Mini-Tutorial to get a linux Desktop GUI working on Pine64+
UPDATE: I have been able to get my wifi USB dongle working! If you have followed the above how-to and have a working OpenSUSE desktop with ethernet internet, then you can also get your USB wifi working. You need to go down to the little chameleon in the bottom left corner and click, this is the equivalent of windows start, then in system you will find install/remove software, select it, then put in the root password the default is: pine64root, then you will see many different places to find software, you will need to search the different lists of repositories, and other software to select any/all the USB related packages, wireless packages, network packages, and any other things you would want to add. You can tell what is already installed and what isn't by the checks in the boxes for the various packages, scroll down to where the checked packages stop and where the unchecked aka available, but not installed software is, and select the relevant packages, when you are finished select accept, then your new software will be downloaded and installed. Reboot with your hardware connected and your devices will be recognized. NOTE: I was using a USB hub in the top USB port on the pine, and it was able to see my wireless keyboard, mouse, and wifi dongle without issue.
If this has helped you, please add me to your buddy list and add rep or comment. I will also happily answer any questions I can, so please ask here or message me. I am no expert, but I am happy to share my knowledge with everyone!
RE: Mini-Tutorial to get a linux Desktop GUI working on Pine64+ - by speedro86 - 12-14-2016, 03:54 PM
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 698 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  Irradium (based on crux linux) riscv64, aarch64 mara 0 657 11-03-2023, 03:10 PM
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,761 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,467 06-17-2021, 05:35 AM
Last Post: kqlnut
  ISO Smart Mini Portable Soldering Iron cjmones 0 1,917 12-13-2020, 01:34 PM
Last Post: cjmones
  Setting up QT for compiling on my desktop vincer 0 2,071 09-19-2020, 03:31 PM
Last Post: vincer
  Ctrl + Shift + Tab not working in Firefox Bolitoglossa 2 4,144 08-21-2020, 04:05 AM
Last Post: Bolitoglossa
  Just discovered Pine64 ! - first Q philip_rhoades 4 5,779 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 3,990 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 151,385 01-15-2020, 12:46 PM
