CyanogenMod 13
I tried out the new boot.img,
$ sha256sum boot.img
fbfe7b55b7e7f57d75ef38482032fef971c84ceb171d548efbd97893927c3f41  boot.img
Here are the logs,
[   17.759624] Freeing unused kernel memory: 524K (ffffffc0009e5000 - ffffffc000a68000)
[   17.770423] init: init started!
[   17.783885] SELinux: 2048 avtab hash slots, 5277 rules.
[   17.795535] SELinux: 2048 avtab hash slots, 5277 rules.
[   17.801277] SELinux:  1 users, 2 roles, 561 types, 0 bools, 1 sens, 1024 cats
[   17.809085] SELinux:  87 classes, 5277 rules
[   17.817166] SELinux:  Completing initialization.
[   17.822211] SELinux:  Setting up existing superblocks.
[   17.827877] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   17.835692] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
[   17.843740] SELinux: initialized (dev bdev, type bdev), not configured for labeling
[   17.852118] SELinux: initialized (dev proc, type proc), uses genfs_contexts
[   17.859752] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   17.867666] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
[   17.876536] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
[   17.889549] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
[   17.897101] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
[   17.904627] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
[   17.914524] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
[   17.922625] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
[   17.931257] SELinux: initialized (dev configfs, type configfs), not configured for labeling
[   17.940391] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   17.948303] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   18.145452] type=1403 audit(1262304012.920:2): policy loaded auid=4294967295 ses=4294967295
[   18.155317] init: (Initializing SELinux enforcing took 0.39s.)
[   18.168442] init: init second stage started!
[   18.229869] init: waitpid failed: No child processes
[   18.235519] init: (Loading properties from /default.prop took 0.00s.)
[   18.244602] init: (Parsing /init.environ.rc took 0.00s.)
[   18.250814] init: (Parsing /init.usb.rc took 0.00s.)
[   18.256826] init: (Parsing init.common.rc took 0.00s.)
[   18.262664] init: (Parsing init.sun50iw1p1.usb.rc took 0.00s.)
[   18.269145] init: (Parsing init.zygote64_32.rc took 0.00s.)
[   18.275240] init: (Parsing /init.sun50iw1p1.rc took 0.02s.)
[   18.281729] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[   18.288110] init: /init.zygote64_32.rc: 1: ignored duplicate definition of service 'zygote'
[   18.297271] init: /init.zygote64_32.rc: 10: ignored duplicate definition of service 'zygote_secondary'
[   18.307463] init: (Parsing /init.zygote64_32.rc took 0.02s.)
[   18.313776] init: (Parsing /init.trace.rc took 0.00s.)
[   18.319833] init: (Parsing /init.superuser.rc took 0.00s.)
[   18.325832] init: (Parsing /init.cm.rc took 0.01s.)
[   18.331182] init: (Parsing /init.rc took 0.09s.)
[   18.336456] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[   18.346946] init: Starting service 'ueventd'...
[   18.352297] init: Waiting for /dev/.coldboot_done...
[   18.354516] ueventd: ueventd started!
[   18.755285] ueventd: Coldboot took 0.40s.
[   18.759962] init: Waiting for /dev/.coldboot_done took 0.41s.
[   18.766320] init: /dev/hw_random not found
[   18.770963] keychord: using input dev sunxi_ir_recv for fevent
[   18.777334] keychord: using input dev MCE IR Keyboard/Mouse (sunxi-rc-recv) for fevent
[   18.786504] keychord: using input dev axp81x-supplyer for fevent
[   18.793077] keychord: using input dev audiocodec sunxi Audio Jack for fevent
[   18.802544] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.811801] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.822314] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.835626] init: write_file: Unable to open '/proc/cpu/alignment': No such file or directory
[   18.845318] init: write_file: Unable to open '/proc/sys/kernel/sched_compat_yield': No such file or directory
[   18.858209] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.866487] init: write_file: Unable to write to '/dev/cpuctl/cpu.shares': Invalid argument
[   18.877498] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[   18.890864] SELinux: initialized (dev pstore, type pstore), uses genfs_contexts
[   18.899267] init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory
[   18.911030] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   18.920647] init: /dev/hw_random not found
[   18.955285] [NAND]Failed to insmod nand!!!
