How to add support to strongSwan IPsec
(05-17-2017, 08:12 PM)kingsing2 Wrote: So, how to insert these modules or should I recompile the kernel from the beginning.
First, to answer the question you didn't ask;  Yes, you can use VPN without using strongswan.
...  you may need the IPsec-based VPN solution;  but I would try to avoid it.   On the other hand, if you need the modules you listed then you will have to compile them in;  good thing strongswan is open source.
RE: How to add support to strongSwan IPsec - by MarkHaysHarris777 - 05-17-2017, 10:46 PM
  Ubuntu Xenial - Firefox add support for H264 and EAC3 klode 1 4,773 05-26-2017, 11:10 AM
Last Post: Gnx
  GPU support? adamw 15 19,123 05-27-2016, 04:08 PM
Last Post: adamw
