TP Cable Extension
(09-10-2016, 11:59 AM)Bluphire Wrote: Is the "byte sized" part literal? Or was it a computer programmer's joke?
I'm thinking I need these cables, and these pitch ribbon connector sockets.
But I do not know how to properly connect the 2 connectors. Can you lend some knowledge on that, preferably on a noob'd-down level?
byte-sized is humor, yes.
Ok , the cables will be fine, and the connectors will be fine too...  here is the trouble... the connectors will need to be placed on a board (an adapter board) soldered in place (there will need to be two of them, one for each cable) that will serve as a connector.  Otherwise, you'lll have to find one already made someplace., and there is probably one out there is you look hard enough.
To get an idea of wht I'm talking about take a look at your LCD connector adapter extender that came with your LCD display.  You will need to buy (or make) one like that for your tp ribbon as well,  only if you want to extend it... which frankly is not necessary.
TP Cable Extension - by Bluphire - 09-09-2016, 05:59 PM
RE: TP Cable Extension - by MarkHaysHarris777 - 09-09-2016, 07:04 PM
RE: TP Cable Extension - by Bluphire - 09-09-2016, 11:13 PM
RE: TP Cable Extension - by MarkHaysHarris777 - 09-10-2016, 09:09 AM
RE: TP Cable Extension - by Bluphire - 09-10-2016, 10:04 AM
RE: TP Cable Extension - by MarkHaysHarris777 - 09-10-2016, 10:21 AM
RE: TP Cable Extension - by Bluphire - 09-10-2016, 10:34 AM
RE: TP Cable Extension - by MarkHaysHarris777 - 09-10-2016, 10:48 AM
RE: TP Cable Extension - by Bluphire - 09-10-2016, 10:54 AM
RE: TP Cable Extension - by MarkHaysHarris777 - 09-10-2016, 11:23 AM
RE: TP Cable Extension - by Bluphire - 09-10-2016, 11:59 AM
RE: TP Cable Extension - by MarkHaysHarris777 - 09-10-2016, 12:32 PM
RE: TP Cable Extension - by Bluphire - 09-10-2016, 12:55 PM
RE: TP Cable Extension - by MarkHaysHarris777 - 09-10-2016, 12:57 PM
RE: TP Cable Extension - by Bluphire - 09-10-2016, 12:58 PM
RE: TP Cable Extension - by MarkHaysHarris777 - 09-10-2016, 01:06 PM
  playbox case ribbon cable too short pinoosh 7 15,163 02-22-2019, 03:24 AM
Last Post: GaryFunk
  ABS Playbox came with no extension cable? kenhawkins 4 8,130 09-12-2016, 02:47 PM
Last Post: echild
