Weatherproof case build
(10-02-2016, 10:21 PM)KablammoNick Wrote:
(10-02-2016, 10:10 PM)ltorsini Wrote:
(10-02-2016, 09:53 PM)KablammoNick Wrote: Hi, what are you using for Zigbee interface?
No ZigBee radio yet,  Tllim just had it reshipped.  We're testing enocean at the moment with the 300 USB on Android  but still early days.  I'm hoping openHAB will be a good option for the ZigBee kit.
Cheers, hoping to add Zigbee to my HASS build, but would rather an internal radio board to keep it neat... hopefully the one from Pine64 uses the Euler bus as the RPi bus is full with Z-wave board.
If I'm not mistaken you can connect the enocean radio via EULER, a little hardware hacking is needed but a pretty clean install should result. Good luck regardless.
Sent from my PINE A64 using Tapatalk
Weatherproof case build - by ltorsini - 08-14-2016, 09:19 PM
RE: Weatherproof case build - by montero65 - 08-16-2016, 09:12 AM
RE: Weatherproof case build - by ltorsini - 08-18-2016, 06:34 AM
RE: Weatherproof case build - by montero65 - 08-18-2016, 06:46 AM
RE: Weatherproof case build - by ltorsini - 08-22-2016, 08:31 AM
Weatherproof case build - by ltorsini - 09-04-2016, 08:20 AM
RE: Weatherproof case build - by KablammoNick - 10-02-2016, 09:53 PM
RE: Weatherproof case build - by ltorsini - 10-02-2016, 10:10 PM
RE: Weatherproof case build - by KablammoNick - 10-02-2016, 10:21 PM
RE: Weatherproof case build - by ltorsini - 10-02-2016, 10:49 PM
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 64,385 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 3,976 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 12,343 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 11,554 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 19,017 07-18-2017, 10:39 AM
  A case with active cooling for 1Gb pine64 ishwest 5 10,061 06-28-2017, 04:05 AM
Last Post: ishwest
  Lego Case Kiryu 67 89,101 03-30-2017, 11:36 AM
Last Post: Luke
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 13,058 10-24-2016, 08:18 AM
Last Post: killor
  Pine64 Layer case modmypi 2 5,315 10-04-2016, 02:45 AM
Last Post: modmypi
  Playbox case orderable? schindlb 8 13,630 10-02-2016, 08:20 AM
Last Post: schindlb
