Rock64 power consumption
(07-27-2017, 03:45 AM)dkryder Wrote: there is a reason that the rock64 power supply units in the store are 3Amp with barrel jacks while the pine64 board power supply are 2Amp with micro usb plug. rock64 uses considerable current compared to many other sbc.
No, not the case dkryder Wink
The reason for the 3A power supply is because that pine64 is standardising on the 3.5x1.35mm (IEC type H) barrel jacks instead of microUSB for two main reasons. The first is that the microUSB connector is only spec'd to handle 1.7 or 1.8A (think it's the latter). So a 2A or more power supply would be stupid in that case. The second it because of crappy microUSB leads with power lines about as thick and as useful as a human hair. Resulting it massive voltage sag when the power is needed, causing instability and data corruption.
So, they have moved the the 3.5x1.35mm connector and a single PSU (with a USB to DC cable as an option also). Which is used by the pinebook, rock64, sopine base board, and the upcoming LTS version of the pine64, plus any other boards they come out with. Why 3A? Because whilst the pine64 and rock64 on their own don't need that, if you have pheripherals pulling power from the rock64/pine64, it obviously needs a bit more. And whilst the pinebook only draws around 1.8A, that just means the power supply isn't being run flat out, so doesn't get seriously hot like a lot of others do.
To give you an idea of actual power requirements of the rock64, here are two quick (and crap quality  - I'll re-upload them later in HQ instead of SD) videos of the rock64 booting, and the rock64 running a cpuburn-A53 processor load test. You can see from the USB power meter that it uses under 1A when the CPU is loaded. This is with it running up at 1.3Ghz...
Rock64 power consumption - by arevenco - 07-26-2017, 09:29 AM
RE: Rock64 power consumption - by jebivetar - 01-12-2018, 11:52 AM
RE: Rock64 power consumption - by dkryder - 07-27-2017, 03:45 AM
RE: Rock64 power consumption - by pfeerick - 07-27-2017, 05:58 AM
RE: Rock64 power consumption - by dkryder - 07-28-2017, 03:30 AM
RE: Rock64 power consumption - by pfeerick - 07-28-2017, 06:22 PM
RE: Rock64 power consumption - by dkryder - 07-29-2017, 05:02 AM
RE: Rock64 power consumption - by pfeerick - 07-29-2017, 07:48 PM
RE: Rock64 power consumption - by tllim - 07-29-2017, 07:33 PM
RE: Rock64 power consumption - by dkryder - 01-12-2018, 01:34 PM
RE: Rock64 power consumption - by jebivetar - 01-12-2018, 02:35 PM
RE: Rock64 power consumption - by dkryder - 01-12-2018, 06:42 PM
RE: Rock64 power consumption - by xalius - 01-12-2018, 04:53 PM
RE: Rock64 power consumption - by jebivetar - 01-12-2018, 07:26 PM
RE: Rock64 power consumption - by tllim - 01-15-2018, 10:51 PM
RE: Rock64 power consumption - by Exec - 01-16-2018, 08:07 AM
RE: Rock64 power consumption - by Malmgren - 01-16-2018, 02:12 PM
RE: Rock64 power consumption - by ayufan - 01-16-2018, 02:25 PM
RE: Rock64 power consumption - by z4v4l - 01-16-2018, 02:48 PM
RE: Rock64 power consumption - by Exec - 01-16-2018, 04:43 PM
RE: Rock64 power consumption - by z4v4l - 01-17-2018, 06:50 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 2,020 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 14,524 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 8,811 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 8,437 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 1,354 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 3,916 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 5,283 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 4,220 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 1,651 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 1,722 10-07-2022, 07:50 PM
Last Post: rookie_267
