microSD card performance comparison
Performance governor is what I was using (it was the default).
I think the comparisons to odroid c2 are off topic. Yes, emmc is faster.
You also link to SATA performance, but we don't have SATA on this board.
I think common sense would dictate that you shouldn't be writing a ton of data to the SD card while taking read benchmarks. Yes, things going on in the background will cause some problems. We can only do as best as we can here. If you follow my spreadsheet, you'll see that for most of the tests I take an average of 2 or 3 tests to reach that number. That should be sufficient to give us a ballpark measure. You'll see the results don't vary much.
I appreciate your criticisms and participation and understand you don't want to contribute or use this data.
We can deal with erroneous test results as they come in. Hopefully enough people will contribute we can build a large data set.
And yes, the evo+ cards are probably the ones people should get. But because I didn't know this, I had two other cards with not as good performance. Would love for someone with the evo+ cards to come in and provide their performance numbers.
RE: microSD card performance comparison - by falk.ben@gmail.com - 03-24-2016, 01:00 PM
  Flashing SD card over USB ccben 5 15,003 07-25-2017, 10:11 PM
Last Post: ccben
  How do I change the default sound card? zirconx 2 8,674 10-02-2016, 05:10 AM
Last Post: pfeerick
  RHEL Performance Tuning Guide xalius 0 4,124 07-31-2016, 03:01 AM
Last Post: xalius
  MicroSD card won't format Andr3w 2 7,456 07-12-2016, 11:10 AM
Last Post: Luke
  Making a Ubuntu Server image for SD Card insignia96 3 10,214 04-06-2016, 09:46 PM
Last Post: insignia96
  How to get Ubuntu SD Card Bob123456789 7 17,315 01-25-2016, 04:08 PM
Last Post: Ghost
