Mini-Tutorial to get a linux Desktop GUI working on Pine64+
(03-27-2017, 11:04 AM)Logan5 Wrote: Ok during setup, resizing of partition was unsuccessful and during install of KDE, I had to press "S" a couple of times to skip feedback errors, I suspect are related to partition size. took about an hour, to end at a blank Pinecone screen, no prompt, so I rebooted. It booted to a graphic screen with 2 windows, one is a command line prompt and the other is a console log for pine64. I attempted to resize by install gparted and it failed.  I am sure my disk space is limitation is part of my troubles. I will attempt to use the command line entries again in the partial GUI environment. If anyone has advice please advise..
Perhaps your sd card is not truly the size it says. I have run in to that problem with sd cards that were bought on amazon, and weren't any weird brand.
(03-28-2017, 02:20 PM)Logan5 Wrote:
(03-27-2017, 02:49 PM)xalius Wrote: Generally the repositories for many distros on arm64 are still work in progress, but it was a lot worse last year... you can however run 32-bit arm software (armhf) on your 64bit system...
May I ask, how do I get my on board bluetooth module working. In settings, it says "bluetooth turned off" then a button "fix it" that does not seem to do anything. should I try a USB dongle, or do I need to preform a task to activate my module? I am using wired USB for now.
When your at your regular desktop screen, go down to the chameleon click him then click install/remove software packages. There are a lot of things available, so focus on the Network/Communication software folders, it will be time consuming but you pretty much need to go through and read the summary of the various packages you find that pertain to bluetooth. I suggest anyone that has to do with Bluetooth drivers etc. select and install those, then update, then reboot. After your back go into your network setup and set up your bluetooth module.
RE: Mini-Tutorial to get a linux Desktop GUI working on Pine64+ - by speedro86 - 04-05-2017, 01:45 PM
  Star64 Irradium (based on crux linux) riscv64, aarch64 mara 12 13,827 03-06-2026, 10:53 PM
  StarPro64 Irradium (based on crux linux) riscv64, aarch64 mara 16 8,017 03-05-2026, 04:24 PM
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 8,844 10-21-2025, 10:13 AM
  Running Linux on Pinebook Pro with External Monitor Twers1962 2 2,298 03-25-2025, 11:10 PM
Last Post: Dendrocalamus64
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 3,629 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,189 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 6,002 06-17-2021, 05:35 AM
Last Post: kqlnut
  ISO Smart Mini Portable Soldering Iron cjmones 0 2,827 12-13-2020, 01:34 PM
Last Post: cjmones
  Setting up QT for compiling on my desktop vincer 0 3,161 09-19-2020, 03:31 PM
Last Post: vincer
  Ctrl + Shift + Tab not working in Firefox Bolitoglossa 2 6,184 08-21-2020, 04:05 AM
Last Post: Bolitoglossa