[   18.963011] init: Warning!  Service exec 0 (/sbin/busybox) needs a SELinux domain defined; please fix!
[   18.973214] init: Starting service 'exec 0 (/sbin/busybox)'...
[   18.980352] type=1400 audit(1262304013.780:3): avc:  denied  { execute_no_trans } for  pid=1380 comm="init" path="/sbin/busybox" dev="rootfs" ino=3978 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   19.002355] init: cannot execve('/sbin/busybox'): Permission denied
[   19.009517] init: Service 'exec 0 (/sbin/busybox)' (pid 1380) exited with status 127
[   38.073612] fs_mgr: __mount(source=/dev/block/by-name/system,target=/system,type=ext4)=-1
[   38.082640] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/system at /system options: (null) error: No such file or directory
[   57.748671] fs_mgr: __mount(source=/dev/block/by-name/cache,target=/cache,type=ext4)=-1
[   57.757512] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/cache at /cache options: nomblk_io_submit,barrier=1 error: No such file or directory
[   77.435145] fs_mgr: __mount(source=/dev/block/by-name/alog,target=/logger,type=ext4)=-1
[   77.443968] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/alog at /logger options: nomblk_io_submit,barrier=1 error: No such file or directory
[   97.111583] fs_mgr: __mount(source=/dev/block/by-name/UDISK,target=/data,type=ext4)=-1
[   97.120316] fs_mgr: fs_mgr_mount_all(): possibly an encryptable blkdev /dev/block/by-name/UDISK for mount /data type ext4 )
[   97.132714] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   97.140713] init: fs_mgr_mount_all returned an error
[   97.146496] init: fs_mgr_mount_all returned unexpected error 255
[   97.153160] init: cannot find '/system/bin/app_process64', disabling 'zygote'
[   97.161333] init: cannot find '/system/bin/app_process32', disabling 'zygote_secondary'
[   97.170136] init: cannot find '/system/bin/sh', disabling 'console'
[   97.180484] Unable to find swap-space signature
[   97.185517] fs_mgr: swapon failed for /dev/block/zram0
[   97.191271] init: cannot find '/system/bin/installd', disabling 'installd'
[   97.198876] init: cannot find '/system/bin/logd', disabling 'logd'
[   97.206623] init: SELinux: Could not set context for /cache:  Read-only file system
[   97.216936] init: SELinux: Could not set context for /logger:  Read-only file system
[   97.225695] init: (Loading properties from /system/build.prop took 0.00s.)
[   97.233267] init: (Loading properties from /vendor/build.prop took 0.00s.)
[   97.240847] init: (Loading properties from /factory/factory.prop took 0.00s.)
[   97.248860] init: /recovery not specified in fstab
[   97.255328] init: cannot find '/system/bin/logd', disabling 'logd'
[   97.262131] init: cannot find '/system/bin/vold', disabling 'vold'
[   97.269439] init: Not bootcharting.
[   97.301763] init: SELinux: Could not get canonical path /data/user/0 restorecon: No such file or directory.
[   97.312540] init: cannot find '/system/bin/tzdatacheck', disabling 'exec 1 (/system/bin/tzdatacheck)'
[   97.323414] init: cannot find '/system/bin/gatekeeperd', disabling 'gatekeeperd'
[   97.331547] init: cannot find '/system/xbin/perfprofd', disabling 'perfprofd'
[   97.339407] init: cannot find '/system/bin/sdcard', disabling 'sdcard'
[   97.346864] init: Warning!  Service bootclone needs a SELinux domain defined; please fix!
[   97.356069] init: Starting service 'bootclone'...
[   97.362003] type=1400 audit(1262304093.430:4): avc:  denied  { execute_no_trans } for  pid=1383 comm="init" path="/sbin/busybox" dev="rootfs" ino=3978 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   97.362025] init: Warning!  Service precopy needs a SELinux domain defined; please fix!
[   97.362036] init: Starting service 'precopy'...
[   97.362680] type=1400 audit(1262304093.430:5): avc:  denied  { execute_no_trans } for  pid=1384 comm="init" path="/sbin/busybox" dev="rootfs" ino=3978 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
[   97.362739] init: cannot execve('/sbin/busybox'): Permission denied
[   97.363072] init: Service 'precopy' (pid 1384) exited with status 127
[   97.363834] init: cannot find '/system/bin/sysinit', disabling 'sysinit'
[   97.363941] init: (Loading properties from /data/local.prop took 0.00s.)
