CyanogenMod 13
(02-03-2016, 10:39 AM)Hahaburger Wrote:
(02-03-2016, 07:44 AM)taros Wrote: The HDMI output shows the A64 bootlogo (it's stuck) and the console output is more encouraging.
I think the main issue is with being unable to mount the system partition.
I am still happy to try any newer image.
I've set SELinux to permissive mode to at least find out if ROM boots. I'll add missing policies after ROM starts to work Smile
Here is new boot image: https://drive.google.com/file/d/0B5NrIPX...sp=sharing
I tried out the fresh boot.img (sha256sum: c0cf4c0b137e1366ab1621ece7fdc82a41259bc7d13c37917483705ed3802874) and it hangs quite early (Cannot find kernel):
[     13.771]inter uboot shell
Hit any key to stop autoboot:  0
read partition: boot or recovery
[     14.605]sunxi flash read :offset 4000000, 16918757 bytes OK
Kernel load addr 0x41080000 size 10881 KiB
Kernel command line: androidboot.selinux=permissive
RAM disk load addr 0x42000000 size 4617 KiB
[     14.956]ready to boot
prepare for kernel
[mmc]: MMC Device 2 not found
[mmc]: mmc 2 not find, so not exit
Starting kernel ...
INFO:    BL3-1: Next image address = 0x41080000
INFO:    BL3-1: Next image spsr = 0x3c5
Actually, here is all the information from the console:
Connected.
HELLO! BOOT0 is starting!
boot0 commit : 2fe7b0a9fb512fae2996ec1a2ba89d535e1f3c4d
boot0 version : 4.0.0
set pll start
set pll end
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
DRAM driver version: V1.1
rsb_send_initseq: rsb clk 400Khz -> 3Mhz
PMU: AXP81X
ddr voltage = 1500 mv
DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM clk = 672 MHz
DRAM zq value: 003b3bbb
DRAM single rank full DQ OK
DRAM size = 1024 MB
DRAM init ok
dram size =1024
card boot number = 0, boot0 copy = 0
card no is 0
sdcard 0 line count 4
[mmc]: mmc driver ver 2015-05-08 20:06
[mmc]: sdc0 spd mode error, 2
[mmc]: Wrong media type 0x00000000
[mmc]: ***Try SD card 0***
[mmc]: HSSDR52/SDR25 4 bit
[mmc]: 50000000 Hz
[mmc]: 15423 MB
[mmc]: ***SD/MMC 0 init OK!!!***
sdcard 0 init ok
The size of uboot is 000fc000.
sum=15bc131f
src_sum=15bc131f
Succeed in loading uboot from sdmmc flash.
boot0: start load other image
boot0: Loading BL3-1
Loading file 0 at address 0x40000000,size 0x0000b400 success
boot0: Loading scp
Loading file 2 at address 0x00040000,size 0x00019c00 success
set arisc reset to de-assert state
Ready to disable icache.
J9=�    Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):2fe7b0a
NOTICE:  BL3-1: Built : 10:15:37, Jan 12 2016
NOTICE:  BL3-1 commit: 2fe7b0a9fb512fae2996ec1a2ba89d535e1f3c4d
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x4a000000
INFO:    BL3-1: Next image spsr = 0x1d3
U-Boot 2014.07 (Jan 12 2016 - 10:15:41) Allwinner Technology
uboot commit : 2fe7b0a9fb512fae2996ec1a2ba89d535e1f3c4d
rsb: secure monitor exist
[      0.377]pmbus:   ready
[      0.380][ARISC] :arisc initialize
[      0.710][ARISC] :arisc_dvfs_cfg_vf_table: support only one vf_table
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :arisc_para size:1a8
[SCP] :arisc version: [v0.1.76]
[SCP] :sunxi-arisc driver v1.10 is starting
[      0.838][ARISC] :sunxi-arisc driver startup succeeded
[      0.871]PMU: AXP81X
[      0.873]PMU: read AXP81X 84H=0xf2
[      0.877]PMU: write AXP81X 84H=0xf6
[      0.880]PMU: AXP81X found
bat_vol=321, ratio=100
[      0.887]PMU: dcdc2 1100
[      0.890]PMU: cpux 1008 Mhz,AXI=336 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz AHB2=300Mhz MBus=400Mhz
device_type = 3253, onoff=1
dcdc1_vol = 3300, onoff=1
dcdc2_vol = 1100, onoff=1
dcdc6_vol = 1100, onoff=1
aldo1_vol = 2800, onoff=0
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
dldo1_vol = 3300, onoff=0
dldo2_vol = 3300, onoff=0
dldo3_vol = 2800, onoff=0
dldo4_vol = 3300, onoff=1
eldo1_vol = 1800, onoff=1
eldo2_vol = 1800, onoff=0
eldo3_vol = 1800, onoff=0
fldo1_vol = 1200, onoff=0
fldo2_vol = 1100, onoff=1
gpio0_vol = 3100, onoff=0
vbus not exist
no battery, limit to dc
run key detect
key pressed value=0x1
fel key not configed
key pressed value=0x2
time out
key not pressed anymore
no uart input
DRAM:  1008 MiB
fdt addr: 0x76eb70e0
Relocation Offset is: 35f09000
In:    serial
Out:   serial
Err:   serial
gic: sec monitor mode
[     12.573]start
drv_disp_init
init_clocks: finish init_clocks.
enable power vcc-hdmi-33, ret=0
drv_disp_init finish
boot_disp.output_disp=0
boot_disp.output_type=3
boot_disp.output_type=10
fetch script data boot_disp.auto_hpd fail
disp0 device type(4) enable
attched ok, mgr0<-->device1, type=4, mode=10
[     12.945]end
workmode = 0,storage type = 1
[     12.949]MMC: 0
[mmc]: mmc driver ver 2015-07-29 14:10:00
SUNXI SD/MMC: 0
[mmc]: start mmc_calibrate_delay_unit, don't access device...
