EULER bus question...
Use multiplexing;
... the 74hc165 is a parallel in serial out chip; you multiplex and latch the ADC of choice and then use SPI to bring the ADC bits into the pine via serial. The 74hc595 reverses that. A combination of 165 and 595 is generally used to scan a keyboard matrix, for instance.
Basically each ADC has its own parallel to serial setup. Your software should use multiplexing to select the parallel to serial setup (for the particular ADC) and then SPI is used to read it. This can be done with i2c as well.
Heck yeah your pine and SPI can keep up with your ADC chips;
EULER bus question... - by ealbers - 05-20-2017, 05:19 AM
RE: EULER bus question... - by martinayotte - 05-20-2017, 09:17 AM
RE: EULER bus question... - by MarkHaysHarris777 - 05-20-2017, 01:24 PM
RE: EULER bus question... - by ealbers - 05-20-2017, 05:18 PM
RE: EULER bus question... - by MarkHaysHarris777 - 05-20-2017, 09:33 PM
RE: EULER bus question... - by ealbers - 05-21-2017, 05:13 AM
RE: EULER bus question... - by pfeerick - 05-21-2017, 06:37 PM
RE: EULER bus question... - by MarkHaysHarris777 - 05-21-2017, 08:25 AM
RE: EULER bus question... - by martinayotte - 05-22-2017, 04:06 PM
RE: EULER bus question... - by pfeerick - 05-22-2017, 07:23 PM
RE: EULER bus question... - by MarkHaysHarris777 - 05-22-2017, 07:33 PM
  I2S Codec on Euler bus of Pine A64+ RANJITT76 8 10,499 01-17-2019, 02:25 AM
Last Post: ramstadt
  Supply DC power to Pine64 via Pi-2 Connector & Euler Bus? crapped 2 5,771 05-24-2018, 01:58 AM
Last Post: crapped
  Backer 12,931 - Shipping Question pspina3rd 13 15,450 07-30-2016, 07:10 PM
  Simple Question, has anyone successfully booted a 2Gb Pine? rahlquist 24 32,722 07-12-2016, 11:31 PM
  Backer 11,978; Shipping question GJurriens 3 4,806 07-12-2016, 06:55 PM
  Case question Fosterocalypse 5 5,797 05-02-2016, 10:35 PM
Last Post: Fosterocalypse
  Playbox Kit Question! TGCOM 8 11,127 02-22-2016, 12:13 AM
Last Post: Ghost
