Heat-sink as add-on?
I have ordered (from AliExpress) a batch of heatsinks for my pine. I read here on the forum that there is room for a 20x20 heatsink for the cpu and a 9x9 for the power unit (dont remember what thread). I ordered both 10 and 15mm height of both sizes. (My casing will be as shown in my signature so free space in the Z-axis is not a problem, but is is something you must remember to consider depending on what enclosure you will be using.
Heat-sink as add-on? - by longsleep - 02-28-2016, 04:16 AM
RE: Heat-sink as add-on? - by Tarjei85 - 02-28-2016, 06:18 AM
RE: Heat-sink as add-on? - by tllim - 02-29-2016, 02:08 AM
RE: Heat-sink as add-on? - by Tarjei85 - 02-29-2016, 02:21 AM
RE: Heat-sink as add-on? - by RaspiBit - 02-29-2016, 09:29 AM
RE: Heat-sink as add-on? - by tllim - 02-29-2016, 10:42 AM
Heat-sink as add-on? - by Zoidiano0 - 02-29-2016, 09:40 AM
RE: Heat-sink as add-on? - by vsz85 - 03-06-2016, 07:32 AM
RE: Heat-sink as add-on? - by patrickhwood - 03-06-2016, 12:13 PM
RE: Heat-sink as add-on? - by janjwerner - 03-06-2016, 09:28 AM
RE: Heat-sink as add-on? - by janjwerner - 03-06-2016, 02:26 PM
RE: Heat-sink as add-on? - by tllim - 03-06-2016, 03:12 PM
RE: Heat-sink as add-on? - by longsleep - 03-06-2016, 02:34 PM
RE: Heat-sink as add-on? - by janjwerner - 03-06-2016, 02:39 PM
RE: Heat-sink as add-on? - by longsleep - 03-06-2016, 02:44 PM
RE: Heat-sink as add-on? - by janjwerner - 03-06-2016, 02:47 PM
RE: Heat-sink as add-on? - by longsleep - 03-06-2016, 03:31 PM
RE: Heat-sink as add-on? - by tllim - 03-06-2016, 03:49 PM
RE: Heat-sink as add-on? - by Andrew2 - 03-07-2016, 01:44 PM
RE: Heat-sink as add-on? - by tllim - 03-07-2016, 06:48 PM
RE: Heat-sink as add-on? - by jhgoodwin - 03-30-2016, 10:36 AM
RE: Heat-sink as add-on? - by peterz - 03-30-2016, 01:19 PM
RE: Heat-sink as add-on? - by rahlquist - 03-30-2016, 01:36 PM
RE: Heat-sink as add-on? - by patrickhwood - 03-31-2016, 08:59 AM
RE: Heat-sink as add-on? - by rahlquist - 03-31-2016, 09:48 AM
RE: Heat-sink as add-on? - by Andrew2 - 03-31-2016, 11:58 PM
RE: Heat-sink as add-on? - by Andrew2 - 03-31-2016, 10:25 AM
RE: Heat-sink as add-on? - by pine.tree - 04-01-2016, 06:57 AM
RE: Heat-sink as add-on? - by rahlquist - 04-01-2016, 07:10 AM
RE: Heat-sink as add-on? - by pine.tree - 04-01-2016, 07:27 AM
RE: Heat-sink as add-on? - by rahlquist - 04-01-2016, 08:15 AM
RE: Heat-sink as add-on? - by rahlquist - 04-01-2016, 01:10 PM
RE: Heat-sink as add-on? - by Andrew2 - 04-02-2016, 12:37 AM
RE: Heat-sink as add-on? - by pine.tree - 04-01-2016, 01:24 PM
RE: Heat-sink as add-on? - by rahlquist - 04-01-2016, 01:30 PM
RE: Heat-sink as add-on? - by pine.tree - 04-01-2016, 01:38 PM
RE: Heat-sink as add-on? - by HappyFuzzy - 04-26-2016, 09:21 AM
RE: Heat-sink as add-on? - by carb1a4h - 04-26-2016, 09:27 AM
RE: Heat-sink as add-on? - by g_t_j - 05-26-2016, 09:18 AM
RE: Heat-sink as add-on? - by SkimMilk - 07-28-2016, 08:09 PM
RE: Heat-sink as add-on? - by tllim - 07-30-2016, 06:56 PM
RE: Heat-sink as add-on? - by jaferic - 09-21-2016, 08:27 AM
RE: Heat-sink as add-on? - by HenryD - 10-18-2016, 08:14 AM
RE: Heat-sink as add-on? - by benpope81 - 03-15-2017, 05:26 PM
RE: Heat-sink as add-on? - by vinodmenon80 - 04-17-2017, 03:21 AM
RE: Heat-sink as add-on? - by pfeerick - 04-17-2017, 07:28 PM
RE: Heat-sink as add-on? - by Luke - 04-18-2017, 03:41 AM
RE: Heat-sink as add-on? - by vinodmenon80 - 04-18-2017, 06:41 AM
