HDMI Color Inverted on TV
(01-12-2017, 01:57 AM)Apicalis Wrote: Hello everyone,
my TV is the Philips 42PFL8404 which i bought ~6-7 years ago. Since then i had the same issue with some devices which didn't really bother my because i rarely used them on my TV
The problem is that every now and then (no real trigger) the screen gets inverted colors. Doesn't matter if a movie is running or it's a picture on the screen without any movement.
This happened to some devices like my laptop, a playstation and my PC once when i had another GFX card installed. So the Problem is definetly the TV not the Pine.
Why am i talking about it then on this forum???
Because there is a Fix that can be used on Radean GFX Cards. There u can go to the ATI Driver Settings and set "PC-Standard-Pixelformat RGB 4:4:4 (full RGB)" to fix this issue. And i wanted to ask if there is anything similar that can be done on the Pine64 on Linux oder Android
It's really terrible that my Pine64 finally runs smoothly with Ayufans Android image but i can't use it on my TV :/
Thanks in advance
May not able to apply, the Pine A64 board output YUV 4:2:0 instead of RGB 4:4:4. My guess what you are facing is teh RGB or YUV color conversion issue that TV determine wrongly.
HDMI Color Inverted on TV - by Apicalis - 01-12-2017, 01:57 AM
RE: HDMI Color Inverted on TV - by tllim - 01-16-2017, 04:25 PM
RE: HDMI Color Inverted on TV - by lyhaku - 03-28-2017, 10:33 AM
  HDMI CEC on Android fneves 39 55,464 03-10-2018, 06:08 PM
Last Post: lupa18
  USB Mic + HDMI Speaker jack_shepherd 0 1,925 11-27-2017, 03:27 AM
Last Post: jack_shepherd
  Android 6.0 (HDMI Video Output) [20170112 v2.0.1] no sound philips 0 2,567 07-23-2017, 11:14 AM
Last Post: philips
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 23,212 05-05-2017, 01:50 AM
Last Post: Quezbeme
  No HDMI Output Arkhanjel 5 5,988 05-03-2017, 09:21 AM
Last Post: Arkhanjel
  Supported 4:3 and 16:10 resolutions over HDMI on Android karlitos 26 32,346 03-06-2017, 03:59 PM
Last Post: dikov
  HDMI not working gubaguba 7 9,119 01-25-2017, 09:45 PM
Last Post: MakerLing81
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 6,982 12-11-2016, 05:57 PM
Last Post: Luke
  Build the Lichee and Android source-"Android 5.1.1 Image (HDMI Video Output) Release SuperX 2 4,541 08-12-2016, 02:00 AM
Last Post: xalius
  How to set HDMI output to less than 720p? Kattemageren 1 3,083 06-14-2016, 06:13 PM
Last Post: Ghost
