Which of the following best describes your ethernet situation on the PineA64? (read first post, post your answers after the poll)
GbE ethernet has always worked on my PineA64 (regardless of OS choice)
5.88%
3
GbE ethernet has never worked on my PineA64 (regardless of OS choice)
76.47%
39
GbE ethernet NOW works on my PineA64 by changing the environment or configuration
9.80%
5
I'm not interested in GbE ethernet
0%
0
I don't use ethernet 10/100/1000 primarily
0%
0
My machines are primarily connected via wifi
1.96%
1
other
5.88%
3
51 vote(s)
GbE Ethernet Port Issue Data Gathering Statistics Intel
1) board serial number and type (2G) 410640123090 - A64-DB-2G-Rev B 2016-02-25
2) RTL chip numbers:  ie,  RTL8211E G2H97M2 GG098
3) current ethernet switch or router make model and numbers: Edimax ES-5500G V3 (previously tried with Asus WL-500GP running OpenWRT - didn't work either)
4) if you modded your board and made it work, how? No modifications
5) if you swapped out your switch or router and made it work, what or which? N/A
6) if GbE is critical to your operation, please tell us how so - no answer
7) provide any other additional 'data only' that might be helpful.
RE: GbE Ethernet Port Issue Data Gathering Statistics Intel - by klement - 08-29-2016, 03:01 PM
  Ethernet port down afert 1 day jeda 0 647 11-12-2022, 06:48 AM
Last Post: jeda
  Ethernet --> Causing boot loop podtofs 3 5,333 05-16-2017, 03:41 AM
Last Post: m17
  What will it take to get the Ethernet port working? clarkss12 10 16,547 10-17-2016, 03:42 PM
Last Post: waldo
  Ethernet Slow Download Ascotg 89 114,062 09-08-2016, 01:50 PM
Last Post: MarkHaysHarris777
  Pine64+ 1GB Ethernet Port spec ecotack 13 15,789 08-20-2016, 09:28 PM
Last Post: pfeerick
  If you have had difficulty with the GbE ethernet please take the poll MarkHaysHarris777 0 2,390 08-17-2016, 05:44 PM
  Ethernet works on Arch Linux. Nothing elese pfunk237 4 6,145 07-23-2016, 03:07 PM
Last Post: SuperArmySoldiers