[   97.364087] init: cannot find '/system/bin/logd', disabling 'logd'
[   97.364143] init: cannot find '/system/bin/logd', disabling 'logd-reinit'
[   97.369477] init: Starting service 'healthd'...
[   97.369995] init: cannot find '/system/bin/lmkd', disabling 'lmkd'
[   97.370046] init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
[   97.370115] init: cannot find '/system/bin/surfaceflinger', disabling 'surfaceflinger'
[   97.370197] init: cannot find '/system/bin/sayeye', disabling 'sayeye'
[   97.372584] binder: 1385:1385 transaction failed 29189, size 0-0
[   97.373047] init: write_file: Unable to open '/proc/bluetooth/sleep/lpm': No such file or directory
[   97.380799] init: cannot find '/system/bin/sh', disabling 'console'
[   97.380962] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such file or directory
[   97.381019] init: write_file: Unable to open '/sys/class/android_usb/android0/idVendor': No such file or directory
[   97.381080] init: write_file: Unable to open '/sys/class/android_usb/android0/idProduct': No such file or directory
[   97.381137] init: write_file: Unable to open '/sys/class/android_usb/android0/functions': No such file or directory
[   97.381194] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such file or directory
[   97.381287] init: Starting service 'adbd'...
[   97.582685] init: cannot execve('/sbin/busybox'): Permission denied
[   97.589900] init: Service 'bootclone' (pid 1383) exited with status 127
[   98.356700] binder: 1385:1385 transaction failed 29189, size 0-0
[   99.347342] binder: 1385:1385 transaction failed 29189, size 0-0
[  100.338012] binder: 1385:1385 transaction failed 29189, size 0-0
The logs between this and the previous boot.img show no difference, https://www.diffchecker.com/whcbcrjc
CyanogenMod 13 - by Hahaburger - 02-02-2016, 05:43 PM
RE: CyanogenMod 13 - by tllim - 02-02-2016, 10:10 PM
RE: CyanogenMod 13 - by taros - 02-03-2016, 04:20 AM
RE: CyanogenMod 13 - by Hahaburger - 02-03-2016, 06:56 AM
RE: CyanogenMod 13 - by taros - 02-03-2016, 07:44 AM
RE: CyanogenMod 13 - by Hahaburger - 02-03-2016, 10:39 AM
RE: CyanogenMod 13 - by taros - 02-03-2016, 03:34 PM
RE: CyanogenMod 13 - by Hahaburger - 02-04-2016, 08:22 AM
RE: CyanogenMod 13 - by taros - 02-04-2016, 05:15 PM
RE: CyanogenMod 13 - by Hahaburger - 02-05-2016, 05:54 AM
RE: CyanogenMod 13 - by taros - 02-05-2016, 06:47 AM
RE: CyanogenMod 13 - by Hahaburger - 02-05-2016, 06:03 PM
RE: CyanogenMod 13 - by taros - 02-07-2016, 07:55 AM
RE: CyanogenMod 13 - by Hahaburger - 02-07-2016, 10:20 AM
RE: CyanogenMod 13 - by Zoidiano0 - 02-03-2016, 02:05 PM
RE: CyanogenMod 13 - by Hahaburger - 02-03-2016, 03:12 PM
RE: CyanogenMod 13 - by taros - 02-07-2016, 04:30 PM
RE: CyanogenMod 13 - by Hahaburger - 02-08-2016, 11:22 AM
RE: CyanogenMod 13 - by taros - 02-08-2016, 01:56 PM
RE: CyanogenMod 13 - by Hahaburger - 02-10-2016, 12:25 PM
RE: CyanogenMod 13 - by Hahaburger - 03-02-2016, 02:31 AM
RE: CyanogenMod 13 - by Zoidiano0 - 03-02-2016, 06:55 AM
RE: CyanogenMod 13 - by janjwerner - 03-16-2016, 07:00 PM
RE: CyanogenMod 13 - by Hahaburger - 03-17-2016, 12:00 PM
  Cyanogenmod 13 GoZone 2 4,028 03-30-2016, 06:06 AM
Last Post: g_t_j
Heart CyanogenMod Danton 12 16,383 01-30-2016, 11:35 AM
