Disable touchpad tap to click?
(06-21-2017, 08:30 AM)MarkHaysHarris777 Wrote:
(06-21-2017, 08:15 AM)colin.faulkingham Wrote:
(06-21-2017, 06:40 AM)MarkHaysHarris777 Wrote: What would be really handy is if the tap-to-click were a configurable property (and a unique event) so that we could ignor just that one;   Blush
This touchpad is really poorly designed. It would be nice if there was a way to hack the firmware of this touchpad or replace it with something better.  Sad Documentation from Hailuck is non-existent.
Yes, but here's the rub-- many expensive notebooks have this same issue !  I put that script on my daughter's Asus when she went to Luther college, and I put it on my son's HP DVD series when he went to Iowa State. My HP g6 series also has the same issue, and the same script;
And think about this, almost all notebooks put the danged touchpad in the palm rest position so that its impossible to type without causing havoc with the touchpad !  Even the Holy Mac Book Pro has the same issue.  So, I think over time some of this may change;  but , it doesn't look like anytime soon.   Sad
I have used quite a few notebooks from MacBook Pro's (current machine) down to Chromebooks. None of them had the problem of the cursor jumping around because of a slight touch of the touchpad. The tap-to-click on this touchpad is fundamentally broken. To fix they need to either tune the sensitivity or disable the tap-to-click functionality.
RE: Disable tap to click? - by MarkHaysHarris777 - 06-19-2017, 07:50 PM
RE: Disable touchpad tap to click? - by pfeerick - 06-21-2017, 03:12 AM
RE: Disable touchpad tap to click? - by colin.faulkingham - 06-21-2017, 08:45 AM
RE: Disable touchpad tap to click? - by pfeerick - 06-21-2017, 06:23 PM
RE: Disable touchpad tap to click? - by combs - 08-04-2017, 08:18 PM
RE: Disable touchpad tap to click? - by NoSalt - 04-08-2019, 02:40 PM
RE: Disable touchpad tap to click? - by ab1jx - 02-09-2020, 02:20 PM
RE: Disable touchpad tap to click? - by jezek - 02-09-2020, 02:35 PM
RE: Disable touchpad tap to click? - by ab1jx - 02-09-2020, 03:39 PM
RE: Disable touchpad tap to click? - by ab1jx - 02-09-2020, 04:42 PM
RE: Disable touchpad tap to click? - by ab1jx - 04-27-2020, 06:25 PM
RE: Disable touchpad tap to click? - by ab1jx - 04-27-2020, 07:31 PM
  How to enable touchpad natural scrolling? plumlis 3 6,504 07-19-2020, 02:46 PM
Last Post: Martin Gruber
  Proof of concept script to disable the touchpad while typing daid 21 27,772 02-25-2018, 06:47 PM
Last Post: pfeerick
Sad touchpad edges scrolling kurai021 11 13,840 07-09-2017, 05:56 PM
Last Post: Luke
