Difference in downloads
(08-06-2016, 01:24 PM)MarkHaysHarris777 Wrote: TL Lim has said that the engineers are working on this problem.  Ghost is correct, if it were easy to fix (and its not) it would have been fixed weeks ago.   It is NOT (in my opinion) a red faced issue  [   Angry   ]
The best thing to do at this point (from a user perspective) is get a larger card than you need (i recommend using the 32G cards Samsung Evo+ Class 10) and using them as is with what-ever sized image.  You  may find luck in expanding the partitions across the card with gparted.
Stay tuned, and stay positive !    Big Grin
I apologize for the red face ,should have used Confused  , I ended up installing the image for the 32 GB on my 64 GB card , one question : does this make the extra space left on the available ,or can I create another partition out of that space ? I'm more of a windows person is why I ask. Big Grin
Difference in downloads - by Obewon - 08-06-2016, 11:25 AM
RE: Difference in downloads - by Ghost - 08-06-2016, 12:15 PM
RE: Difference in downloads - by Obewon - 08-06-2016, 07:06 PM
RE: Difference in downloads - by jodybrown99 - 08-06-2016, 02:50 PM