[mmc]: delay chain cal done, sample: 200(ps)
[mmc]: media type 0x0
[mmc]: ************Try SD card 0************
[mmc]: host caps: 0x27
[mmc]: MID 1b PSN 008541f6
[mmc]: PNM 00000 -- 0x30-30-30-30-30
[mmc]: PRV 1.0
[mmc]: MDT m-12 y-2011
[mmc]: speed mode     : HSSDR52/SDR25
[mmc]: clock          : 50000000 Hz
[mmc]: bus_width      : 4 bit
[mmc]: user capacity  : 15423 MB
[mmc]: ************SD/MMC 0 init OK!!!************
[mmc]: erase_grp_size      : 0x1WrBlk*0x200=0x200 Byte
[mmc]: secure_feature      : 0x0
[mmc]: secure_removal_type : 0x0
[     13.162]sunxi flash init ok
--------fastboot partitions--------
-total partitions:11-
-name-        -start-       -size-
bootloader  : 1000000       2000000
env         : 3000000       1000000
boot        : 4000000       1000000
system      : 5000000       60000000
misc        : 65000000      1000000
recovery    : 66000000      2000000
cache       : 68000000      30000000
metadata    : 98000000      1000000
private     : 99000000      1000000
alog        : 9a000000      5000000
UDISK       : 9f000000      0
base bootcmd=run setargs_nand boot_normal
bootcmd set setargs_mmc
key 1
recovery key high 12, low 10
fastboot key high 6, low 4
misc partition found
to be run cmd=run setargs_mmc boot_normal
update dtb dram start
update dtb dram  end
** Unrecognized filesystem type **
load file(sn.txt) error
serial is: 241051900808142809cb
no battery exist
sunxi_bmp_logo_display
681774 bytes read in 36 ms (18.1 MiB/s)
bmp file buffer: 0x41000000, bmp_info.buffer: 47400000
fetch script data boot_disp.output_full fail
screen_id =0, screen_width =1920, screen_height =1080
frame buffer address 47400036
prepare for kernel
Starting kernel ...
CyanogenMod 13 - by Hahaburger - 02-02-2016, 05:43 PM
RE: CyanogenMod 13 - by tllim - 02-02-2016, 10:10 PM
RE: CyanogenMod 13 - by taros - 02-03-2016, 04:20 AM
RE: CyanogenMod 13 - by Hahaburger - 02-03-2016, 06:56 AM
RE: CyanogenMod 13 - by taros - 02-03-2016, 07:44 AM
RE: CyanogenMod 13 - by Hahaburger - 02-03-2016, 10:39 AM
RE: CyanogenMod 13 - by taros - 02-03-2016, 03:34 PM
RE: CyanogenMod 13 - by Hahaburger - 02-04-2016, 08:22 AM
RE: CyanogenMod 13 - by taros - 02-04-2016, 05:15 PM
RE: CyanogenMod 13 - by Hahaburger - 02-05-2016, 05:54 AM
RE: CyanogenMod 13 - by taros - 02-05-2016, 06:47 AM
RE: CyanogenMod 13 - by Hahaburger - 02-05-2016, 06:03 PM
RE: CyanogenMod 13 - by taros - 02-07-2016, 07:55 AM
RE: CyanogenMod 13 - by Hahaburger - 02-07-2016, 10:20 AM
RE: CyanogenMod 13 - by Zoidiano0 - 02-03-2016, 02:05 PM
RE: CyanogenMod 13 - by Hahaburger - 02-03-2016, 03:12 PM
RE: CyanogenMod 13 - by taros - 02-07-2016, 04:30 PM
RE: CyanogenMod 13 - by Hahaburger - 02-08-2016, 11:22 AM
RE: CyanogenMod 13 - by taros - 02-08-2016, 01:56 PM
RE: CyanogenMod 13 - by Hahaburger - 02-10-2016, 12:25 PM
RE: CyanogenMod 13 - by Hahaburger - 03-02-2016, 02:31 AM
RE: CyanogenMod 13 - by Zoidiano0 - 03-02-2016, 06:55 AM
RE: CyanogenMod 13 - by janjwerner - 03-16-2016, 07:00 PM
RE: CyanogenMod 13 - by Hahaburger - 03-17-2016, 12:00 PM
  Cyanogenmod 13 GoZone 2 4,028 03-30-2016, 06:06 AM
Last Post: g_t_j
Heart CyanogenMod Danton 12 16,378 01-30-2016, 11:35 AM
