadmin - 08-06-2018, 02:30 AM
RE: Linux Images (ROCK64) - by gedas07 - 08-24-2018, 08:22 AM
RE: Linux Images (ROCK64) - by gene83 - 08-06-2018, 06:43 AM
RE: Linux Images (ROCK64) - by boudiicca - 08-06-2018, 08:15 AM
RE: Linux Images (ROCK64) - by ayufan - 08-06-2018, 11:32 AM
RE: Linux Images (ROCK64) - by AkiraSensei - 08-09-2018, 01:47 PM
RE: Linux Images (ROCK64) - by Averell - 09-12-2018, 06:02 AM
RE: Linux Images (ROCK64) - by evilbunny - 09-12-2018, 06:21 AM
RE: Linux Images (ROCK64) - by Averell - 09-26-2018, 05:31 AM
RE: Linux Images (ROCK64) - by evilbunny - 09-26-2018, 06:30 AM
RE: Linux Images (ROCK64) - by Averell - 11-01-2018, 12:47 PM
RE: Linux Images (ROCK64) - by thewonderer - 09-19-2018, 10:16 PM
RE: Linux Images (ROCK64) - by Luke - 09-20-2018, 04:00 AM
RE: Linux Images (ROCK64) - by thewonderer - 09-20-2018, 04:48 PM
RE: Linux Images (ROCK64) - by Averell - 10-17-2018, 07:26 AM
RE: Linux Images (ROCK64) - by Averell - 10-17-2018, 10:22 AM
RE: Linux Images (ROCK64) - by Averell - 10-18-2018, 06:37 AM
RE: Linux Images (ROCK64) - by thewonderer - 11-01-2018, 09:34 PM
RE: Linux Images (ROCK64) - by Averell - 08-18-2019, 12:18 AM
RE: Linux Images (ROCK64) - by kcirap - 08-26-2019, 05:52 PM
RE: Linux Images (ROCK64) - by fire219 - 08-26-2019, 06:11 PM
RE: Linux Images (ROCK64) - by kcirap - 08-26-2019, 09:28 PM
RE: Linux Images (ROCK64) - by kcirap - 08-30-2019, 05:08 PM
RE: Linux Images (ROCK64) - by dpgraham - 01-12-2020, 01:39 PM
RE: Linux Images (ROCK64) - by evilbunny - 01-12-2020, 07:52 PM
RE: Linux Images (ROCK64) - by dpgraham - 01-14-2020, 12:23 PM
RE: Linux Images (ROCK64) - by useful64 - 05-07-2020, 12:01 PM
RE: Linux Images (ROCK64) - by scalextrix - 05-05-2020, 12:22 PM
RE: Linux Images (ROCK64) - by vve1505 - 07-25-2020, 01:57 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 188 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,415 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 370 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 674 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 656 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,725 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 193,074 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 627 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,804 06-02-2023, 07:52 AM
Last Post: diederik
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 677 05-27-2023, 06:11 AM
Last Post: Transportsicherung
