Questions about GPIO
(02-14-2016, 07:12 PM)patrickhwood Wrote:
(02-14-2016, 05:49 PM)limitlesscodes Wrote: Hey Pine64 backers! I am having difficulty figuring out how I would use C to take user input, button presses, and light LEDs with the GPIO, I understand C fairly well but have no experience with interfacing with"GPIO." Here is the best program I could think of although I believe there is a much better way to do this:
*Simple pulsing of GPIO example
#include <stdio.h>
#include <string.h>
FILE *zero, *one;
int main(int argc, char *argv[])
zero = fopen("/sys/class/gpio/gpio206/value", "w");
one = fopen("/sys/class/gpio/gpio206/value", "w");
while(1)
fputs("0\n", zero);
fflush(zero);
fputs("1\n", one);
fflush(one);
Also what determines the pin number? Thanks for your help!
You've got the right general idea.  See http://falsinsoft.blogspot.com/2012/11/a...space.html and
http://linux-sunxi.org/GPIO
I read through them, so from what I am able to understand my program would only work if the kernel supports GPIO access from sysfs, will the Pine64 support this(I really hope to hear yes)? Also, say I am trying to blink an LED, can you be so kind as to tell my a pin number on the GPIO that can do that?
GPIO ports - by igna09 - 12-31-2015, 04:31 AM
RE: GPIO ports - by o9guy - 12-31-2015, 10:28 AM
RE: GPIO ports - by limitlesscodes - 02-07-2016, 01:56 PM
RE: GPIO ports - by tllim - 02-07-2016, 08:25 PM
RE: GPIO ports - by limitlesscodes - 02-10-2016, 12:25 AM
RE: GPIO ports - by tllim - 02-10-2016, 06:53 PM
Questions about GPIO - by limitlesscodes - 02-14-2016, 05:49 PM
RE: Questions about GPIO - by patrickhwood - 02-14-2016, 07:12 PM
RE: Questions about GPIO - by limitlesscodes - 02-15-2016, 06:05 PM
RE: Questions about GPIO - by limitlesscodes - 02-16-2016, 03:15 PM
RE: Questions about GPIO - by patrickhwood - 02-16-2016, 11:45 PM
RE: Questions about GPIO - by limitlesscodes - 02-17-2016, 03:51 PM
  GPIO specifications in device tree ramstadt 1 5,193 01-16-2019, 03:17 PM
Last Post: ramstadt
  +PINEBOOK Q4OS Pinebook Questions StewB 0 3,416 08-24-2017, 03:53 PM
Last Post: StewB
  Low-Level-GPIO-Access Thoams131 2 6,403 01-11-2017, 02:54 PM
Last Post: Thoams131
Question PPS-GPIO Sebastian 11 25,186 07-12-2016, 07:25 PM
  C#.NET / Mono GPIO library? abutler77 0 4,078 06-12-2016, 10:34 PM
Last Post: abutler77
  Lazarus and GPIO gbestwick 0 3,331 05-22-2016, 08:51 PM
Last Post: gbestwick
  GPIO javascript library. neeeds 1 5,303 02-19-2016, 11:31 PM
Last Post: limitlesscodes
