Simple 3d Printed Case
(03-19-2016, 10:48 PM)kanthony Wrote: I designed a simple 3d printed case since there didn't seem to be one out there already. Nothing fancy but it works.
STLs available here: http://www.thingiverse.com/thing:1428977
Hi!
Thanks for making this case!
As I have a M3D printer which only prints objects in size 10x10x10cm I can't print any available Pine64 case... :Big Grin
So, what do you think, would be possible to close the case and split it in half, and add some screw mounts on the left and right (longer) side of the case to connect 2 parts of the case?
Thanks! Smile
EDIT: This is what I came up with http://www.thingiverse.com/thing:1483681
Simple 3d Printed Case - by kanthony - 03-19-2016, 10:48 PM
RE: Simple 3d Printed Case - by Akazungu - 03-20-2016, 06:05 AM
RE: Simple 3d Printed Case - by Shady2tree - 03-20-2016, 09:01 PM
RE: Simple 3d Printed Case - by montyflange - 03-30-2016, 09:29 AM
RE: Simple 3d Printed Case - by trevor.ribal - 03-30-2016, 03:11 PM
RE: Simple 3d Printed Case - by vedranius - 04-11-2016, 11:59 AM
RE: Simple 3d Printed Case - by hukuzatuna - 04-12-2016, 12:28 PM
RE: Simple 3d Printed Case - by vedranius - 04-12-2016, 02:30 PM
RE: Simple 3d Printed Case - by Shady2tree - 04-12-2016, 03:30 PM
RE: Simple 3d Printed Case - by PDXMike - 04-13-2016, 12:08 PM
RE: Simple 3d Printed Case - by ksolomon - 04-19-2016, 03:57 PM
RE: Simple 3d Printed Case - by vedranius - 04-19-2016, 04:15 PM
RE: Simple 3d Printed Case - by ksolomon - 04-19-2016, 07:09 PM
RE: Simple 3d Printed Case - by digivish - 04-20-2016, 12:55 PM
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 64,496 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 3,987 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 12,391 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 11,594 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 19,061 07-18-2017, 10:39 AM
  A case with active cooling for 1Gb pine64 ishwest 5 10,102 06-28-2017, 04:05 AM
Last Post: ishwest
  Lego Case Kiryu 67 89,301 03-30-2017, 11:36 AM
Last Post: Luke
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 13,126 10-24-2016, 08:18 AM
Last Post: killor
  Pine64 Layer case modmypi 2 5,332 10-04-2016, 02:45 AM
Last Post: modmypi
Photo Weatherproof case build ltorsini 10 29,492 10-02-2016, 10:49 PM
Last Post: ltorsini
