Joystick/Gamepad support
Question
Hello all, first time noob posting...
I've just got the Pine64+ 2GB model, installed the latest Debian XFCE image and did all of the updates suggested. I've successfully installed XMAME following this tutorial and now I'm trying to configure a gamepad to work with it. I've tried 2 separate USB devices, one is a PS2/PS3 compliant device and the other one is a DragonRise gamepad, but unfortunately both of them didn't work.
Here's the log from dmesg when I connect a gamepad:
[ 1299.821184] ehci_irq: highspeed device connect
[ 1299.948456] ohci_irq: fullspeed or lowspeed device connect
[ 1300.342055] usb 3-1: new full-speed USB device number 3 using sunxi-ohci
Here's an output from lsusb:
Bus 004 Device 002: ID 1997:2433
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 003: ID 054c:0268 Sony Corp. Batoh Device / PlayStation 3 Controller
...but there's no device detected in the /dev/input/ folder (/dev/input/js0 is missing). I've tried "cat" and "evtest" on every /dev/input/eventX device, but with no luck. I can see that both the "joydev" and "evdev" modules are built in, and I've installed the "joystick" and "xserver-xorg-input-joystick" packages, but nothing seems to help.
As I've seen on a Gentoo forum post, I've looked at /usr/src/linux-headers-3.10.102-2-pine64-longsleep/.config and I found that
# CONFIG_HID_DRAGONRISE is not set
and
# CONFIG_HID_SONY is not set
...so I guess this is the problem the system isn't detecting the gamepad devices. Now, I guess I need to somehow enable kernel support for those two, but I have no idea how and it doesn't seem like a one-liner...
Can anyone give me pointers or help?
Joystick/Gamepad support - by Drakuwa - 08-10-2016, 08:54 AM
RE: Joystick/Gamepad support - by CaptainZalo - 08-10-2016, 09:52 AM
RE: Joystick/Gamepad support - by Drakuwa - 08-10-2016, 10:09 AM
RE: Joystick/Gamepad support - by xalius - 08-10-2016, 10:12 AM
  Programming languages support under PINE64 baryluk 6 17,349 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  AXP803 Battery Charger Support xalius 14 32,762 12-22-2017, 08:59 AM
Last Post: Velociraptor
Wink Pine64 Will support Freenas or openmediavault ? joe 1 6,255 04-13-2017, 07:44 AM
Last Post: xalius
  Remote Desktop Support? Rochambeaux 20 39,278 10-01-2016, 05:08 PM
Last Post: HayseedGeek
  Binfmt_misc support cztian 1 4,897 08-17-2016, 11:49 PM
Last Post: longsleep
Big Grin Funny ! Support Intel x86 linux applications on ARM-based ( PINE64 ) not freeware joe 10 21,520 08-09-2016, 05:59 PM
Last Post: dkryder
  Camera support - Ubuntu Xenial 16.04 LTS @lex 3 7,336 08-07-2016, 03:47 AM
Last Post: romansavrulin
  Virtualization Support soccercheng 12 23,324 07-14-2016, 11:04 AM
Last Post: mont3z
  distro with kernel support for DVB-T dongles? mkaut 2 6,278 07-02-2016, 02:36 PM
Last Post: mkaut
  XFS Support? utdrmac 2 4,935 06-30-2016, 01:44 AM
