Release upgrade failed! Or not?
(02-06-2024, 06:18 AM)FortunateFowl Wrote: I would believe that it has upgraded successfully. Although it may still be a good idea to run
apk fix
as suggested. But the fact that the next upgrade command said that upgrade was successful suggests it worked fine.
It seems like this kind of error on upgrades is known, and it shouldn't cause install errors, see for example the comment at the bottom of this link or of this.
[url=https://gitlab.com/postmarketOS/postmarketos-release-upgrade/-/issues/5][/url]
Have you encountered any issues or error messages during the upgrade process, and have you tried running the "apk fix" command as suggested to ensure a successful upgrade?
Release upgrade failed! Or not? - by jojuma - 02-05-2024, 04:57 AM
RE: Release upgrade failed! Or not? - by jojuma - 02-06-2024, 03:01 PM
RE: Release upgrade failed! Or not? - by deep22 - 02-20-2024, 03:11 AM
RE: Release upgrade failed! Or not? - by jojuma - 02-23-2024, 01:52 AM
  Turn off 10 minute lockout after 3 failed log in attempts. rqkeating 0 597 06-18-2023, 12:00 PM
Last Post: rqkeating
  PineTab Mobian Upgrade issue - Pin no longer works thomzane 3 4,189 04-30-2021, 06:52 AM
Last Post: thomzane
