MicroSD Size mismatch with Image
(08-05-2016, 08:20 AM)montero65 Wrote: Marcus, I purchased one of the Samsung Evo+ cards, the 64GB version, and have had the exact same problem that I had with my SanDisk Ultra cards.  I have yet to find a company that sells flash storage that uses 1024.  Both my Samsung and SanDisk cards even state on the packaging (in very small letters) that they use 1000.  Knowing that is the case, I would agree with Stiansen (as well as many others that have made the same point in numerous threads) that the images should be sized with this in mind.  So telling someone to go buy a better quality SD card is not really a fix.
As mentioned in this thread, there are those of us who do not have a linux system or know anything about setting one up, myself included.  So we don't know how to deal with changing partitions.
I don't understand why the image files aren't just made a little smaller, as that would solve this problem once and for all.  From all the threads I've read on this same issue, it sounds like part of the image is actually just open space that can be used for storage.  Why not just make that a little smaller so it fits on the cards?  They aren't oversized by much, and I imagine dropping a small amount of the storage space would be the way to go.  Besides, having a 32GB image on a 64GB card means there's a ton of storage I'm missing out on, so if the storage available in the image was dropped by 1 or 2 GB, it would be an improvement because I could use the rest of the space on my larger card.
So make the images a little smaller, make everyone happy, and those of us that don't know how to resize partitions can still make full use of the cards we buy.  It seems much easier for the provider of the images to resize rather than asking every user to resize the image on their own.
I plan to make the build image smaller for sub sequence build. Currently, I am collecting the physical capacity size of microSD card in market to determine the build size. I also don't want to be too small and waste capacity.
MicroSD Size mismatch with Image - by Hbtr - 07-30-2016, 08:31 PM
RE: MicroSD Size mismatch with Image - by Hbtr - 07-31-2016, 07:38 AM
RE: MicroSD Size mismatch with Image - by tllim - 08-01-2016, 02:11 PM
RE: MicroSD Size mismatch with Image - by Obewon - 08-04-2016, 04:47 PM
RE: MicroSD Size mismatch with Image - by tllim - 08-05-2016, 12:27 PM
RE: MicroSD Size mismatch with Image - by DonFL - 08-05-2016, 01:43 PM
RE: MicroSD Size mismatch with Image - by tllim - 08-07-2016, 05:40 PM
RE: MicroSD Size mismatch with Image - by FoZo - 08-08-2016, 08:19 AM
  Reducing Android Image download size. KPhillisJr 4 8,211 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 6,436 07-18-2017, 08:49 AM
Last Post: eclay
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 23,436 05-05-2017, 01:50 AM
Last Post: Quezbeme
  Error formatting MicroSD Terra854 21 39,763 03-07-2017, 01:31 AM
Last Post: AnaNova
  android image & sd card size problems tomarneson 11 17,987 01-24-2017, 05:31 AM
Last Post: ayufan
  Tutorial: How to create DD images with appropriate size tkaiser 5 12,574 12-20-2016, 08:17 AM
Last Post: Bluphire
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 24,222 10-29-2016, 04:31 AM
Last Post: joe
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 5,656 10-17-2016, 11:42 AM
Last Post: mathiraj
  burning Android SD image with Ubuntu... Jessica Spongekipper 0 2,098 09-16-2016, 01:46 AM
Last Post: Jessica Spongekipper
  Can't read SD card on Mac/Win after mounting DD Android image Voyager 3 5,604 09-04-2016, 12:05 PM
Last Post: Boring
